Question about Juki DNU-1541 Mechanical Sewing Machine
Bobbin wont move
A thread got caught in the bobbin while I was winding a bobbin and it made a terrible noise and now the bobbin won't move at all
    New Friend:
Not sure if you have had your question answered, but I've been down that road and it drove me nuts!! Simple solution: reset the clutch. There's a silver button in the middle of the bed, push it down, and hand rotate the wheel in the opposite direction until it clicks. Now it should work. (it's a built in safety feature that trips when something is wrong so you don't destroy your machine)
Posted on Dec 09, 2012
Why is my thread getting caught under needle plate?
try changing the needle
make sure the thread has not come off the thread take up lever
try turning the bobbin the opposite way
Jan 09, 2013 | Janome Sewist 625e
Bobbin won't move
Check for thread caught under silver guide, may have got jammed in there.
Aug 16, 2012 | Singer Quantum XL-6000 Computerized Sewing...
Bobbin won't move
rethread the machine top & bobbin
make sure the bobbin is wound correctly & inserted correctly
into the bobbin case
if these suggestions don't help then you might think about having
the machine checked at a sewing machine shop
Aug 05, 2012 | Brother PC-420
Bobbin won't wind - foot pedal working but bobbin won't turn ES2020 New *unused just stored since purchase from new*
Your new but stored machine has sat long enough that any oils from the factory have become gummy and or dried out. I would take it in and have the pros service it. But for now you might try....
Turning the hand wheel by hand while you press on the pedal. This MAY free up the machine enough for the motor to take over.
Jul 21, 2012 | Sewing Machines
Pfaff select 1540 bobbin thread jam
if there is a thread in the hook area try taking a pair of needle nose
pliers to try & get the thread out, if that doesn't work then you might
think about taking the machine to a sewing machine shop to have the
machine checked since the needle will not go up & down & handwheel
won't move
May 03, 2012 | PfaFF Sewing Machines
Bobbin won't wind on singer 5500 just makes motor noise
the machine probably needs to be serviced
Apr 13, 2012 | Sewing Machines
Upper thread get s caught under the needle plate when free motion quilting. Forms a loop and the fabric can't move.
change the needle
clean under the needle plate & in the bobbin area for loose threads & lint
Mar 16, 2012 | Husqvarna Sewing Machines
Thread breaking, not even threaded in needle anymore, thread gets caught on spool sometimes
Upper thread breaks
1.the needle may be bent or damaged--try rolling the needle on a flat surface to see if it's bent or not
Or the needle could be in backwards
Correct needle insertion
Correct needle insertion is mandatory for proper use of sewing machine.
Raise the needle bar to the highest point, then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine or if using a round needle--the groove in the needle should face away from the shaft.
Push the needle all the way up to the stop or as far as it will go, then tighten the needle clamp screw
2.upper tension may be to tight--try 3 to 5
3.thread may be hanging up in bobbin case--check area for loose threads or lint
Lower thread breaks
The most probable cause of lower thread breaking is improperly wound bobbin
1.always start with a empty bobbin
Never wind one color over the other
2.choose thread that is identical in color & type as the one to be used for upper threading
3.wind the bobbin evenly across & in layers
4.don't wind the bobbin so full that it would be tight & hard to insert into bobbin case
5.bent bobbin--replace
6.lint built up in the bobbin case--frequent cleanings will eliminate this problem, the more often you use the sewing machine the more often it needs to be cleaned
7.thread catching on the bobbin spring or latch on bobbin case, check to see that the bobbin is inserted completely & correctly, & that you are using the right kind of bobbin
for the top & bobbin thread keep thread tails of 3 to 6 inches long pulled behind the needle before you start sewing
yes,sometimes the thread will get caught on the spool, you might think about getting a extra holder that sets behind the machine to hold those spool's that the thread get caught on, that's what I did.
Sep 15, 2011 | Brother PE770 Computerized Sewing Machine
The thread keeps jamming under the feed dogs. The machine takes about 2 stiches and then it won't move any more, but it keeps sewing making a terrible mess under plate. What can I do to fix this...
I had the same problem and tried everything you did: rewinding the bobbin, checking to be sure I had the bobbin in correctly, checking the upper threading, readjusting the tension. When nothing I tried helped, I bit the bullet and took it to the shop where I had bought it. The timing was off; there were burrs on the bobbin case; the hook was not performing correctly;there were threads caught between the tension disks. It cost about $65 but when I brought it home, it purred like a kitten! I suggest you take it in for a check up! Especially if you've tried all the usual tests and none of them worked.
I'm sorry I couldn't give you a do-it-yourself answer but sometimes they've just gone beyond what we can do for them.
Jul 24, 2011 | Brother SE350 Mechanical Sewing Machine
Bobbin won't wind correctly!!
Iam very picky about my bobbins!
make sure you are threading the machine for the bobbin correctly, In my opinion I don't think any machine really winds well.
What I do is hold the thread about an 1" away from the bobbin. start to wind and I guide the thread slowly up and down the bobbin so that it winds even
Aug 28, 2009 | White Sewing 2200 Multi-Tasker
Sewing Machines Logo
155 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
