Question about Maytag Neptune MAH5500B Front Load Washer
Trying to check the fuse for the motor... - Maytag Neptune MAH5500B Front Load Washer
  • badogspike
    badogspike Nov 08, 2012
    a couple on screws inside the front door and it will pop off the face of the washer....
    Top Expert:
  • Maytag Master
  • 9,472 Answers
Posted on Nov 09, 2012
dh1200s
  • 335 Answers
SOURCE: how to get front panel off neptune fav6800aww washing machine
Just a quick search in this forum fot "Front Panel" returned this post which says it better then I could.
http://www.fixya.com/support/t538238-remove_front_panel
Posted on Jan 18, 2009
  • 398 Answers
SOURCE: How do I open my maytag Neptune MAH9700AWW front load washer?
first get access to the back of it. find the screws that hold the accsess panel on unscrew and look underneath. its on the bottom.
Posted on Feb 19, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Maytag Neptun will not agitate or spin
Change your timer. or timer sensor. behind your knobs
Posted on Feb 14, 2009
SOURCE: my maytag front loader will not drain water oe comes on the control panel
On the 9700s it's even easier - three screws on the front bottom panel below the door, then use your hand to unscrew the large round handle in the front center. When you can't unscrew any more, pull gently and the filter / catcher will come out.
It's amazing how much stuff mine held - 4 breastfeeding shields, a pencil, a pen, a fake mouse, and lots of grey gunk.
Screw it back in, put the panel back on, and you're in business.
Posted on May 04, 2009
FAV6800AWDIY
  • 526 Answers
SOURCE: Front Panel
See the first part of my Clutch Fix I describe the process and have links to the Service manual.....Rich
Posted on Apr 26, 2010
Windows blowing 15a fuse under coloum
Shorted motor, stuck motor, wire touching metalof door, circuit pulling to much power, try this disconnect all motors replace fuse connect one motor at a time checking fuse between each one also try each window after connection when fuse blowes that motor is shorted
Dec 11, 2015 | Cars & Trucks
My windshield wiper sprayer is not working
Look in the fuse panel to visibly check for blown fuse. Each manufacturer hides the fuses in a different place - sometimes under the dash panel, sometimes behind an ash tray or change compartment, sometimes in the glove box. The panel should have a fuse layout diagram with the rated amps for each use - usually 10, 15, 20 or 30. When you find the blown fuse replace with a new one of the same amp rating - too low and it will blow. Too high and you could damage the wiring if there's a short. Before I went crazy tracing fuses, check the plug on the washer motor. I would unplug it, clean the contacts with a spray cleaner and replace.
Or maybe the pump motor has gone bad. Electronics Goldmine sells washer pump motors very cheaply. One of them may fit.
Aug 02, 2015 | 2009 Chevrolet Chevrolet Cobalt LT
Wipers do not work
Begin troubleshooting by checking 30A FUSE 116 in the battery junction box and 7.5 A FUSE 17 in the central junction box.
Mar 07, 2014 | 2004 Mercury Grand Marquis
Winshield wipers arent working, already tried to change fuses is there more than one fuse box to check
did you check the wipers motor relay? is in the same fuse box in engine compartment.Thanks
Mar 28, 2011 | 2001 Ford Focus
Heater fan won't work
Hope this helps, it it does please leave feedback Thank You and Good Luck
Check fuses
Check power at blower motor
if there is power try to tap the motor this may getting it going but you will need motor.
if no power
check power before resistor
if power present and it goes on/off with blower motor switch
resistor is bad
if no power to resistor check power from fuse to resistor
but most likely it will be either the fuse, resistor or the motor
Jan 01, 2011 | 2000 Chevrolet Blazer
Electric windows will not go mup or down in the front I have tried new electrics and they still don't work is it afuse or regulator any ideas anyone
have you checked fuse if its not the fuse do you hear motor when you push up on window switch if fuse is good then take door panel off check motor for power if motor dont work window motor is bad replace motor
Dec 21, 2010 | 1999 Toyota Camry
I am trying to figure out which relay is for the front blower motor. anyone know?
Hi!!
Look ion the INSTRUMENT PANEL Fuse Box, there are two blower motor relays and two fuses, look on the inside of the relay cover for a diagram. The relay you are looking for should be labeled FRONT BLOWER MOTOR RELAY and the rear one should say AUXILIARY BLOWER MOTOR RELAY.
The TWO fuses with the same name on passenger compartment fuse box check:
  • fuse #39 30A fuse. AUXILIARY BLOWER MOTOR
  • fuse #36 30A fuse. AUXILIARY BLOWER RELAY
Dec 09, 2010 | 1996 Ford Windstar
Heater fan not working
check for power at fan, but frist check all fuses. if fuses are good then check for power at fan if you have power at fan then fan is bad.hope this helps.
Oct 08, 2009 | 2000 Pontiac Grand Prix
Maytag Neptune MAH5500B Front Load Washer Logo
14 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
