Question about Cyclades Avocent Acs48 Sac 48-port Console Terminal Server Switch 10/100b-t
I dont know where I should start. Can I be able to open the GUI instead so I can assign IP for this device?
  • 2,878 Answers
I beleive its Telnet or SHH via console. You need to connect it on a DHCP port so a IP is picked up.
http://global.avocent.com/us/olh/ACS/v_3.1.0/wwhelp/wwhimpl/js/html/wwhelp.htm
Posted on Nov 09, 2012
Reserve ip address
It all depends on the brand of your router, but mainly is to jump into the GUI with your admin password, look for DHCP options, static DHCP and save the MAC Address of the host with the desired IP.
Apr 29, 2014 | Netopia Computers & Internet
Port forwarding
WHEN YOU OPEN A PORT YOU NEED TO ASSIGN THE DEVICE THAT GOES ASSOCIATED WITH IT...LIKE PC1 IP 192.168.1.1
PC2 IP 192.168.1.2 THE PORT YOU WANT TO OPEN NEEDS TO BE ASSOCIATED TO EITHER PC1 0R PC2 WHICH EVER IS RUNNING YOUR APLICATION...TEKGODS.COM
Feb 18, 2013 | D-Link DSL-2740R Wireless N ADSL2 4-Port...
Connection using ip address for bizhub 350 from desktop
If you want to check the connection from desktop ten follow this.Click on start menu.In run, type cmd and press ENTER.Now in dos mode type ping>space>ip address of machine which you want to check. press enter.If it shows TTL=32 or ttl=64 then it means OK.Your machine is connected with desktop.
Now if you want to put your machine on network and want to assign IP to machine then do these steps1-Connect the network cable to machine.2-Assign an IP to machine.3-To assign the IP, Simply press "Utility/counter" button.4-press "check details" button on LCD panel.5-Now press Admin management.6-Enter password. 123456787-select ADMIN 28-select Network settings.9-Select DHCP.set it to manual instead of auto obtain.10-Now assign the IP in IP address option and after entering correct free ip restart the machine.
Jan 17, 2012 | Minolta bizhub 350 Black and White Copier
WRT4G2 VI wireless router. I was upating the firmware when the power flashed. I have no access to the router's gui and the router is not broadcasting. I am not getting a dhcp address
do a hard reset for the router by pressing the reset button for 10-20 seconds...
check whether its getting a dhcp address...
if it is still not getting an ip address, then try to assign a static ip address in the range of your router on your computer...
for example...
The default ip address of linksys is 192.168.1.1.............
then assign
IP address 192.168.1.5
Subnet mask 255.255.255.0
Default gateway 192.168.1.1
Also assign a static DNS
Primary DNS : 8.8.8.8
Secondary DNS : 8.8.4.4
Now try to open the GUI of your router...
Dec 10, 2010 | Linksys WRT54G2 Wireless Router
We currently have benkin wireless in th home but for some reason can't get it to hook up on two other computers in the house. What should we do
Before you do the steps below make sure your Networking Interface Card (NIC) is working. You can find out this by typing 127.0.0.1 in command prompt (to bring command prompt type cmd in the RUN command)
Step 01: type ncpa.cpl on the Run command
Step 02: Right click the network connection and navigate to the properties.
Step 03: Under Networking Tab select the Internet Protocol IP v 4 click property button right underneath it.
Step 04: Under General make sure to click the Obtain IP automatically and Obtain DNS automatically. This allows your belkin wireless router to assign IP address dynamically.
Step 05: Open your web browser and type 192.168.1.1 (usually this address is your default gateway if not 0.1 or 2.1 on the address) and access the belkin router.
LAN settings: IP address should be your default gateway address and subnet mask will assign automatically if not type 255.255.255.0 on the subnet mask section.
Make sure DHCP (Dynamic Host Config Protocol) is on and assign IP pool from next address to starting address and ending usually 254 or 100)
Start 192.168.2.2 End 192.168.2.100
Lease Make sure DNS are assign automatically.
ignore above steps if they are already assigned.
once you finished reboot your computer (you dont have to do this)
Now open browser enjoy.
If you still dont get internet you must check your cabling with ur router to pc. or different port
Thank you Visit www.somdtech.co.uk
Sep 12, 2010 | Computers & Internet
Windows system error: "an IP address conflict wit...
This error indicates that you have two devices on your network that have the same ip address assigned to them.
If you have have ip addresses manually assigned to your network devices you can open a command prompt and enter IPCONFIG, this will tell you what the ip address is of the device that is giving you the error. This ip address is assigned to another device on your network.
You can either change the ip address of the device you are receiving the error from or find the device with the same ip address and change that one.
Alternatively, if you have a router that that has DHCP enabled you can change the properties on your network adapters to obtain the ip address automatically by going to Network Connections, right click on LAN connection and click properties.
May 21, 2010 | Computers & Internet
Dont know ip for my Sharp AR_C270 i just bought
Find out what the gateway setting are on your computer and assign an ip address based on the gateway.
For example if your gateway is 192.168.0.1  then a good ip address would be 192.168.0.XXX.  xxx=available ip address to use.
Your copier does have a DHCP setting that allows the router to assign on automatically for you if the copier is connected to one but you should assign that ip address manually after using DHCP because if the power goes out, it could assign a different one than the previous assignment making the IP port assignments to print with on your computer useless without creating a new port.
Oct 19, 2008 | Sharp AR-C270 Color Copier
Connecting this print server
Without knowing more information, I can't give you exact instructions...however, in order to make the print server truly functional, it needs a dedicated IP address. Look through the settings on the print server interface (GUI) and see if you can assign it a local IP address (192.168.xxx.xxx, depending on your LAN setup).
Once you give it a dedicated IP address, you should be able to route print jobs through it.
Hope this helps - remember to rate :)
Oct 02, 2008 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Siemens 4100
Just consult your ISP provider. they can give you a static ip.
Mar 13, 2008 | Efficient Networks SpeedStream 4100...
I cant open an ip address for an assigned webpage.
There are several private address ranges that may be affecting the operations you are attempting to perform see table
IP Address Ranges Reserved for Private Use
Class Networks A 10.0.0.0 through 10.255.255.255 B 172.16.0.0 through 172.31.0.0 C 192.168.0.0 through 192.168.255.0
All addresses in this range in your network are only directly addressable to machines within your network at most by default. The router to your ISP and the internet as a whole maps these addresses onto the IP address assigned statically or dynamically by your ISP to the WAN side of your router using an address translation (NAT) service. So where you are attempting to connect to this device from may be significant. You may need to review your setup guide to see if it references router configuration requirements to support access to the Web_xpander port from devices not attached to your internal network. If you have multiple internal networks (address ranges and not devices) this could also be an issue.
Secondly -- does the Setup software for the device tell you the IP address assuming it is dynamically assigned. Otherwise how would you know what the address is. Static assignment could resolve that issue however you must understand your network to assign your own address. Given a theoretical network where the router gateway is 192.169.0.1 and the network mask is 255.255.255.0 the valid network addresses are 192.168.1.0 - 192.168.1.255. A router or other device supporting DHCP address assignment reserves another range such as 192.168.0.100 for 50 leases (ending at 192.168.0.149) for dynamic assignment to requesting network adapters. Ignoring the 0 and 255 address this leaves open to the network administrator (you in your home) the possibility of assigning static IP address in the ranges of say 192.168.0.2 - 192.168.0.99 and 192.168.0.150 - 192.168.0.254 or so. You as well as the DHCP server are required to assure that there are no duplicate IP addresses assigned on your network. So statically assigning 192.168.0.100 (which is DHCP assignable in our case) could and would most likely result in duplicate addressing and network problems.
Dec 08, 2007 | Computers & Internet
Cyclades Avocent Acs48 Sac 48-port Console Terminal Server Switch 10/100b-t Logo
101 people viewed this question
Top Cyclades Computers & Internet Experts
David Payne
David Payne
Are you a Cyclades Computer and Internet Expert? Answer questions, earn points and help others
