Question about Frigidaire Dishwashers
My frigidaire dishwasher model fdb641ras1 controle lights dont light and soap despser dosent open but machean runs
  • Official Brand Answer
  • 4,342 Answers
Hi glennjorgens - Try resetting the dishwasher by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and if it proves to be ineffective contact a professional to move forward accurately. Unit could possibly be experiencing a communication issue with the control panel or wiring failure which would need further diagnosing.
Posted on Nov 13, 2012
  • 105 Answers
SOURCE: Have the Kenmore Limited Edition
check the wash arms to see if food has not cloged the holes stopping water getting through
if these are clean the machine may not have enough water entering machine
also check how you stack machine
Posted on Feb 02, 2008
  • 351 Answers
SOURCE: soap door won't open during wash cycle
its either the dispenser or the timer/pcb.
Posted on Mar 02, 2008
SOURCE: soap won't dissolve in dishwasher
I had the same problem and my wife fived it by unsticking a valve to the left side of machine in front lets water in she poped it open and dried soapm came out restarted and now works fine.
Posted on Aug 07, 2009
SOURCE: My Frigidaire dishwasher is leaving soap, a lot of
I scrubbed the screens with a brush and added two cups of white vinegar to the bottom of the washer, then ran it. Cleaned up nicely. I most likely will add a cup of vinegar once a week.
Posted on Sep 16, 2009
SOURCE: Frigidaire Dishwasher Energy Star blinking lights.
Hmmm...don't know why this worked, but it did. When the lights were flashing when I tried to start my Frigidaire dishwasher model#FDB1500LF, nothing would happen...just blinking lights, so I went to the house electrical panel, found the switch for the dishwasher, turned off & on again, and now the dishwasher works.
Go figure.
Posted on Oct 21, 2009
Frigidaire dishwasher fills but then the motor is not running for the wash cycle
Hey Gary, thank you for your inquiry!
From the information you have provided your Frigidaire dishwasher fills with water and then the motor will not run to complete the cycle. This could be an issue within the control panel or motor of the dishwasher. Which lights are flashing on the control panel of the dishwasher? Can you provide me with your model number as well? Once I have that additional information I would be able to assist you. -Matt
Apr 18, 2016 | Frigidaire Dishwashers
Dispenser door will not open
Hey friend, thank you for the post!
I understand that your soap dispenser door will not open on your Frigidaire dishwasher, LGBD2432LW0A. You could possibly be seeing an issue with soap dispenser not getting water into it to release the soap from dispensing. I would check to make sure there are no dishes blocking or obstructing the soap dispenser. You could also remove the soap dispenser to clean it and make sure there is no buildup of any previous detergent remaining that would cause the door to not open. If those steps do not solve the issue it could be a problem with the dispenser and I would recommend having a tech come out to the home to properly diagnose and repair the dishwasher. Hope this is helpful. -Matt
Jul 28, 2014 | Frigidaire Dishwashers
Frigidaire dishwasher leak
run it with no soap. if you get no leaks then cut back on your soap. you may need to run washer a few cycles to get rid of excess soap.
Sep 02, 2012 | Frigidaire Dishwashers
I just bought a brand new dishwasher and the soap dispenser opens but the soap is still in the dispenser clamped up like sand. It doesn't happen every time. The same thing started happening with my old...
Try using the soap tablets instead. The frigidaire units use a small cylinder to actuate
the soap dispenser and if just a little too much soap is used the latch will bind and not
release. Alternatively, make sure the dispenser is only about half to 2/3 full if you need to
use powder detergent. This is a common problem with the frigidaire/ whirlpool/galax/kenmore
models. Hope this is useful.
Apr 04, 2011 | Frigidaire Dishwashers
My frigidaire dishwasher FDB1502RGC4 will not run a cycle. it will fill and drain the water but will not run a wash cycle. all the lights on the control panel lightup when they should. so i dont think it...
having the same problem with mine, just replaced the discharge pump last week because it went out, worked a couple days now this. still have not figured out the problem
Dec 01, 2010 | Frigidaire FDB1502RGC Built-in Dishwasher
The soap holder is opening during the wash cycle but the soap tablet is not dissolving. Any ideas?
Is the water coming on? Is water hot enough? Is washer overloaded, water jets aren't hitting the soap? Maybe try a different brand of soap tablet? Run the dishwasher in "heavy soil" mode which will use hotter water and run for longer?
Nov 20, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
Dishwasher cup won't open
Make sure no dishes have block it from opening. If this is a dial model, then with the door open so you can see the soap cup, turn the dial and see if it opens up. If not replace soap cup.
Oct 01, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidaire dishwasher door squeaks when opened and closed
I had the same problem and this worked like a charm:
http://www.blog.applianceoutletservice.com/2008/12/frigidaire-dishwasher-door-squeaks.html
All you'll have to do is take off the kick plate, actually remove the cords, and lubricate with soap (lower tech than spray silicon, but it's worked so far...)
Aug 22, 2009 | Frigidaire PLD4555RFC Dishwasher
Soap dispenser doesn't open for wash cycle
I noticed you didn't rate out chat and saw that your problem was posted. I'm happy to continue to help you if you encountered problems or were not happy with the solution in your chat session.
Jul 07, 2008 | Frigidaire FDS251RJ Free-standing...
Soap does not seem to dissolve or clean
Probably a sticky dispenser door. Run for a few times with the dispenser open and put a tablet in the cultery basket
Nov 23, 2007 | Frigidaire 24 in. FDB635RF Built-in...
Dishwashers Logo
82 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Robert Roath
Robert Roath
Level 1 Expert
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
