Question about Frigidaire Affinity FAFW3511KB 3.5 Cu. Ft. Electric Front Load Washer - Classic Black
The "washer" turns every now and then but for the must part it just sits there. I can hear the "motor" running as if it is going through different cycles of the wash. The spin cycle does not work because the water is sitting in the washing machine (not draining).. any suggestions?
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
Remove the back access panel. Remove the drain boot between the tub and pump. In that boot is the filter that will need to be cleaned. Also, while the boot is off, reach up into the tub and feel for any blockage. Keep me posted.
Posted on Nov 09, 2012
catriver
  • 878 Answers
SOURCE: Frigidaire front load washer (LTF600ES1) Error E20
holla, Im not showing a E20 code on the tech sheet. There is a E21. Water not draining fast enough. Try holding the start/pause and cancel key together for 3 seconds. The door lock, wash, rinse and final spin leds should light. Any error codes should be displayed when holding those keys. If you see a different error code, post it. If not, I would suspect a clogged pump...Catriver.
Posted on Aug 04, 2007
docjohn174
  • 943 Answers
SOURCE: frigidaire affinity front loading washer won't drain
HI .THANKS FOR YOUR QUESTION. THE PROBLEM IS WITH THE WATER PUMP.REMOVE 2 SCREWS AT BOTTOM OF FRONT PANEL . PUMP ON RIGHT .REMOVE HOSES AND CLEAN OUT THANKS THE APPLIANCE DOC.
Posted on Oct 04, 2008
  • 3 Answers
SOURCE: won't wash
press the pause and stop button at the same time it will give u a code
Posted on Mar 21, 2009
  • 1531 Answers
SOURCE: my frigidaire GLTF2940ES washes but doesnt spin on
replace the door lock mechanism
Posted on Apr 10, 2010
Jahn27
  • 1554 Answers
SOURCE: I have a frigidaire affinity front loader washer
There is an auxiliary switch in the door lock and switch assembly that is activated at the end of the wash cycle for the machine to advance to the spin cycle. This is a safety feature to prevent the door from opening during the spin cycle and the machine will not spin unless the switch is activated. The machine works except advancing to the spin cycle and this signifies that the auxiliary switch cannot be activated and the door lock and switch assembly is faulty. Replaced the door lock and switch assembly (part #131763202) to address the issue.
Disconnect power to the machine. Open the washer door then look for the retaining hoop securing the door seal around the lip of the door opening. Stretch the retainer spring of the door seal retaining hoop then remove it.
Carefully peel off part of the door seal from the lip of the door opening near the door lock and switch assembly. Remove enough of the door seal to gain access to the door lock and switch assembly.
Remove the screws securing the door lock and switch assembly to the front panel. Once the screws are removed, lift the door lock and switch assembly then pull it away from the front panel.
Take the door lock and switch assembly out of the machine. Disconnect the electrical connections then connect it to the new door lock and switch assembly.
Put the new door lock and switch assembly back into position in the front panel and secure it with the securing screws.
Properly put the eased part of the door seal back over the lip of the door opening then secure it with the retaining hoop.
Posted on Jul 13, 2010
My washer stopped mid cycle and wouldnt drain or spin or anything. The error message is "nd". Can I fix it myself? thanks
Hi
ND=-no drain error.
Remove the back panel you will see the pump. Simply remove the pump and remove the obstruction that is keeping it from draining. Check for thongs, baby socks and sometimes hair pins or even screws can obstruct the water pump. There's going to be some water left in the pump and drain hose, so get a large towel ready. Remove screws attaching black piece (motor) to white piece (housing), pull out motor and clean the housing and motor impeller. Reverse steps to assemble it back together. If you don't hear pump running after completing the cleaning, you may need to check the wiring and/or replace main control board located inside the console. If the pump seems to be running but no water is being drained - replace pump.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 06, 2011 | Maytag MAH2400A Front Load Washer
My maytag washer mah-24 have a "nd" msg. which mean "not draining" and now i cannot open the door to take the clothes out. pls. help.
Unlocking the door:
Turn on the washer, but don't start any wash cycles. After a few minutes, the door should unlock itself.
Troubleshooting the "nd" message:
"nd" means "no drain". Empty the (now unlocked) washer and fill the wash tub with just enough water to see a bit of water at the bottom of the tub. Run a drain cycle and check a) if it drains and b) if there are any unusual noises while it is draining. If either event occurs during the drain cycle, the drain pump may have to be repaired/replaced.
Nov 25, 2010 | Maytag MAH2400A Front Load Washer
Someone put some heavy things in it and it stopped mid-cycle. We removed the heavy objects, and then attempted to drain the leftover water by putting it on "rinse and spin." It never really...
The ND error code on a digital Neptune front load washer. The ND code means 'No Drain' and it is probably just something caught in the pump. Sometimes this is a early sign of the pump going out or a control board issue.
Nov 23, 2010 | Maytag Neptune MAH5500B Front Load Washer
I was washing a lad of clothes I went in to check if they were done and there was an "ND" on the screen and when I opened the door it was full of soapy water .... I tried to turn off the machine and...
You likely need the drain pump cleaned. Unplug and pull the washer out. Remove cover in back. The pump is attached to the washer's floor. Pinch off the hose from tub to pump. There's going to be some water left in the pump and drain hose, so get a large towel ready. Remove screws attaching black piece (motor) to white piece (housing), pull out motor and clean the housing and motor impeller. Reverse steps to assemble it back together. If you don't hear pump running after completing the cleanin, you may need to check the wiring and/or replace main control board located inside the console. If the pump seems to be running but no water is being drained - replace pump. for Maytag MAH5500B the part number is 25001052.
Vlad
First Choice Appliance
Aug 19, 2010 | Maytag Neptune MAH5500B Front Load Washer
What does the nd Error Code mean on a Maytag Neptune frontloader??
ND== No Drain.
You likely need the drain pump cleaned. Unplug and pull the washer out. Remove cover in back. The pump is attached to the washer's floor. Pinch off the hose from tub to pump. There's going to be some water left in the pump and drain hose, so get a large towel ready. Remove screws attaching black piece (motor) to white piece (housing), pull out motor and clean the housing and motor impeller. Wear gloves, as it's always a nasty stuff what comes out. ;) Reverse steps to assemble the pump back together. If you don't hear pump running after completing all the cleaning, you may need to check the wiring and/or replace main control board located inside the console. If the pump seems to be running but no water is being drained - replace pump. for Maytag MAH5500B the part number is 25001052.
Vlad
Jun 29, 2010 | Maytag Neptune MAH5500B Front Load Washer
Nd error code what should be next step
Vlad
Apr 25, 2010 | Maytag Neptune MAH5500B Front Load Washer
Code nd on maytag neptune
Vlad
Jan 04, 2010 | Maytag Neptune MAH5500B Front Load Washer
Error code nd after installing new motor
If the drain pump wiring is connected - You likely need the drain pump cleaned. Unplug and pull the washer out. Remove cover in back. The pump is attached to the washer's floor. Pinch off the hose from tub to pump. There's going to be some water left in the pump and drain hose, so get a large towel ready. Remove screws attaching black piece (motor) to white piece (housing), pull out motor and clean the housing and motor impeller. Reverse steps to assemble it back together. If you don't hear pump running after completing the cleanin, you may need to check the wiring and/or replace main control board located inside the console. If the pump seems to be running but no water is being drained - replace pump. for Maytag MAH5500B the part number is 25001052.
Vlad
Nov 20, 2009 | Maytag Neptune MAH5500B Front Load Washer
My washer keeps flashing nd code -wondering if I need a new water pump
Vlad
Jun 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
Wont go to wash
Do you hear any noise, like motor running or anything like that or does it just sit silently?  If it makes noise, it could be a motor coupler issue.  If it sit silently, it may only be a lid switch.  The lid switches do have a habit of breaking, which would allow it to fill, but not run.  No to expensive, and a fairly easy job to do.  Let me know further info or if you need any help or info.
Jim
Sep 21, 2007 | Roper RAS8445KQ Top Load Washer
Frigidaire Affinity FAFW3511KB 3.5 Cu. Ft. Electric Front Load Washer - Classic Black Logo
27 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
