Question about Car Audio & Video
Why is there a ringing sound coming from my amp when I hook up the remote wire to my amp
    Master:
  • 689 Answers
If it is makeing a ringing sound there is a problem with it, I have install car audio equipment for over 40 years, End i have never heard of a amp doing that, But any thing is possible the way some people hook them up that don,t no what there doing.
Posted on Nov 08, 2012
2 Suggested Answers
raberd14
  • 60 Answers
SOURCE: Amp will not come on ,no light
Yes!!!!!!!!!! Your remote wire is what tells your amplifier to turn on and off it won't work without it. Assuming your stereo headunit is an after market unit it has the correct wire for this. what you have to do is pull out you headunit, and in the back of the headunit where all the wires plug into your unit there is blue wire with a white stripe. this is the remote turn on wire. connect a wire to that blue n white wire and run it back to your amp, insert it into to the spot marked remote. turn your head unit on and your amp will power up... if you have all the rca cables hooked up your amp should be ready to go.... btw good choice on the amp, kenwood is the way to go!
Posted on Aug 31, 2009
Boss car amplifier stays on with remote wire removed?
sounds to me like your acc. wire is hooked to consistent power instead of power with ignition on only and off with key off. or radio on or off .
May 03, 2017 | Car Audio & Video
Hooked up my amp it has power but power light won't come on won't power up front speakers work and have sound but it doesn't move to back
Make sure the remote wire is hooked up. You can run a small wire from the power terminal to the remote terminal. If it powers up, then you have a remote wire problem. You can run a remote wire from the blue power antennae wire of the deck.
Apr 02, 2012 | 1991 Ford F250
I have a jl 500/1 amp hooked up in my car and the power light comes on for about 5 seconds then turns off. no sound out of the subs. it is hooked up to a factory deck through a high to low level converter....
hook up the remote wire ( or make sure its hooked up good) check your ground! ground wire not big enough awg wire and put on bare metal not more than 1 foot away from amp. bad ground will cause this.
Sep 12, 2011 | Jl Audio 500/1 Car Audio Amplifier
I just bought a hifonics amp the brz2100.1D and when i tryed to hook it up every thing is correct as far as the wireing compared to the manual and the blue lights come on power light is on but its not...
MAKE SURE YOUR GROUND WIRE IS GROUNDED GOOD,,AND IT IS IMPORTENT TO HAVE YOUR REMOTE WIRE HOOKED UP. IT WILL BE A BLUE WIRE,,FIND THE HOT WIRE FOR YOUR TAIL LIGHTS AND HOOK IT THERE THEN WHEN YOU TURN YOUR CAR ON THE AMP WILL ALSO COME ON.THAT SHOULD STOP ALL THE NOISE AND POWER YOU UP.
Jul 15, 2011 | Hifonics BRZ21001D Car Amp
I have checked all connections to my amp battery,head unit,remote or trigger wire,fuses,power cable,rca leads,ground wire,amp has a green led light on it indicating if it works ok,red if it`s not,light...
Your amp could be in protection mode! Sometimes turning up to high or wires touching will put in protection mode! It will have to be unplugged for a day or two to drain all power out of the memory. Leave accessorie/ignition wire hooked up, just not power and ground wiring. It should reset itself.
Jan 22, 2010 | Lightning Audio B4.250.2 Car Amp
No out put sound
Check all fuses on the amp first. If the fuses are good then make sure the remote wire is hooked up. If you dont wanna run the remote wire from the amp to the stereo then all you need to do is run a wire from the remote on the amp to the power on the amp. if the remote is not hooked up then you will get NO SOUND
Dec 31, 2009 | MTX Thunder 1501D Car Audio Amplifier
Amp powers on but sub does not come on
I would double-check your RCA's on the amplifier. You should hear a thud if you unplug them. If not they are either not hooked up or defective.
Feb 07, 2009 | Sony XM-2150GSX Car Audio Amplifier
Cd player plays, but no sound comes out of speakers.
first off the amp gets power straight from the battery. the amp is used to power the subs. the subs are suppose to be connected to the amp only( never the speakers).
for the second part you mostlikely killed the wires. you should get some one to look at it and check the wires. thee speakers might need to be re-wired
Jan 31, 2009 | Kenwood KDC-MP238 CD Player
Look at the enwood. I bet you have the remote wire hooked to the blue wire insted of the blue/white wire. The blue wire goes dad when you play a cd as it is for a power antenna. The blue/white wire is your amp turn on.
Now, if you do not have a blue/whie and only blue, then obviously that circuit in the radio is bad in whch case your only other option s are either connecting it to an accesory fuse or using a toggle switch connected to power.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 27, 2009 | Kenwood KDC-MP228 CD Player
Car Audio & Video Logo
19 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
