Question about Dishwashers
KitchenAid KUDI01IBS6 Dishwasher stopped working.
It had begun to get noisier, a metallic gnashing that sounded like an unhappy motor with bad bearings. Then there was a 'Pop! like a belt breaking and it stopped altogether. In the recent past I've had to replace the control panel, and two thermal fuses.
  • 1314 Answers
SOURCE: Kitchenaid Dishwasher Control Panel lights - some don't light up
about the only thing to try would be to remove the inner door panel to get to the control bd then you will see a mylar ribbon looks like a fat piece of scotch tape pull up on the plastic connector that holds it in and pull the ribbon out then get a clean pencil eraser and gently clean the ribbon and put it back in dont forget to push the locking tab back down then try it again and let me know
Posted on Feb 12, 2008
aborcass
  • 2651 Answers
SOURCE: Hidden control panel not accessible on dishwasher
no thats correct installeation of machine, its meant to be a "hidden" control. simply open the door, choose your options, press start and close door.
Posted on Feb 28, 2008
SOURCE: KUDS25SHWH1 Kitchenaid Dishwasher Control Panel Only CANCEL light on
I bought a control board for $127.00 figuring that was the problem but it wasn't. I called an appliance guy who came out and said its the touchpad that needs to be replaced. I ordered the touchpad ($325) since I already have to much invested in this dishwasher. I paid $1200 for it 8 years ago and its really a great dishwasher. My appliance confirmed that if it was the fuse-ling that you would not have any lights on.
Posted on Sep 03, 2008
  • 12 Answers
The problem is the control panel. You may have to shut the power off for a few seconds to reset the control board, then check to see if it works. If not, the control board has a break in the wiring or the keypad is no good.
Posted on May 13, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Kitchenaid Dishwasher has starting making a real loud noise
Hi Andy and welcome to FixYa. I am Kelly. That loud noise your hearing is the motor bearings. If you were to remove the lower kick panel you will prbably find signs of a slow leak of water has been trickling through the motor and you will see a water spot under the motor pump assembly.
You were correct in your assumption that it was bearings. What happens is the motor shaft ceramic seal starts leaking long before the home owner even notices it. Then the water gets into the motor and corrosion starts to build up. As the motor turns the bearing starts to spal as a result of the corrosion and you hear the loud noises.
The only fix for this sadly to say is a complete motor impeller assembly replacement. If your model number is the one associated with this post / question: KUDI01FLSS then there is one more digit after the last "S" that being one of the following numbers 0, 1, 2, 3, 4, 5 or 6.
The motor and impeller for your dishwasher Item 10 or 18 can be found here and is listed at $138.44:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5164895&diagram_id=907556#d907556
The seal that has failed is item 23 of the same link. Changing the seal at this point will not stop the noise.
Thanks for using FixYa.
Kelly
Posted on Apr 23, 2010
It fills up with water then it stops working and you can here a humming soud for about 10 seconds and after it stops
Sounds like your motor is trying to run but can't. Check inside pump for anything blocking impeller. Check if wires are attached to motors capacitor. If all looks good the motor or capacitor are bad.
Nov 17, 2011 | KitchenAid Dishwashers
Dishwasher fills with water then hums
Hello & Welcome to FixYa
When the dishwasher fills then it means that the control and the water inlet valve are fine, hum sound itself indicates that the motor is bad and needs replacement. If you hear a hum sound from the bottom of the unit then it is the motor that is bad and if the hum comes from the control then it is the timer that is bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Dec 11, 2010 | KitchenAid KUDS50FVSS Builtin Dishwasher
Our Kitchenaide KUDT03FTSS2 dishwasher is not cleaning the dishes like it did when it was new. It doesn't appear to dry the interior and leaves gunk inside, and is noisier than it was when we purchased...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
p[''p[
Oct 28, 2010 | KitchenAid Architect® KUDT03FT 24 in...
My KitchenAid Superba (whisper quiet ultima) started to leak out the front when it is running. Is this an easy repair or should we think of replacing the dishwasher? BTW - we love this dishwasher!
Hello. If the unit is over ten years old, I advise against repair. But if you do wish to consider repair, here are the things to look at
Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly. The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the: Lower rack Spray arm Spray arm support Wash/drain impellers Then pry the seal out of its housing and replace it. Door gasket or seal Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak. Water-inlet valve The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary. The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve. Hoses Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Mar 18, 2010 | KitchenAid Dishwashers
GE Dishwasher not working...
Sounds like you have a one of four possible issues. More info to diagnose would be helpful. (age, which mid cycle) If the motor runs when you turn the timer dial than it is a belt/motor pump issue. If the motor does not run than a bad motor start switch or the water level switch. More than likely the motor/pump assembly as this is usually the problem on these models. If newer check with whirlpool the manufacturer to see if it is covered by warranty.
Nov 06, 2008 | KitchenAid 24 in. KUDI01TJ - Multiple...
Kitchenaid dishwasher
Motor bad. If you are getting power to the motor then the motor is bad.
Mar 31, 2008 | KitchenAid 24 in. KUDS25 Built-in...
Kitchenaid dishwasher motor removal
This motor comes as a module. The whole plastic assembly its in is part of the module. It comes out with 3 slide out releases around edge of module underneath.
Sep 15, 2007 | KitchenAid 24 in. KUDS02FRSS Stainless...
Dishwashers Logo
22 people viewed this question
Top Dishwashers Experts
