Question about Kenwood Car Audio & Video
Red Triangle light off?
My kenwood Kac-9105D 2 channel 1800watt amp was working fine the night befor. but i took my system out of my car to clean my car up real good and to put new back seats in. Well after i was done doing that. and hooked everything back up and turned my car on to make sure it worked. the red triangle light that is usually on. came on real quick then straight off leaving the blue line light under it on still. Would this be a wiring issue? i was told it was. but i couldnt find the problem. PLEASE HELP!
  • Chandler Cooper Nov 08, 2012
    @hoyzee1 I Checked the fuses on the amp. there fine. and to even make sure it wasnt the fuses. i replaced them with brand new ones (30s) i think it is my remote wire leading to my CD player. cause when i have it just hooked up to the remote conection in the amp, it does nothing. but i jumped it from the remote to power and the redlight comes on for about 3 seconds then as soon as the music starts playing it turns off leaving the blue line light on though. but now i unhooked it and redone the wiring on the amp. and the remote wire didnt work again so i jumped it. now the red light comes on real quick and goes back off again leaving the blue line light on.
    @Larry Tezekjian it cant be the subs cause i just bought the subwoofers.. ALSO the amp doesnt move arround non. i had it mounted to the box. i have also unplugged the subwoofers to see if anything changed. and it does the same thing. (AMP IS ABOUT A MONTH OLD)
    Master:
  • 689 Answers
I have the same amp in my car, If it is only a month old there is a internal problem with it, It should stay on when you used a jumper wire, I installed car audio for over 40 years before i retired, End was allso Am a certified electronic (Tech) PS,One thing it is not a 2 channel amp, people mistake it for a 2 channel amp because of the for speaker terminals on them, It is a mono (Bloc) Amp ,End where people go wrong on wireing them up is buy , Having each sub hooh up seperately to it, Instead of use just one of the negative end positive terminal on it , .I no the instruction for the wireing on it are confuseing, That can cause it to shot down. Allso if you have dual voice coil subs end there not wired up properly will cause it to shot down,
Posted on Nov 08, 2012
    tbh. i new it was a mono but for some reason i keep thinking its 2 channel cause of speaker terminals. it cant be internal cause i just hooked it up to a friends car and it worked fine -_-. i think its my fuse on my power wire from battery.
sumthin
  • 71 Answers
SOURCE: Kenwood KAC-9104D
Circuit City ? I'll keep that opinion to myself.
If all is properly hooked up, Check the ground wire for the amp.
Give it a tug where it is connected to the car chassis, NOT the amp,
if it moves or comes loose thats easy to fix, scrape the paint off the grounding point use a high quality ring terminal and a oversize screw with a star locknut. Also check the wiring in the box.
Subs and boxes are quite heavy. And if it's banging around, I hope you have it in a trunk, they are very lethal projectiles in a hatchback should you have a accident.
My second thought is that you may have dislocated a component , solder joint, or cracked the PC board,
When in doubt see a installer. Good luck Sumthin
Sumthin
Posted on Jun 11, 2008
  • 149 Answers
SOURCE: power amp wont power up
Check the fuses-should be a pair of 30 amps on the side. use a paper clip and jump power from the power+ to the remote+ and see if that lights it up-if it does than your remote lead isnt giving it juice-
Posted on May 12, 2009
LVT7857
  • 116 Answers
SOURCE: Kenwood KAC-8401 light goes from blue to red when turned on
Either the amp is ad or the sub got shorted? You can check itby disconnecting the Sub and seeing if the amp comes on blue then. If yes, then the sub is shorted. If no, then the amp is shorted. Also chck the voltage AT THE AMP. Make sure that it is above 12 Volts.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Posted on Jan 28, 2009
demonsm
  • 253 Answers
SOURCE: Have a Kenwood KAC-9104D the red triangle is flashing
maybe when hook up something sorted and blew the sub side .I have seen it happen
Posted on Nov 27, 2009
  • 66 Answers
SOURCE: I have a Kenwood KAC-9104D and it was working fine
A ground wire may have come loose or your subs may be blown.
Posted on Apr 09, 2010
Kenwoood kac-7202 redlight/no output
you blew the output Ic's (amps one or more ) you can fix this by replacing the output IC's
Jan 29, 2014 | Kenwood KAC-7202 Car Audio Amplifier
No sound from my subs
it should have a red light on if it is in protection mode. If it does not have the red light then buy a new amp and check all you wiring
Nov 22, 2013 | Kenwood KAC-9105D 1800W Max Class D 1 Ch...
Kenwood kac-9105D amp
Tipical for that amp.Did you buy it used?
Oct 27, 2012 | Kenwood KAC9105D Car Amp
How to bridge a kenwood kac-9105d
Are you referring to something like this, using two different amps? It is a mono amp, meaning there's one amp in the box.
"KAC-9105D also has a Dual Mono Drive connection that allows you to strap two KAC-9105D amps together to power a single subwoofer."Quoted fromhttp://www.kenwoodusa.com/Car_Entertainment/Amplifiers/KAC-9105D
Here's a link to a page out of the Yamaha Sound Reinforcement book. the top shows a stereo amp (1 box, two different amps inside) hooked up to drive two different speakers, which is known as 'stereo' mode.It then shows the two amps hooked to the opposite sides of the same speaker, which is known as 'bridge' mode.http://books57.net/ampOuts.gif
Any help?
Feb 24, 2012 | Kenwood Car Audio & Video
I have a Kenwood KAC-9105D amp. It is brand new and worked for about 20 minutes while I was driving and it hasn't worked since. When I turn my car on, the blue and red LEDs on the amp both come on for a...
First of all, how are your subs wired to the amp. Make sure your amp is not bridged or you'll fry it, it only has one channel. If that doesn't work you probably already fried your amp.
Oct 09, 2010 | Kenwood KAC9105D Car Amp
Power amp wont power up
Apr 06, 2009 | Kenwood KAC-9152D Car Audio Amplifier
How to wire kenwood amp to kicker cvr 12"
How you wire it depends on how hard you want drive your amp. If your woofer runs 4ohm per coil I would wile it in series (amp +to sub +1 sub -1to sub +2 amp - to sub -2) then run it for a week and see if it has enough power. the lower your Impedance (the resistance load on the amp) the harder your amp works and more THD (noise) is produced. (Dclass amps aren't know for being clean to begin with) configured like this your amp will see 8ohms and sound the clean east. if this turns out to be not enough power wire it in parallel and double the output. wire amp + to sub +1 and +2 then amp - to sub -1 and -2.
A word to the wise... start with your volume very low and work up slowly most speakers will puk up the voice coil before the amp starts to get warmed up. you would hate to have to buy a new sub.
Have fun
Rob
Dec 10, 2008 | Kicker CVR12 Car Subwoofer
Car Audio & Video Logo
381 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
