Question about LG LFD22860 Stainless Steel Bottom Freezer French Door Refrigerator
Lg frost free fridge freezer gr-399sq
Hello, ive had this frdge freezer about 3 years, its recently started getting a build up of ice on the freezer floor. i thing its comming from a small hole inside the freezer on the wall dripping down the back. how can i stop this? can anyone help?
  • douglas Jan 21, 2009
    i have a gr-349sqf , same problem with build-up of ice on freezer floor which has to be removed every 2 or 3 weeks , would appreciate some help on this one
  • rayburke72 Feb 21, 2009
    thank you, it works perfectly now.
On the back wall inside the freezer unscrew the white panel and then remove the panel behind this . you should now see a tray that runs the width of the freezer with a driphole on the left-hand side which will probably be frozen with ice , chip away whatever is possible and then put boiling water on the driphole and once this is clear you should find the problem sorted , 1 other option is to turn the fridge/freezer off for several days and this will allow the ice build-up to thaw thus resolving the problem
Posted on Jan 30, 2009
I have a beko frost free fridge freezer its only 18 months old and Ive got a build up of ice in the fridge. all my food is getting frozen and Ive got my temp dial down to min .cant understand what cou
Is the door seal working correctly? If the door has become distorted slightly it might be letting in moisture via a gap in the door seal which will result in the build up in ice.
If you can see ice build up leading from the door area, this will give you a clue to where the seal may be faulty. Check that the door is squared up to the freezer with a spirit level and if required gently bend the door back into place by holding the corner with your feet and adjust from the other corner.
Oct 07, 2014 | Beko CDA670FS 280 litre Frost Free Fridge...
Ice build up in LG frost free american freezer
You have a problem with your auto defrost system or someone did not get door shut all the way
Jul 14, 2014 | LG Refrigerators
We have a lg gr-s592gt and we noticed the frezer is working fine but the fridge wasnt cold. i noticed that the two fans that controller the temp in the fridge arnt working but everything seems fine , this...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Ice build up and stops the fans...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Sep 11, 2010 | Refrigerators
LG GR-349R bottom mount freezer gets heavy ice build up in 3-4 days under lower drawer in freezer. L side of fridge near where fridge and freezer doors meet is very warm to touch.
Find the drain tube in the back and check it for a frozen state. If it si,use a hair dryer to thaw it. If it does it again, you have a defrost problem
Jan 10, 2010 | LG Refrigerators
Frost-free fridge-freezer; internal floor icing up
drain plug and or line probably plugged should be clear if ice was problem in between the casing shouldnt be a problem let unit run normal and check temp the amount of high humidity and usage [open and closing of doors] has caused a lot of frost free and regular units to frost and or ice up
Sep 29, 2009 | Freezers
Bosch Frost Free Frdge Freezer Icing Up
Switch off fridge. Put a pedistal fan in front blowing into the cabinet and leave until all ice has defrosted. Locate the drain hole in the back of the freezer compartment, try to defrost ice which blockes up about the first inch or two of this pipe. If water does not run through you need to force it through with a turkey baster. This should sort your problem. ratemeplease
Mar 12, 2009 | Freezers
LG frost free fridge freezer GR-359sq
defrost drain is blocked - probably with ice. take the back panel off inside the freezer and melt the ice off with a hairdryer then follow up with hot water till it flows away freely. this takes some patience. if fault reoccurs then get back to me
Aug 27, 2008 | Freezers
Back of Fridge icing up
If the fan is running you more than likely have a defrost problem.
look at the back wall of the freezer section if it is frosted up. it's not defrosting.
There three components in this system. The defrost heater, the defrost termination stat., and the defrost timer. Newer refrigerators do not have a timer per say it is build into a electronic board usually mounted on the back of the refrigerator under a metal plate. The termination stat is the cheapest part @ $ 25.00. The heater should run @ 50.00 to 70.00. The board could be as much as 200.00 or more. If the refrigerator is over 10 years old you may wish to look into getting a replacement. Appliances are designed to start failing after 10 years old.
My opinion.
If you unplug the refrigerator let it defrost then plug it back in. it will work properly about 3 days before it frosts back up.
May 17, 2008 | Miele KFN8762SDED Bottom Freezer...
Lg electro cool fridge
hi mine was doing the same we recently movedhouse you need to turn the legs in front underneath so the fridge freezer is slanting so that when you open the door it will shut on its own now i have no water or ice build up on the bottom hope this helps.
Apr 08, 2008 | LG Refrigerators
LG LFD22860 Stainless Steel Bottom Freezer French Door Refrigerator Logo
1,392 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
