Question about Oki Electric Industry C8800 Printer
Just changed all 4 toner cartridges on Oki c8800, now colors are not aligning. all drums have been replaced recently. how do i fix alignment?
3 Suggested Answers
leroyal
  • 2120 Answers
SOURCE: OKI 3300 Image Drum Problem
Did you remove the plastic tape from the new cartridge?
Posted on Feb 16, 2009
don_farr
  • 1011 Answers
SOURCE: REPLACED OKI C33OO'S CYAN TONER CARTRIDGE AND
Are you using a third party toner cartridge or a refilled cartridge?
If you are, DON'T!
Don
Posted on Jan 29, 2010
Oki c5200 alignment
often a drum unit will go bad causing misalignment of just one color. print the demo page and that will help you diagnose what one of the 4 colors is off and replace only that one drum unit
Jul 01, 2014 | OKI C5200 Color Laser Printer
Printing alignment soloution
I have seen this problem before a number of times - the usual culprit is the Black toner/drum cartridge I would first ask if you have recently changed this and if so would suggest you replace again with a new OEM unit from HP and NOT a 3rd Party ReManufactured unit. the problem lies with Very stiff toner units adding drag to the motor servos driving the toner unit,
if replacing the black toner has not cured the error then My next move would be to replace EACH consumable unit until the error is cleared
I have never Yet had to replace an internal component for this error, just a toner or Transfer belt has been the culprit. The fuser/Fixing unit is not likely to have an effect on this fault.
Jan 25, 2014 | HP LaserJet 4650 Color Printer
541: M toner sensor error - this is the message I'm getting. I've replace the toner that does not work. How do I fix the toner sensor?
As the toner cartridge sits in the drum unit, the toner sensor outputs signal to drum unit which in turn conveys it to the printer via electrical contacts.
Try cleaning the contacts that are located on both sides of the corresponding drum unit, and also the contacts protruding from the sides of the drum socket inside the printer. Also reseat the toner in the drum.
If this doesn't solve the problem, try swapping two drum units - if the error now moves to the other color, than there's something wrong with the toner cartridge or the drum, and you have to find out if it's a contact problem between the toner and the drum, or perhaps the toner cartridge is defective - happened to me once.
If the error doesn't move to the other color, it means that something's wrong with the printer contacts - either they are dirty or dead, because of static electricity or something, and the printer needs servicing.
Jul 31, 2009 | OKI C5500n Printer
I have Oki B4350 printer. The print on both edges
Depending on the age of the model, it could be a couple of things. ***Never touch the drum or expose it to bright light*** The drum unit is bad. It's the shiny brightly-colored large roller in the center of the machine. On most recent smaller machines like this on it's integrated into the toner cartridge. Check it out. If it has toner build up on the ends, it's bad. or The corona wires need cleaning. Some machines have a small slide that moves from one side of the printer to the other which cleans the hidden corona wires. It's usually brightly colored .
Jun 03, 2009 | OKI B4350 Laser Printer
OKI C3400 printer keeps saying
Okay, I had the same problem with my C3300. I phoned the people i purchased from and this is what fixed it for me:
looking directly at the printer:
-open printer
-remove drum in question (the drum is what houses the toner cartridge) in my printer it is black.
-look on the right side of the drum & there is a little (approx 5mm x 5mm) hole that has a little panel that opens- push this up to open it.
-replace drum close the top and try printing.
I had to do this 2 times before it worked, but it worked.
Jan 19, 2009 | OKI C5100n Laser Printer
OKI Toner
Have very good experience with Uninet Imaging toner for this model. So replace the drum units and try this one. It also have wax particles in its structure. But wax lubricates fuser, not drums...
Jan 14, 2009 | OKI C9300 Led Printer
OKI C5100 alignment issues, I think
FROM YOUR USEWR MANUAL>>>>>>>
In colour menu
AJUST REGISTRATION, press EXECUTE
Performs automatic colour registration
adjustment. Normally this is done on power
on and when the top cover is opened and
then closed. This process accurately aligns
the cyan, magenta and yellow images to the
black image.
Use oki drums and toners, clean led heads
Dec 19, 2008 | OKI C5100n Laser Printer
Oki c5100n printing yellow color offset
What is the stats % of drums if low under 50% change them, soon as you add non Gen you throw a spanner in any attempt to fault find, fix is possible toner more than likely drum/drums, do a print of each colour and change drums as indicated by failure in its colour to print, check transport belt is OK and led heads are clean
Nov 13, 2007 | OKI C5100n Laser Printer
Oki Electric Industry C8800 Printer Logo
54 people viewed this question
Top Oki Electric Industry Office Equipment & Supplies Experts
Tony
Roger Binsfeld
Victorman
Victorman
Are you an Oki Electric Industry Office Equipment and Supply Expert? Answer questions, earn points and help others
