Question about GE Washing Machines
Have a GE Profile washer, approx 5 years old, started to
It has started to sling a little grease into the wash. I cannot see or feel where it is comming from. Any tips would be helpful
  • jetfixr May 11, 2010
    It sounds like your tub bearings are starting to leak. I just rebuilt mine. It appears that once the main seal fails, water migrates into the bearing cavity and I guess sometimes some grease leaks out. I also found that the original bearings were a -2Z which is a shielded bearing not sealed. The sealed bearings are a -2RS. Anyway, if your washer is getting louder on the spin cycle, the bearings are going bad or will be if the greas is leaking out. Mine was a frigidaire, but I think they are for the most part they all have the same configuration.
    Hope this helps.
  • 115 Answers
Actually the black grease looking stuff usually comes from a buildup of liquid fabric softner under the agitator get some stuff called washer magic and follow the directions on it that will clean everything up please rate
Posted on Jan 06, 2009
Ge profile washer 12 years old, won't start but when put on rinse cycle it works
http://appliancejunk.com/ge/dishwasher/31-9137.pdf
Ok, this can be a few things that show this symptom, you will have to troubleshoot and isolate your problem by using the troubleshooting steps in the manual. If you need parts, they are readily available online, simply Google, for what you need, all numbers etc, are in the manual.
Jun 05, 2010 | GE Profile WPRE6100G Top Load Washer
GE WHDSR209D2WW has black grease in the wash water
The grease comes from the transmission. Part 320 on this diagram. You can see from the price it may be better to but a new washer.
depends on weather or not you can do it yourself.
Feb 11, 2010 | GE Profile Prodigy WPSE4200A
GE Profile wont spin,why?
Hello, your problem is going to be with the lids switch, in this machine it is going to be a magnetic contact. You can confirm this my pulling the front panel off and accessing the wiring to the lids switch, If you have electrical knowledge bypass the lid switch using a wire nut and run the machine. If all is ok make sure you replace the lid switch since it is there for a reason. If you have any other questions or concerns please feel free to comment again. Good Luck!!! Thanks for using Fix-ya. A high rating would be appreciated for your free question :)
Jul 26, 2009 | GE Profile WPRE6100G Top Load Washer
Black spots floating on top of water
the top seal in the transmission is bad causing oil to get inside you will need to replace the trans but it will be cheaper to buy a new washer
Jul 12, 2009 | GE Profile 3.5 Cu. Ft. King-Size Capacity...
GE Profile Washing Machine wont fill with water top loader
disconnect water lines from washer and check to see if sedement from water plugged up little screen filters
Jun 11, 2009 | GE Profile WPRE6100G Top Load Washer
GE Profile washer will not drain. (DOES SPIN)
take the front off the washer take the two hoses off the pump youll probably find where its stopped up
Apr 24, 2009 | GE Profile WPRE6100G Top Load Washer
Grease on clothes?
This is a 50 year old problem on washers.  All brands.  You just got lucky on this one.
If you buy a new one, consider a unit built by Whirlpool.  They also make Kenmore and others.
Nov 12, 2008 | GE WSXH208A Front Load Washer
GE Profile Model WPSR3100W0WW
normally there is no grease required as they are closed bearings.
Jun 03, 2008 | GE Profile WPRE6100G Top Load Washer
HELP GREASE RUINING CLOTHES IN WASHER
over 5 years or cost over 250?
 throw it away, and get a Whirlpool
Oct 21, 2007 | GE Profile Prodigy WPSE4200A
Washing Machines Logo
157 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
