Question about Canon 2530 ImageRunner Copier
Set the Canon ir 2530 to factory defaults - Canon 2530 ImageRunner Copier
SOURCE: Canon ScanGear Ir - how to set defaults?
ScanGear won't run under Vista. The scanner works with other programs. (Twain works) ScanGear fails and Vista closes it.
Don
quantm@localnet.com
Posted on Jan 26, 2008
  • 168 Answers
SOURCE: Factory Defaults IR C3200
you need turn rui on if you do not have a c1 rip it is under add function then system setting then network setting if you are using the c1 you need to do it under the rip set up
Posted on Dec 27, 2008
  • 118 Answers
SOURCE: canon imagerunner Ir c3200 total reset
On the Control panel press asterisk (with the head) next to ? mark the press the ID SYSTEM SETTING>NETWORK SETTING>TCP IP .you can reset or erase the IP Addres or if you know to go to service program :COPIER>FUNCTION>CLEAR> MN-CON then switch OFF and ON the machine it will restart and then the machine will asked to switch ON/OFF theunit then all are reset
Posted on Jun 22, 2009
mdaslam46448
  • 31 Answers
SOURCE: How do restore my Canon IR C3200 to factory
Posted on Oct 14, 2010
spinal
  • 287 Answers
SOURCE: I need to set a Canon IR 3025 so that the Scan
Hi fiona,
I am glad to help you.Press the "ADDITIONAL FUNCTIONS" button located to the right of the display. Select "communication settings". Now press "TX SETTINGS".Now press "common settings".Now press "Edit standard send settings". You will now see a screen that allows you to set the DPI value and file format.You will have drop down menus for each that allow you to change these settings. Once you have selected your preferred settings press the "OK" button located at the lower right. I have "FIXEDYA". :-) Rememeber, you can change these settings of a case per case basis on the main send srceen. Be well and smile when you get a chance.Please let "fixya" know I have helped. Thanx
Posted on Jan 24, 2011
How do i get the factory default setting for canon ir 6800?
Go to service and and clear the error
Asterisk * press
then press 2 & 8(Two buttons single time)
Again press Asterisk *
COPIER>FUNCTION>CLEAR>ERR
Then press ok an off the machine wait 1 minute and on the machine..
Jun 23, 2016 | Canon Office Equipment & Supplies
Error 0099 canon image runner
0099 : SMART PANEL Canon-IR-2520-2525-2530: A memory communication reservation has been cancelled.
Looks like it was answered here for a different printer -
http://www.fixya.com/support/t7156967-canon_ir2020i_dasnt_print_error_code
Sep 09, 2014 | Canon imageRUNNER 2525 AllInOne Laser...
Error code E000001 in canon ir 2530
E000-0001: Fixing temperature abnormal rise
Description: The temperature detected by the main thermistor does not rise to the specified value during startup control.
Remedy:
- Go through the following to clear the error:
CLEAR > ENGIN > ERRCLR; and then turn OFF and then ON the power.
- Check connection of the Connectors (Thermistor Connector and AC Connector).
- Replace the Fixing Main Thermistor (Film Unit).
- Replace the Fixing Assembly.
- Replace the DC Controller PCB (PCB4).
See Service Manual page 173 (7-3):
Canon imageRUNNER 2530 Service Manual Page 173
Dec 10, 2013 | Canon 2530 ImageRunner Copier
Canon ir c3220 error code E602-0003
This is just a shot in the dark, but if there is no "reset" button, you might try unplugging it for a couple of minutes and it should reset itself to factory default settings. You will loose any settings and any work in progress. Just a guess. If you have an owner's manual, I would check there to find how to solve the problem. You also might want to enter the "menu" if there is one, and discover whether you can solve the problem there. If you don't have an owner's manual, you might be able to find one at the printer manufacturer's website in the support section. Good luck.
Nov 11, 2013 | Canon Office Equipment & Supplies
Ir password
Try a factory reset. The factory default user and password is 7654321.
Sep 25, 2013 | Canon imageRUNNER C2550 Color Copier
RESET IR 2018 AS FACTORY DEFAULT
Additional Functions button>ID System Settings>Initilize All Data Setting tab. This may take a while to process do not power down during this time.
Sep 02, 2010 | Canon iR 2016i Black and White Copier
Canon IR3570 Factory reset
how to reset cannon ir 3570 photo copier
Apr 07, 2010 | Canon Office Equipment & Supplies
When i start canon photocopier ir-2016j , its shows error download standby
Your machine appears to think it's waiting for a file (like an update). Somehow it was put into download mode (only a canon tech would know how to). You need to have a canon technician to either reset the machine or if there is a legitimate problem put it into factory default.
It may be a hard drive error from my experience.
Nov 25, 2009 | Canon iR 2016i Black and White Copier
Dec 23, 2008 | Canon imageRUNNER C3200 Copier
Canon 2530 ImageRunner Copier Logo
142 people viewed this question
old marine
old marine
