Question about Lexmark Wheelwriter 2500 Typewriter
I need a 1353502 printwheel - Lexmark Wheelwriter 2500 Typewriter
  • Lexmark Master
  • 3,594 Answers
We have available a good used Prestiege Elite #1353502 IBM printwheel for 29.95 or a new one for 49.95.
DickyO
Cleveland Business Machines
2419 St. Clair Ave.
Cleveland, Ohio 44114
216-241-0027
Posted on Jan 12, 2009
    Scholar:
  • 91 Answers
Which manufacturer?
You can also buy online.
Posted on Jan 05, 2009
How do I change the size/font of the letters? Bold and underline too?
To change font and pitch, you need to buy a different printwheel. machines came with a prestige elite 12 printwheel. Prestige elite has small letters and 12 puts 12 charactors per inch. Letter gothic is larger size letters. Google search for ibm wheelwriter printwheel, also called a daisy wheel.
Mar 03, 2016 | IBM Wheelwriter 30 Series II Typewriter
How to change pitch on wheelwriter
The printwheel determines what the pitch is on the wheelwriters. A 10 pitch printwheel will only print in 10 pitch and a 12 pitch printwheel will only print in 12 pitch. Same with a 15 pitch or a PS (proportional spacing) printwheel.
Apr 03, 2014 | Lexmark Wheelwriter 3000 Typewriter
Letters printing out of order
Printwheel in wrong. release the printwheel, make sure the pin is aligned with the slot on the hub and snap it back in. The printwheel should spin, then home out to the left margin, the it should be ok. Checkd to make sure no pedals on the printwheel are bent.
Mar 07, 2011 | Office Equipment & Supplies
I am having a problem with the sx-4000 typewriter. Every key that I hit on the typewriter is not typing correctly. What do I need to do to fix this?
Printwheel in wrong. release the printwheel, make sure the pin is aligned with the slot on the hub and snap it back in. The printwheel should spin, then home out to the left margin, then it should be ok. If not try it again.Check to make sure no pedals on the printwheel are bent.
Hopes this helps!
Mar 02, 2011 | Brother SX-4000 Typewriter
I am getting an error 215 on my typewriter at the office and dont have the manuel. Do you have any suggestions? I need to use this right away. thank you
215 Error is the printwheel. Remove the printwheel. look in the PW area for bits of paper or other debris, if you have an air source blow out this area, reinstall PW and test. If the problem persists you will need a printwheel sensor.
DickyO
Nov 04, 2010 | IBM Wheelwriter 30 Typewriter
The flywheel from my brother ml300 typwriter came off and i don't know how to put it back on
I assume by "flywheel", you are referring to the "printwheel" which is removable from the typewriter by unlatching the print hammer mechanism by pulling the black lever on the right side of the print hammer towards the front of the machine. To install the printwheel, drop the printwheel in its cartridge with the letters facing the paper, then push the print hammer assembly towards the paper to the latched position. Turn on machine, and the printwheel will spin and "home". If printwheel homing is not correct, repeat above procedure with slightly more pressure when latching the printwheel. (The printwheel must latch on to its drive spindle securely). Good Luck
Nov 25, 2009 | Brother ML-300 Typewriter
The keys I strike are not what appears on the paper. Could the print wheel need replaced?
My printwheel also does not print what is typed. took out and put back in now what? How do you reset?
Nov 10, 2009 | Brother SX-4000 Typewriter
Settings
check to see if there is a "kybrd 1 and kybrd 2 " switch. should be on kybrd 1. also there is a pitch switch that needs to be the same as your printwheel. look for a switch that has 10, 12, 15 and PS printed beside it. if you have a 10, 12 or 15 pitch printwheel it won't print properly on PS. a PS printwheel won't work on the other settings. also check to see if anything is anything is touching the printwheel. then check the printwheel to make sure none of the fingers is bent out of place. if none of this seems to work, you probably have a bad main board and will need professional repair.
Oct 16, 2008 | Swintec 7040 Typewriter
Locating a printwheel for IBM Wheelwriter 6
I can get you a new one for $55.00 or I have a good used one for $30.00 plus postage My e-mail is jcagle12@msn.com I own The Typewriter Shop in Oregon
Oct 12, 2007 | IBM Wheelwriter 30 Typewriter
Lexmark Wheelwriter 2500 Typewriter Logo
157 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
