Des-1016a have a slow connection and sometimes get cut or lost its connection
2 Suggested Answers
EngineerMC
  • 186 Answers
SOURCE: D'Link DES-1016A
assign them an IP address each, making sure the addresses are all different and consecutive, make sure the subnet mask is the same on all machines, the switch will work right out of the box.
Posted on Jun 16, 2012
Can i turn on touchscreen on a kocaso netbook?
The Kocaso netbooks do not have a touch screen, only the Kocaso tablets offer this feature. With the netbooks, you must use the trackpad.
For this and more information, here is the Kocaso website and FAQ
Support FAQ
Apr 07, 2013 | Kocaso 1016A 10" Android 4.0 1.2GHz...
D'Link DES-1016A
Jun 07, 2012 | D-Link Computers & Internet
Problem with D-Link DES 1016D (DES-1016D) 16x10/100 Mbps Networking Switch
What HW version is your router?
What FW version is currently loaded?
What ISP Service do you have? Cable or DSL?
What ISP Modem do you have? Stand Alone or built in router?
What ISP Modem make and model do you have?
Ensure DNS IP addresses are being filled in under Setup/Internet/Manual?
Turn off QoS options.
Turn off Advanced DNS Services if you have this option Setup/Internet/Manual.
Turn on DNS Relay under Setup/Networking.
Setup DHCP reserved IP addresses for all devices on the router.
Ensure devices are set to auto obtain an IP address.
Set Firewall settings to Endpoint Independent for TCP and UDP.
What wireless modes are you using?
Try single mode G or mixed G and N?
What security mode are you using? WEP, WPA or WPA2? Preferred is WPA2 and Cipher type to AES only if your device support this.
Feb 18, 2012 | D-Link DES 1016D (DES-1016D) 16x10/100...
I have installed dlink 1016 10/100 Switch I have two computers and one dsl router connected to this switch but i am facing slow internet problem. when i connect my pc directly with router it works fine...
you'll probably find the router is set up to ignore ping requests, most are by default, for better results, try pinging a website and compare the results both with and without the switch. The switch shouldn't make any noticable difference to your connections, I use one and there's not perceivable difference in performance.
Apr 19, 2011 | D-Link DES 1016D (DES-1016D) 16x10/100...
How to connecte d-link switch model-DES-1008D two same switch pls urgent
Sometimes we need to connect 2 switches, which can be done by using Ethernet Cable (CAT5 or 6). Just connect the cable to the LAN ports from one switch to another. Let me know the purpose of doing so that i may guide you better.
Hope this helps!
CreativeTECH
Nov 16, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
Some loose contact it seems??? sometime able to connect internet and sometimes not possible?? wat is the reason???
D-Link 1024D performace drops when it gets heated.. Thermal problem.. switch off this equipment for few minutes and try.. keep this equipment in proper ventilation
Jun 01, 2010 | D-Link DES 1024D (DES-1024D) 24x10/100...
I interconnect a D-Link DES-10160 with D-Link Gigabit Switch DGS-1024D network and my network becomes slow
connect only DGS -1024D to your network....it will be faster...
because DGS supports 10/100/1000 speed.... but DES supports only 10/100 speed...
connect DGS directly to your network and work with that... if you wish to extend the number of ports then connect the DES to one of the ports of DGS
and dont connect DGS to one of the ports of DES
May 10, 2010 | D-Link DES-1024D Express EtherNetwork...
I have a d-link des-1008d switch connected to a satellite modem. i have a good connection, but one other computer connected to the switch has weak connection and one has no connection. the one with no...
For isolating the issue, try connecting the same computer to different ports on this switch. Mostly it should not be an issue with the computer but still as we need to troubleshoot this logically, we need to try this.
Else keep the power cable unplugged and plug it back in after 15 minutes.
Lastly try connecting your computers directly with the modem one-by-one.
Still if the problem persists, you may have to get the switch replaced.
Because a switch is not an intelligent device, nothing much can be done to troubleshoot.
Jan 20, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
Lost login Username and Password
How do I use the reset the password on my DES-3226?
Nov 14, 2006 | D-Link DES 3226 (DES-3226) 24x10/100 Mbps...
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
