Question about Viking VDSC305-4B Dual Fuel (Electric and Gas) Kitchen Range
How do I replace the oven door gasket on Viking model VDSC305-4BSS?
  • 42 Answers
SOURCE: Viking Range oven door does not close properly
sounds like the door hinges need replaced. order a part #PC020009 qty 2
Posted on Dec 21, 2008
TheMobilian
  • 8220 Answers
SOURCE: Viking Range Oven door will
Viking duel fuel service manual
See page 38
Posted on Sep 17, 2010
allbrands
  • 600 Answers
SOURCE: What is the part number
I searched all over and i am not finding your gasket here is a link that will help you and get you the correct part.
http://www.nationalpartscenter.com/viking/
Sorry i couldnt find the exact part number.....
Posted on Jul 02, 2011
sodeep
  • 3267 Answers
SOURCE: How do I replace the oven door gasket on my VGIC3686
Replacing a Door Gasket
If the oven won't heat to the desired temperature or heats unevenly, the problem could be a defective door gasket. The best way to test for this is to pass your hand around the door, being careful not to touch it, while the oven is turned on. If you can feel heat escaping, the gasket needs replacement. Replace it with a new gasket made for the range.
On most ovens, the gasket is located on the frame of the oven, and the door closes against it. This gasket is generally friction-fit in a channel and can be replaced. In other units, the oven door has two sections, and the gasket is not mounted on the door frame, but is installed between the front and back sections of the door. Don't try to replace this type of gasket; call a professional service person. Here's how to replace a frame-mounted gasket:
Step 1: Pull the old gasket out of the channel. On some oven door frames the gasket is held in place with screws. To get at the screws, bend back the exposed edge of the gasket.
Step 2: Clean the channel and the door frame with a solution of mild household detergent and water.
Step 3: To install the new gasket, start the replacement at the top of the door frame and work down the sides, easing the gasket around corners. Finish the installation along the bottom, butting the ends of the gasket firmly together.
Posted on Apr 17, 2012
SOURCE: viking igniters door removal?
how do you access those screws with the door still attached; there is no room for a screw driver
Posted on Oct 03, 2012
Viking fridge Model DDRB364RSS dripping water unto bottom cooler drawer and later under fridge - once a day or so. Door Gasket is a bit torn.
problem water in a fridge is moisture from the atmosphere--normally from opening the door but in your case from the damaged door seal
any tear regardless, compromises the compartment so have the seal replaced then see if you have a problem
Oct 26, 2016 | Viking Refrigerators
Eaton viking imperial electric,stove oven door will not close completelty; circa 1996. are replacement hinges still availible?
To the owner of the Eaton Viking stove RS3028W-1, yes you CAN get replacement hinges!
I too, have this stove model (circa 1996) with exactly the same problem and I have spent the past 18 months looking for replacement oven hinges. I was very frustrated at the thought of having to throw out a stove that cooks and bakes wonderfully and has not needed any repairs till now and having to buy one of the new subpar ones that constantly need repairs. Plus you can't do canning on the new stoves and the few remaining coil models are extremely poorly made.
I have found 2 places that carry the hinges.
1. Reliable Parts, 1-800-663-6060. This company is located in Montrea (St. Leonard), Quebec.
2. Appliance Shark, 1-800-663-1176. This company is located in Barrie, Ontario.
The part number for the hinge is: 318-024-741
I hope this is helpful, and may you have many more years of happy cooking on this great stove.
Sep 17, 2014 | Eaton Computers & Internet
How to adjust door viking dfsb423
Viking 42" built-in units usually don't offer any door adjustments. If one of the doors are not closing well, check for obstructions blocking the door bins, worn door gasket, and possible door warp-age on the panel ready models. Viking did have top hinge recalls updating to the new "Cobra" hinge on many of their models which can be verified by calling viking and providing your full model/serial numbers. If your Fridge door is lower than the freezer door you most likely have a worn door closer located on the lower hinge of the fridge door, the closer is a 2 piece plastic interlocking/mating unit which wears down over time from friction. This usually needs to be replaced. Pleazer Appliance...
May 06, 2014 | Viking DFSB423 Side by Side Refrigerator
Viking professional glasstop gasket replacement
If you have a VESC model you have to order a new glass top. They come glass in frame. My advice as a Viking Certified Servicer is to contact a local servicer to repair your range.
Oct 01, 2013 | Viking Ovens
Apr 16, 2012 | Viking Kitchen Ranges
What is the part number for the oven door gasket for a Viking model number vgr36-4gd?
Jul 02, 2011 | Viking Kitchen Ranges
How do you adjust the door swing angle on the Viking VCFF036 bottom freeze French door model? What are the angles?
Check with your Viking rep. I had a problem that the door swings too wide. They said they are coming u with a kit to replace the door stop. I was told there will be a 100 degree doorstop kit for my problem The door when swung open gets a ding from an adjacent Viking electric oven with the professional door.
Jan 01, 2010 | Viking VCFF036 Bottom Freezer French Door...
Wehre is model number located on viking oven?
It is usually on the stove at the bottom of the oven door. you might have to remove it to read it properly
Sep 18, 2009 | Viking Ovens
Jan 12, 2008 | Viking VDSC365-6B Dual Fuel (Electric and...
Viking VDSC305-4B Dual Fuel (Electric and Gas) Kitchen Range Logo
111 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
