Question about Pool & Spa
Wiring a AOSMITH S48A93A66 FAN MOTOR FOR 110 - Pool & Spa
  • 5,245 Answers
Motor wiring will appear on label on side of motor, for Lo 110V, and Hi 220V.
L1 is Line 1 is usually Hot wire
L2 is Line 2 is usually Neutral wire
Motor will show direction of rotation CW clockwise.
Compare diagram with old blower motor.
http://www.centuryelectricmotor.com/Applications/AdvanceCatalogSearch.aspx#Blower%20Units
Take photo of label and include link to photo so wiring diagram can be viewed.
Posted on Nov 09, 2012
  • Gene Haynes Nov 11, 2012
    Fixya has discontinued all my answers starting 11-10-12, choosing to direct quesions to list of answers all of us have worked to produce. And they never said thank you, and they stole $15 from me. Cheap and ungrateful is good description of fixya.
2 Suggested Answers
  • 4340 Answers
SOURCE: I need to install a new AOSmith 1 1/2 horse pump
There is nothing that you can do with respect to the 220 volts vs. 230 volts and fortunately, it does not matter. There is no voltage adjustment that you can do.
The 220 volts comes from TWO DIFFERENT 110 volt lines. Typically, your breaker will handle that correctly for you, be sure that both breakers are bridged, mechanically, so when you turn one off, both go off (prevents electrocution).
Posted on Mar 30, 2011
How do I wire a dayton 400 fire place blower
It should be a simple two wire 110 volt circuit. If it has a fan cycling switch on it, the hot wire goes into and out of the switch on the way to the motor while the neutral goes straight to the power source white wire. If no fan cycling switch, the two wires of the motor just wire to the cord plugging into the wall...(or wired directly into the 110 volt circuit in the wall outlet box.
Nov 15, 2014 | Heating & Cooling
110 volts plug in to 220 volts
It will burn out the device since the requirement is only 110 v the capacity of the wire as well as the motor coil will only allow 110v running.if it goes beyond it damage the motor.
Sep 13, 2013 | Vornado Circulating Fan
Wiring diagram for aosmith a48a93a66 motor
Label will show wiring diagram.
Usually: L1 Line 1 will be 120V Hot
L2 Line 2 is Neutral
Low voltage is 115 volts
High voltage is 220 volts
Motor shipped new with 220V default
Compare existing wiring to what appears on label.
Label will show wire colors Brown, yellow, red, white etc.
Move these wires as needed to change voltage.
Take photo of label, post on internet, add comment with link to photo so diagram can be viewed.
Nov 08, 2012 | Pool & Spa
I need a replacement motor for a nutone fan ls100se
Try Home-Depot replacement fan kit or www.electricmotorwarehouse.com/aosmith/nutone/nutone.htm
Sep 16, 2011 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
I need to install a new AOSmith 1 1/2 horse pump for my pool. The to lines that come from the house are both 110 volt. The pool is wired for 230 volt. Will attaching the 110 lines work for the required...
Mar 30, 2011 | Pool & Spa
I am looking for a WIRING SCHEMATIC for the Hayward 5060 booster pump MOTOR. A wire came off and I cant find where to replace it.
Please comment with the motor manufacturer and the model and serial number off the motor nameplate. It is likely an AOSmith motor and the info will be somewhere on the motor frame.
John
Aug 25, 2010 | Hayward Pool & Spa
What wires do I need to switch to make an AO Smith motor (922L) run the opposite direction?
I can not give you an exact answer as the diagram is not available on AOSmith's website. Generally speaking the wires are a black and a red. It should describe to you the process on the motor nameplate in the bottom right corner. If you are still unable to reverse it, please reply with a comment that includes the motor serial number and I will go to AOSmith's tech support and get the diagram that way.
John
Aug 14, 2010 | AO Smith A O Smith Motors Century 1hp 115v...
Motor rb1074a motor rotation going the wrong way need wiring dia
Most AOSmith motors have either a red and black wire to interchange positions or a blue and yellow wire. It should be mentioned on the motor nameplate as to which wires you swap to reverse it, assuming it is a reversible motor. The motor number is not on the AOSmith website so I can not be sure one way or the other.
Oct 22, 2009 | Pool & Spa
HELP!!! Help wiring new motor for CKL60-1
  1. This is what your wiring should look like if you are using two caps. then you should be using a potential relay as well. This is the diagram for using a potential relay. Hope it helps you.
Aug 25, 2008 | Goodman CKL60AR60 Air Conditioner
Pool & Spa Logo
228 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
