Question about Pool & Spa
Wiring diagram for aosmith a48a93a66 motor
Wiring to 110 from 220
  • 5,089 Answers
Label will show wiring diagram.
Usually: L1 Line 1 will be 120V Hot
L2 Line 2 is Neutral
Low voltage is 115 volts
High voltage is 220 volts
Motor shipped new with 220V default
Compare existing wiring to what appears on label.
Label will show wire colors Brown, yellow, red, white etc.
Move these wires as needed to change voltage.
Take photo of label, post on internet, add comment with link to photo so diagram can be viewed.
Posted on Nov 09, 2012
Wiring a AOSMITH S48A93A66 FAN MOTOR FOR 110
Motor wiring will appear on label on side of motor, for Lo 110V, and Hi 220V.
L1 is Line 1 is usually Hot wire
L2 is Line 2 is usually Neutral wire
Motor will show direction of rotation CW clockwise.
Compare diagram with old blower motor.
http://www.centuryelectricmotor.com/Applications/AdvanceCatalogSearch.aspx#Blower%20Units
Take photo of label and include link to photo so wiring diagram can be viewed.
Nov 08, 2012 | Pool & Spa
My pump is wired for 120 and the diagram shows that a black trace wire to terminal B and a black wire to terminal A.Know my problem is the way its hooked up is a black wire on A and a black and white on...
The black and white wire is the trace wire. Using the A and B posts will be the 230 VAC connection. There should be another diagram for 115VAC telling you to move one wire to L2 and the other wire to I believe B. If the 115V diagram is not there is the motor rated for both 115 and 230VAC? If you need more help reconnecting the motor for 115 please provide the motor model number. It is likely an AOSmith motor with about a 10 character number for the model.
John
Nov 17, 2010 | Flotec 1 - 1/2 Sprinkler Pump Composite...
I need apicture of the wiring on a 1 hp motor
here are a couple typical wiring diagrams that cover most AOSmith pool pump motors. Without knowing more about your motor it's impossible to be exact. Hope this helps. If you need further assistance post a reply in the comments, and don't hesitate to leave good thumb rating if you found this helpful. Thanks, and good Luck! cde0e76.jpg9fa085c.jpgc5ac9c6.jpg
Oct 02, 2010 | A O Smith Motors A O Smith 1hp 115/230v Ur...
Where can I get a manual for the ao smith sq1202 pool pump or schematics
Try this link: http://drawings.aosmithmotors.com/sendfile.aspx?ItemNumber=SQ1202&DrawingType=OUTLINE
There is a small portion that describes the line connections. If you need the internal wiring diagram you will need to contact me thru www.arrowmotor.net and well get it from AOSmith for you.
John
Sep 10, 2010 | AO Smith 2 HP 115/230V 56C Replacement...
What wires do I need to switch to make an AO Smith motor (922L) run the opposite direction?
I can not give you an exact answer as the diagram is not available on AOSmith's website. Generally speaking the wires are a black and a red. It should describe to you the process on the motor nameplate in the bottom right corner. If you are still unable to reverse it, please reply with a comment that includes the motor serial number and I will go to AOSmith's tech support and get the diagram that way.
John
Aug 14, 2010 | AO Smith A O Smith Motors Century 1hp 115v...
I am looking for a wiring diagram for the three capacitors on my 7.5 hp single phase motor. The make is AO Smith, Part Number: 7-348524-05-0J, Frame: F215T, Stock Number: V305. Can you tell me where to get...
Thank you for posting your question here on Fixya.com.
I sent the number to my AOSmith tech contact. I hope to have it monday sometime. Please contact me thru our site, www.arrowmotor.net, so I have your email address to forward the connection diagram to.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Jun 12, 2010 | AO Smith .75 HP Uniseal Vertical Motor
Motor rb1074a motor rotation going the wrong way need wiring dia
Most AOSmith motors have either a red and black wire to interchange positions or a blue and yellow wire. It should be mentioned on the motor nameplate as to which wires you swap to reverse it, assuming it is a reversible motor. The motor number is not on the AOSmith website so I can not be sure one way or the other.
Oct 22, 2009 | Pool & Spa
Diagram of wiring on Miele dryer
Hello cpopp101,
Please follow the link and goto page 30 for the electrical requirements. The manual is for the T8012 but all the dryers are the same for electrical. Goto page 30. There is usually a seperate fuse box for these (Depending on how old the dryer is) in which you may want to contact Miele to see if you have
http://www.mieleusa.com/manuals_pdf/Residential/Dryers/T8012C_8013C_us.pdf
Good luck
Sep 17, 2009 | Miele Novotronic T1515A Electric Dryer
Pool & Spa Logo
349 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
