Question about Hitachi CP-S240 Multimedia Projector
Locate filter where is the filter on the hatachi cp s240
  • 21 Answers
The air filter for the Hitachi CP-S240 is located below the lens if the projector is sitting flat on a surface.
There will be a plastic cover that slides off by pulling it towards the front of the machine. Inside this cover you'll find the filter.
To clean it, simply pull the filter out of the cover or housing and blow the dust out of it. Replace the filter and the cover, and then make sure to go into your menu and reset the filter timer.
Posted on Apr 07, 2011
I need supplayer address in gujarat for hitachi 14"cuttoff wheel
Hello. To locate a supplier, the city within Gujarat is requested by the Hatachi site. Here is the link to the Hatachi Group International Locator tool... Hopefully you will be able to locate a dealer close to you.
Best of luck.
http://www.hitachi-hli.com/DealerLocator.aspx
Feb 22, 2011 | Hitachi 727685B10 14" Cutoff Wheel for...
Flip image on Hitachi CP S240
The setting you are looking for is called mirror. If you go into your menu, you should be able to find it. I'm not fmailiar with that exact model, but Hitachi is very good about keeping their projectors consistent where the menu/options are concerned. Once you find the mirror section, cycle through the options (there will be 3 or 4) until you find the one you need. If your projector is hanging upside down from the ceiling, select the ceiling option.
Feb 08, 2011 | Hitachi CP-S240 Multimedia Projector
The color on our cp-s240 projector is really bad. When I go to menu, color and tint are greyed out so I cannot adjust them, what should I do?
Often you will see that you have lots of options in your menu that appear grayed out. This occurs when you do not have an input device connected to your projector.
In order to have access to all the menu options, simply connect an input device (TV,DVD player, computer, etc) to your data projector and start the projector.
Assuming everything works properly, if the projector starts receiving a signal, you will have all your menu options available.
I'd also note that image discoloration can also be caused from defective/damaged cabling, cables not being connected fully, bent pins depending on the type of cables you are using, and also for internal problems. If you can not adjust your settings to achieve satisfactory color, check your cables for damage and make sure they are all connected properly.
Jan 05, 2011 | Hitachi CP-S240 Multimedia Projector
Hitachi cp-s240 remote question
Hitachi data projectors are able to function as a mouse using either the USB port or the control port located on the back of the projector.
However, they are not intended to be used as a remote presenter. This means that although you can use the remote as a mouse, you will not be able to change slides in a full screen slide show using powerpoint.
I recommend the Targus remote presenter for this purpose. This device will function as a mouse, pointing device, and will allow you to change slides in powerpoint. In addition, it's inexpensive, wireless, and small enough to easily fit in your pocket.
Mar 02, 2010 | Hitachi CP-S240 Multimedia Projector
Whats it mean when the projector says to check the airflow every few hours on the screen. The projector is a Hitachi CPX440
one or more of the fans may not be working properly and the heat is triggering the temperature sensor. if the projector is too dusty, the heat stays in and may ruin components. if there are filters, clean them first.
Nov 04, 2009 | Hitachi CP-S240 Multimedia Projector
Hitachi cp-s240 blue tint cloud problem
This might sound like a worn spot in the (blue) lens from heat, or a bad color driver on the mother board. It could possibly be dirt or condensation behine the lens(s)
Jun 19, 2009 | Hitachi CP-S240 Multimedia Projector
Using the computer monitor and the projector at the same time?
I kind of have a solution for you. I know you need a splitter cable. You might want to go to Radio Shack or your local geek store or the manufacturer of the desktop and see what they have as far as accessories.
Or
Get yourself a laptop and run the projector from that, All you have to do then is hold down the FN key while pressing (depending on the make and model) F3 or F7. I use two differant laptops and those are the keys I use. I hope that I helped.
Dec 11, 2008 | Hitachi CP-S240 Multimedia Projector
Hitachi CP-X250 LCD Projector
clean filter and reset the filter timer by advanced options filter timer and hold reset till menu shows then arrow up and it will zero out.
Oct 19, 2007 | Hitachi CP-X250 Multimedia Projector
Hitachi CP-S240 Multimedia Projector Logo
530 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Chris Goulet
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
