Question about Casio Xj-a140 Dlp Projector
Casio projector power light and temp light blinking
The projector starts initially, then what i think is the fan tries to turn on, then stops, then repeats for a few times. It stops trying, and the power light starts blinking with the temp light. Then the power light goes solid after a little while, with the temp light blinking. I was wondering if anyone knew what I need to fix, or what I should do. Thanks
4 Suggested Answers
SOURCE: problem with Casio xj-s35 projector
You have to disconnect power to reset it.
Posted on Mar 17, 2011
t00nz
  • 4738 Answers
SOURCE: I have an Exilim s-880 casio camera. My camera
Why yes, how old is your battery? If more than a couple years, time for a new one. Here's some from Amazon. While there, also think about an external charger, they're very inexpensive also.
Posted on Jun 12, 2011
  • 52 Answers
SOURCE: casio xj-s30 projector was unplugged
Perform a Factory Reset:
1) Plug unit into AC power, so that all the lights come on as mentioned.
2) Press and hold "MENU", "ENTER" and "INPUT" (all together) for at least 5 seconds. Error lights will clear.
3) Turn OFF by POWER button, wait a few seconds.
4) Turn power ON by pressing the POWER button.
The projector will turn ON, but will take a while (1-2 minutes) to load firmware.
5) Recommend to go into Menu and at the very bottom use the "restore all defaults"
Posted on Sep 30, 2015
Why does red TEMP light come on after power up?
The fan is important. If it doesn't turn at the correct speed the red light will come on. Replace the fan and that will fix the problem Go to Casio's website to get the part or try here:
Nov 21, 2015 | Casio XJ-251 WXGA DLP Projector XJ-A251
Red power, blinking red temp
if the Lamp error and Temperature error lights are flashing red this means that there are two separate errors.
  • A flashing lamp light means the lamp failed to ignite. It could be a lamp driver problem or lamp failure. Replace the lamp to resolve the issue. If the issue is not resolved, then service the projector.
  • A flashing Temperature light signals a fan error. Turn the projector off and allow it to cool down. If the light is still flashing after the projector is turned back on, service the projector.
Goodluck..
Feb 25, 2008 | Hitachi CP-X250 Multimedia Projector
Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dell™.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dell™.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dell™.
Oct 23, 2011 | Dell 1209S DLP Projector
Casio xj-s41 lamp and temp light amber blinking
FIRST LOCALIZE THE UP/ DOWN/ LEFT/ RIGHT AND MIDLE BUTON- ON FUNCTION CONTROL
OK...
KEEP PRESSD FOR 10 SEC
INPUT / MIDLE BUTTON FROM FUNCTIONS/ AND RIGHT ARROW
RELEASE THOSE BUTTONS
NOW YOU SHULD GET THE ERROR RESETED.
NOW YOU HAVE TO INITIALIZE THE UNIT:
POWER OFF UNIT( FROM POWER BUTTON)
POWER ON
PRESS AGAIN: INPUT/ MIDLE BUTON/ RIGHT AROW TILL SHOWS A SERVICE MENU ON SCREEN
CHOSE INITIALIZING AND RESEAT UNIT.
GOOD LUCK...GO CANUCKS
Nov 30, 2010 | Casio XJ-S41 SuperSlim DataProjector ...
Toshiba TDP SC25 projector
The manual says it might be because the power went out when it was on. Just a note here, as projectors age they become more sensitive to power outages. When not in use turn off completely if you can. They have an on/off button.
Otherwise not sure but think you may need to replace the fan. Try cleaning it first but gently.
Jan 31, 2009 | Toshiba TDP-SC25U Multimedia Projector
Problem with Casio xj-s35 projector
Nov 08, 2008 | Casio XJ-S35 DLP Projector
Projector problem
I generally fix this by re-seating the bulb housing. Take it out and put it back in. Look for cracking at the base of the bulb on the mirrored surface. It could be a barely functioning bulb that isn't busted, but can't initialize. I would take it to a shop that has the same bub type in a housing and make a quick switch.
Jun 20, 2008 | InFocus ScreenPlay 4805 Multimedia...
Casio Xj-a140 Dlp Projector Logo
145 people viewed this question
Top Casio Computers & Internet Experts
k24674
jackcity
jackcity
Level 1 Expert
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
