Question about J Mason Caramel Tech Family Fitness J3383 Stroller
Parts to fix open air swing
The head where the batteries fit is bad.
Air just blowing through and out the top discharge valve
Air leaking from top of nailer is indication of bad cylinder seal. Remove cap and look for loose fitting or broken cylinder seal (vinyl ring). The seal should fit snugly around headvalve. If seal seems ok then remove upper bumper and look for cracks (round vinyl part pushed into center of headvalve). Replace as needed. If all parts look good, and while you have the head valve out, clean the upper head and lube with plenty of silicone paste (sold at Lowes in the plumbing department, used for faucet orings ). Parts are sold at your local dewalt repair center or at www.toolpartsdirect.com.
Jul 31, 2011 | Porter Cable Cable Factory Reconditioned 2...
I bought it and put new batteries in it and the music will play and i press the buttons to make it swing and it doesnt do anything. It doesnt make any noise like its trying to swing or nothing. Could that...
Graco swing motors are known for going bad, sorry. I have had no luck trying
to fix them as you tear them down and the electronics are what has gone bad.
They have a motion sensor in them along with a complicated motor to swing swivel
that if you lose a small ball that is the interface, you are doomed.
Time for a new one and if you buy one at a garage sale be sure to run it with weight in
it for at least 5 minutes. That culls out the bad motor ones!
Feb 05, 2011 | Graco Baby Gear
My 3-year old LG air-conditioner was leaking water. So i called some 'experts' to come fix it. This is the first time I called for maintenance service on the air conditioner. The 'experts' dismantled some...
White snow.. I had this issue when 2 inside unit electrical lines were hooked up backwards at the compressor. The compressor would pump too often and overcool the inside unit, because it was using the wrong temperature sensor. But you could have a different issue. I'd have them recheck your freon levels, that can cause it to cool too much - should be 120-135psi when it is running, after 5-10 minutes or so. They adjust this for the outside temperature though.
Oct 04, 2010 | LG LS-L1210CL Mini Split Air Conditioner
How to properly vacuum my pool
attach hose to vacuum head, keep under water while you take the other hose end, and place in your pool, over the outlet, so the hose fills with water and all the air is out... then while keeping it below water level. move it into the skimmer, usually you remove the swinging door and the basket of your skimmer, and the hose fits down in. now while keeping the vacuum head under water, place your hand on the bottom to feel if you have suction. if so. you are good to go... go slowly, depending on how bad it is, you may have to go back and forth a bit, but it's not like carpet, ,,, if you go too fast, you will just stir things up.
when done, disconnect, and make sure you backwash your filter.
Aug 08, 2010 | Hayward S220t Top Mount Pro Series Sand...
1985 VT 500 C Shadow: how do I remove the battery...
Take off the left side cover (press fit) . You'll need a screwdriver phillips or flat head and a ten millimeter socket. Remove the bolt on the right side of the bracket to the frame and swing it out of the way. Unbolt the battery cables, unhook the overflow tube, and lift the battery out of the left side of the bike.
May 06, 2010 | 1985 Honda VT 500 C Shadow
Where is the cabin air filter on a Saab 9-3 Aero convertible?
Open the hood and you see the wide, black, flat plastic cover that goes all the way across just under where the windshield wiper blades are?
On the passenger side, remove the piece of rubber weatherstripping by gently pulling it out partly. Remove the black plastic screw at the passenger edge of the big black piece.
Gently pry the black foam up but hold the connecting side down with your other hand so you don't rip it off.
Lift up the big black plastic tray like piece. See the filter?
Remove the filter by lifting up the 2 clips at the top. Don't break it off. They are hinged at the top and swing up (just the opposite of the post office blue mail boxes which have the hinge below and swing open). Then take off the filter.
Wipe the area with a damp cloth to do general cleaning and then put a new filter in. Look at the arrow to fit the filter in the correct direction (it draws air forward and pulls it to the passenger compartment)
Apr 05, 2010 | 2007 Saab 9-3 Aero Convertible
Pull to left even when just rolling, no damage that i can see
Bad, mismatched, improper tires, Wheel bearings, wheel bearing preload adjustment steering head bearings, steering head preload adjustment. misaligned wheels swing arm bushings or bearings, swing arm bearing preload, worn defective shock, bent frame, rims. forks. misaligned forks. fork stiction.
Prevention is in making all above are correct., a steering damper won't fix it, it will only hide the problem!!!
Oct 31, 2009 | 2008 Suzuki B-king
Swing part doesn't work
the motor could be shot, thats what happened to mine, it was an older fisher price aquarium one, and i had to buy a new one.
hope thats not whats wrong with yours, good luck
Jun 19, 2009 | Baby Gear
Fisher Price Nature's Touch Cradle Swing - Not Swinging
Parts for your model can be found on amazon, here:
Amazon com fisher price swing replacement parts. I hope this helped you. Best of luck
Oct 03, 2008 | Baby Gear
Wii remote controller not fully funtional
in baseball you have to hold it beside your head and in bowling you have to raise your WII control up and realese th B button(hold B button than do instruction)(not for the Baseball game)
Jan 02, 2008 | Nintendo Wii Console
J Mason Caramel Tech Family Fitness J3383 Stroller Logo
18 people viewed this question
Top J Mason Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a J Mason Baby Gear Expert? Answer questions, earn points and help others
