Question about Delfield Freezers
Can a delfield model 407 using r12 freon be modified with a new compressor to use current refrigerants
The model 407 I own does not work, it appears in fairly good condition, the compressor turns on but does not sound good. It does not cool. I would like to replace the compressor with a new one using acceptable freon. Can this model be modified to do this ?
    Problem Solver:
  • 39 Answers
Yes it can. if the model is a techumseh find the local dealer.
give them the compressor model # and get the new 134a model
equivelant. no oil change . replace the filter drier when you replace it .the refrigerant charge will be about 90% of the original r-12 charge
Posted on Apr 18, 2013
  • 173 Answers
SOURCE: I have an upright freezer and it only cools down
Clean coils if no help cleck refrigerant.
Posted on Jul 07, 2009
  • 1150 Answers
SOURCE: Delfield 6000xl: what is the 404a freon charge?
http://www.delfield.com/?xhtml=xhtml/del/us/en/general/partsandservice/archivemanuals.html&xsl=minisite.xsl
this is for their web site. It has all the manuals and charging tables. There is no 6000xl. Need exact model number as the amount varies.
Hope this helps
Posted on Apr 01, 2010
  • 1150 Answers
http://www.delfield.com/docs/uploaded/del/Serviceinfo/ref_serv.pdf
this web site has a table of units and their respective charging amounts.
Hope this does it for you.
Posted on May 11, 2010
  • 193 Answers
SOURCE: Delfield MD # 6151 - S Sr # 206156-T not pulling
Take the top cover off that is next to the compressor,. That cover is about 30 by 30 inches. You will see two fans and an evaporator coil. Several things can happen. First these fans won't come on until the coil is somewhere around 10 degrees or if the door is open. So, once the freezer has been running look under the big cover and be sure both fans are running. If one or both are not running it won't pull down to 0. Also look at the coils and see how much frost has accumulated. If your defrost timer is not working it may be frozen over. When that happens air is blocked from reaching the inside of the freezer. While you are at it, fell of the coils if they are only partially freezing, you may be low on freon. If you have gauges to check the freon charge, check both the high side and the low side pressures. If the high side is less than 200 psi, you have some freon, but maybe not enough. If the high side pressure is 300 psi, you have something blocking the freon from returning to the compressor. Usually a blocked cap tube or a malfuncting expansion valve. Finally check the condenser coils which is the radiator thing out where the compressor is located. If it clogged with dust and grease, it will not dissapate the heat from the freon and will intefere with the operation of the entire unit. Clogged condener coils are probably the number one cause of burned out compressors. Good luck.
Posted on Sep 17, 2010
Testimonial: "Unit still had R 12 in it and someone had charged it and had air in the lines I reclaimed the unit and retrofited it with R 206 and it is find now."
  • 1150 Answers
SOURCE: Is it possible for a
I would look to see if it is tripping during the defrost cycle. One of the heater elements my be faulty. Never heard of a bad TXV causing a breaker tripping, but I guess it's possible. I would adjust the superheat so that it is about 6 to 8 degrees just prior to unit reaching temp and shutting off. I'd start there.
Posted on Apr 13, 2011
I need help with a Delfield m# se-c5-9a, s#0807150000495. I think I have a restriction.but not sure. . I recovered the refrigerant and weighed in the 10 oz it calls for. Now my psi is 6.6 / 150.
If you recovered all the refrigerant how can you have a psi reading? Should be zero, yes? If unit is a refrigerator, proper freon levels are very critical for operation - no leeway as in auto AC's. Need to use accurate scale after using a vacuum pump to purge system and put in exact amount. Too much or too little is no good - have to be spot on.
Aug 28, 2017 | Delfield Freezers
How can i change a delfield 407-dhl from a freezer into a cooler
Refrigerators and freezers are almost identical except for more controls on a freezer. Just raise the thermostat to the temperature you need. If it won't adjust that high, you will need to replace it.
Dec 02, 2013 | Freezers
Inside fan runs but freezer is hot
On this video, Delfield refrigerator with freon issue (restricted system)
May 06, 2011 | Delfield Upright Freezer 403
There has got to be a way to change the factory preset freezer temperature on a Delfield 6000 series MCII to operate at refrigerator tempatures. Does anyone know how I can change the factory preset...
Do you mean to go up to +36 degrees? If so, it just won't work correctly. The refrigerant is the wrong one to run at 36 degrees. The pressure on the "low" side of the compressor is so low that the compressor will starve for freon if you tried to change the thermostat to "warm" it up to +36. Also the defrost cycle would have to be disabled or it would jump to 50 or 60 degrees 4 times a day. It also has the wrong cap tube for that temperature. It could be done with a very expensive condensing unit changeout. Over the years I have seen a lot of people try it and nobody that I know have been succesful at it. It may be easier to find someone who wants to trade. After all a freezer is worth more dollars than a cooler. Good luck.
Oct 07, 2010 | Delfield 113.28 cu. ft. Commercial Freezer...
Delfield MD # 6151 - S Sr # 206156-T not pulling down to Temp set at -10 and only pulling down to 24 freon is good
Sep 17, 2010 | Delfield 113.28 cu. ft. Commercial Freezer...
May 09, 2010 | Freezers
Hope this helps
Mar 25, 2010 | Freezers
What should refrigerant gauges read when charging walk in freezer?
Depends on what kind of refrigerant its works, if is an old unit probably is charged with R12 or R22 newer ones work with R404 ;for R12 presures should be around 20psi on the low side and 160 on the high side ,for R22 about 60 and 250 and for R404 50 and 350 ;you have to look at the condensing unit tag to find out what type of freon its uses ,or look at the expansion valve at the evaporator coil.
Jul 31, 2009 | Everest Refrigeration Freezers
Older model, motor funs, but does not cool the chest
Well one way to find out is to look on the back. It shows all the info including what kind of freon to use. Usually the manufacturing date is on there. If not see if it uses 134 for refrigerant. This would at least indicate it is not really old. 134 was introduced in the late 90s. replacing R12. If you meant the compressor run but do not freeze, unplug it because the compressor can be damaged if it run without refrigerant for long period of time. If you meant the fan in the freezer was running, the compressor might not be running at all thats why it is not getting cold. This could be caused by the breaker switch on it not resetting anymore. It may have a leak it too, and all the refrigerant has leaked out. If it operates on 134, you can buy a line tap, 134 adapter availabe in auto parts store or walmart. Buy you some freon in the can. A propane torch, solder, and some flux. If you have a friend who is handy, or a mechanic. They can do it for you much cheaper. One does not need refrigeration license to work on refrigerators. Only the know how. I can give them instructions. Last note. a fridge usually take 1/2 to 3/4 can of 134.
Jun 28, 2009 | Freezers
Food thawing in freezer
You may have a small leak in the evaporator. You could try to get a replacement freon with stop leak from the automotive store and give it a shot. If it is a R12 unit then it is too old to repair. But it is worth the gamble to shoot it with freeze 12 or an equivilent before you condemn it.
Apr 10, 2009 | Freezers
Freezers Logo
90 people viewed this question
Top Delfield Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Delfield Freezer Expert? Answer questions, earn points and help others
