Question about Mercury Mark 30 Hipo Outboard Motor (Mercury Marine)
How to clean petrol filter - Mercury Mark 30 Hipo Outboard Motor (Mercury Marine)
  • dennis205 Dec 05, 2012
    I detected where the filter probably is, but i can not reacht the screws holding the cover.
    Novelist:
  • 184 Answers
Not familiar with "Hipo" motor, but the early mercs had a filter under the fuel line connecter to each carb, then they started putting them under the intake of the fuel pump under a plastic cover.
Posted on Nov 29, 2012
  • william moore
    william moore Dec 05, 2012
    Those early engines had to loosen or remove the carbs -as Kiekofer in his insanity wanted everybody to do complete rebuilds on simple maintaince items
Why does my 6.5 hp kohler lawn mower keep pulling oil into carb air filter
Its to stop the dust blocking the filter. The filter should be cleaned with petrol every 4 to 6 months to remove the dust & oil build up, cleaned in/with petrol and re-oiled. Its also good to clean the filter housing each time you clean the filter
Sep 26, 2014 | Yard Man YardMan 11A41K3001 21Inch 173cc...
How do you replace the petrol filter and when?
The fuel filter is within the fuel tank. It is replaced after every subsequent 100,000 km or it can be cleaned with compressed air (if clogged).
Mar 15, 2013 | 2006 Toyota Yaris 1.3
EFCO63C mower will not start after being left unused for 10 years
make sure you have spark, then check fuel filter, then fuel pump
Mar 08, 2013 | Garden
My pulsar 150 is showing a missing when it goes to reserve
It probably is due to the crud that is around the filter in the bottom of the tank.
Petrol is messy stuff and as it is a hydrocarbon it contains water.
Water rusts the tank this sinks to the bottom and after a while gunges up the filter.
If possible empty the tank fill with a small amount of fresh petrol and swill it around and empty again. If you can remove the filter from the tank clean it in meths or clean petrol. An old toothbrush works well.
Jan 27, 2011 | 2005 Bajaj Pulsar 150
Will not start. Been sitting since 1980.
hi, the cylinders are dry of petrol fumes and you need a (good battery), if all the mehanical parts (working fuel pump and clean fuel filter) o.k. and the spark plugs are clean and the (spark plug timming leads) are correct and points are set and the (ignition coil) is o.k. this engine should start. (if not) take off the air filter and check it is clean, leve the air filter off and put a very small amount (egg cup full) of clean petrol into port the carberreter (it will not start straight away because the plugs may be wet) or wrong (timming leads) if it splutters problebly not enough petrol or ignition faults (electrical points contacts dirty) all cars need metered fuel and air to run. wish you luck gerry
Sep 07, 2010 | 1980 Cadillac Eldorado
Champion petrol mower ran low on fuel - was
I suspect that there may have been dirt at the bottom of the tank or possibly water. Try changing the fuel filter but first clean the tank and refill with clean petrol
Oct 12, 2009 | Champion Jockstrap and Abdominal Supporter
Nannie what can be wrong with my power devil petrol lawn mower the engine wont keep running then cuts out petrol and oil ok
Check air filter, check screen in bottom of fuel tank,
New spark plug and also check the spark.
If there is a weak spark, the coil may need to be replaced.
If you have good spark, clean air filter, and clean fuel tank screen, then the carberator will need to be pulled of and cleaned out with solvent
Jun 23, 2009 | Mtd 22" Yard Machine Push Mower
No restart when warm audi 100
Do you checked the petrol filter? It can be simple as that.
check the MAF, the spark plugs and cabling, air filter, petrol pump.
I had the same problem with mine (same year, same model), I cleaned all the air intake system, fuel line, and now it's perfect (even needing to change petrol filter, i didn't changed it yet). Careful cleaning the MAF, if you don't know how to do it don't do it, ask an expert near you.
If you can't solve the problem this way, search for air or fuel leaks.
I solved mine cleaning the fuel line and the air intake system.
Apr 14, 2009 | Audi 100 Cars & Trucks
My ford fieasta 1.4i zetec engine keeps flooding all the time and is stinking of petrol it isnt leeking petol just stinking of it wen i start it up and is draing the petrol wat could be rong
Hi, have you tryed cleaning out the fuel injectors and clean up the spark plugs?
Also the car may need a full services, fuel filter, oil filter, air filter, new oil and spark plugs
Apr 09, 2009 | Ford Freestyle Cars & Trucks
Mercury Mark 30 Hipo Outboard Motor (Mercury Marine) Logo
98 people viewed this question
Top Mercury Boating Experts
Colin Stickland
Colin Stickland
Mike
Joseph Hoffmann
Are you a Mercury Boating Expert? Answer questions, earn points and help others
