Question about Whirlpool Dryers
A whirlpool gas dryer - no heat! - replaced the ignitor head ( was broken) -still no heat! thanks bernie
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
What is the model number of your unit?
Does the igniter glow but the unit won't light?
Posted on Nov 09, 2012
catriver
  • 878 Answers
SOURCE: Gas dryer not heating up
Flash, did you check the thermal fuse in the back? On a gas dryer the drum will still turn if it's blown. check out the picture and post back.
Posted on Mar 29, 2007
SOURCE: gas dryer will not heat
The dryer will not heat i check the vent to make sure no upstruction and open the back to make sure no wire was lose. where will the fuse be kenmore model 76722697 serial No. 0702383
Posted on Jan 18, 2008
  • 14 Answers
SOURCE: no heat-gas dryer--Amana
There is a flame sensor on the side of the flame housing. Jump the 2 wires out and see if the ignitor glows then. If so you need a flame sensor.
Posted on Jul 25, 2008
appldoctom
  • 311 Answers
SOURCE: location of thermal fuse on whirlpool estate gas dryer
if this is a gas dryer and the ignitor is working the thermal fuse is fine.need more info .dose the valve coils make any clicking noisecheck with ohm meter to see if coils open/also is gas on
Posted on Dec 31, 2008
  • 77 Answers
SOURCE: maytag gas dryer, no heat, ignitor wont glow
The machine will check all safety features first. check the overlimit by the burner. It may have a reset. If not, turn power off and check continuity (ohms). Good luck.
Posted on Apr 18, 2009
Whirlpool gas dryer we have the ignitor comes on, gas lights, runs for a minute and shuts off. After about a minute the ignitor comes back on but the gas does not. thanks
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 17, 2010 | Whirlpool LGR8648L Gas Dryer
It's run but there's no heat
The gas dryer has a spark ignitor that starts the burner to heat up. Upon switching on the dryer you should hear the ignitor clicking to light the burner. If you do not hear the clicking noise the ignitor needs to ne replaced
Mar 27, 2010 | Whirlpool LGR5636L Gas Dryer
Have a Whirlpool Gas Dryer - model # lgr7646a spins but no heat
Thre is no pilot light. This dryer uses an ignitor (glow bar or coil).
Open the lower front "door" (small access door) and turn on dryer.
If the ignitor does not glow (bright orange), then the ignitor needs to be replaced ($60).
If it does glow, then the gas valve needs replacement ($60).
If it isd the valve, the internal spring is stuck. Do not try to repair it, you must replace it.
Sep 25, 2009 | Whirlpool Dryers
Gas dryer wont heat up, blows only cold air.what would cause this
Could be a bad hi limit thermostat. Could be a bad glowbar ignitor. Check the glowbar ignitor at the gas valve, is it glowing bright orange/red? If not. Replace the ignitor.
Jul 22, 2009 | Whirlpool Dryers
My whirlpool gas dryer will not heat. I replaced
there is a big black box on top of the burner check this if good check theremal fuse this will be on the heat tube most likly in the back it is small and white
Jun 26, 2009 | Whirlpool Dryers
Whirlpool gas dryer won't ignite -no heat
Try replacing the ignitor. The ignitor has to glow red and draw enough current to open the gas valve. When the gas valve opens then the ignitor lights the burner. Replace ignitor.
Nov 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Gold Ultimate Care II: No heat
didc, on a gas dryer, if the thermal fuse blows it will still rotate, but will not heat. Since this is a gas dryer, see if the ignitor is glowing. If it is, then you know the thermal fuse is good. If not, the thermal fuse may be blown or the ignitor itself and thus the reason for no heat. Catriver.7152136.jpg
Jan 01, 2008 | Whirlpool GGQ8831L Gas Dryer
Whirlpool dryer problem
Hi thanks for the question. the problem is with the 2 coils at the gas valve. 1 coil has 2 wires to it the other has 3 wires to it . replace the coils .thanks the appliance doc.
Nov 25, 2007 | Whirlpool LGR7646E Dryer
Mar 29, 2007 | Whirlpool LGR3624JQ Gas Dryer
Dryers Logo
56 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
