Question about Compaq Armada M700 Notebook
Boot issue ok i have seen this all over the place it apears that the compaq laptops do this often... I have yet to find a useful answer... ok my laptop says on boot... 1782 Disk Controller Faillure then after that it says.... Non-system Disk or disk error now i know that it is not the hdd because i have tested it in another laptop. From what i have read it is a BIOS error... more spacificly a CMOS error... I have reset the CMOS by removing the RTC and that did nothing. I I even removed all of the media divices on the laptop. IE the modem and the CDrom. I really need to get this laptop up and running i need it for school.... if any one could help i would really apriceat it....
    Problem Solver:
  • 8 Answers
Okay, First of all, it would be very helpful if you could include the Operating System you are running, AND what is the size/type of your Hard Drive? There's a couple ways to look at this. Did you by chance check the Floppy Drive for a disk in there? I See you showed you had checked the cd-rom drive, but said nothing about a floppy (FDD) drive. SO please check there too. If that's empty, we'll go on from there and attempt getting into your BIOS. Any CMOS issues there can be resolved in the BIOS Setup. It's also possible that the controller isn't setup or is configured wrong in the BIOS. When you power-on your Compaq Notebook, press and hold the F10 button, until you see the screen "Bios Loading" (or something to that effect). If you are able to get to the BIOS Screen, you may be in luck. The Standard CMOS Features are divided into 11 categories. First check to see if the hard drive (Primary Master) is recognized. Arroe down to that, if not. On the "Primary Master", press the enter key. Is your hard drive present there? If so, you're 1/2 way there...if NO hard drive is present, you'll need to get your system to (hopefully) recognize it by setting the Prinary Disk to "Auto" and press Enter, and your system should then recognize your drive. If not, it may be that your drive is too large for the CMOS/BIOS to recognize. If all else fails, press F7, which SHOULD load the BIOS Setup Defaults. You may want to go back into the BIOS then, and set your date/time settings before exiting from your BIOS. Once all that's done, press F10 to Save, then press "ESC" to exit, then the system will reboot...and HOPEFULLY this will work. If you need more help, feel freee to contect me at my email address, so we can get more things done faster, rather then waiting and reposting on this website =) My email address is: bosscomputers@comcast.net Thanks!!
Posted on Jun 13, 2007
    President:
  • 2,961 Answers
Yes it's the disk controller thats at fault, you would need to check the controller, but if it wont boot you cant do that, so all as you can do at this point is look for a clr cmos, but not the battery as that doesnt always clear the cmos settings it will be a 2 or 3 pin terminal JBAT1 or CLRRTC or CLRCMOS which will need to be shorted. If you get into the bios after the clear cmos then you may have to check the drive is recognised in the ide o HDD section, if not, flash the bios which in its self is a last resort fix. Failing that the motherboard bus controller itself as in hardware may be damaged and only a mobo replacment will solve that.
Posted on May 23, 2007
SOURCE:
Compaq 671b wont boot
It sounds like you have a hard drive issue or the windows files are corrupted, if by chance you have a rscovery dics install it now, if no change! remove hardware and reseat back into place, still no result! laptop hard drive should be assessed for possible replacement.
Mar 10, 2012 | HP Computers & Internet
Why won't laptop connect to wireless internet? Wifi is working, another computer in home is fine
are you at home or Starbuck? location matters.
so, the compaq must be setup correctly.
your router broadcasts the SSID name seen by you on all devices, see that on the Compaq (y/n)
then you must pick wep. or wpa, or wpa2 encyption mode.
as set in your router, we cant see inside you router only you can
then set the passphrase to what you router wants.
is this XP, windows
does the wifi chip look ok in device manager?
Is XP infected.? with malware as all are now.
never post about computers lacking what operating system you have, or answers will be wrong, even all answers.
Feb 12, 2018 | Compaq Presario CQ62-215DX Laptop
When i type JKL; UIOP it apear on crean like 123-456* please tell me easy method to solve it
For me when I toggle the num lock key, this causes the issue you describe: jkll;uiop would spit out 123-456*. I am using a HP Pavilion DV9000 series laptop.
Oct 16, 2010 | Compaq Laptop Keyboard for HP Pavilion...
What is Dry Boot of laptop and how to perform it?
Dry boot is a way to reset HP laptops. Sometimes it works and sometimes not. Here is how to do it.
Disconnect the power cord, remove the battery, press and hold the power button for about a minute. Then re-insert the battery and power cord and try to turn it back on again.
If you are still having the same issue, remove the battery but leave the power cord and try to turn it on. Oh yeah, disconnect any USB devices and a monitor (if you connected a monitor to your laptop), make sure there is no disc in the drive either.
If this answers your question, I'd appreciate 4 thumbs. I do this for fun and do not get paid.
Jim
Oct 02, 2010 | Compaq Armada E500 Notebook
My Compaq sr1800nx desktop boots to a black screen with white text with the options of F1 setup or F2 continue instead of the normal boot up. If I select F2 it will continue and boot up normally.
Sounds like you have to open task manager. probably threw ctrl+del keys together. then once the task manager is open you have the option of typing explorer.exe
once the windows desktop apears go to start then run and type chkdsk c: /R this will recover bad files that are possibly missing from the boot volume. the issue happens when software tries to alter the master boot record where windows load's the operating files off of the main drive root partition. hope this helps you.
Good Luck
Aug 12, 2010 | Compaq Presario SR1800NX Desktop PC
My compaq evo nc620c laptop wont boot up, only goes to the "compaq" log screen from where I can go into F10 rom based setup or F12 network boot only.
Without having seen it, it sounds like a hard drive problem. Could be dead, could be the boot info has been destroyed (virus?).
ROM setup should be able to tell you more about the hard drive, and whether Setup can see it.
Apr 03, 2010 | HP Compaq Evo n620c Notebook
Startup/charge issue
hi.. unfortunately i've seen many cases like this and it looks as if from what you are describing that your laptop is fried if there is no boot up at all.. how old is you laptop and what brand is it?
Feb 19, 2008 | HP Compaq Presario V2000 Notebook
Desktop Display
Shut down the computer. Turn it on and during the boot process hit on F8 to get into Advanced boot option (if it skips try again after restart the computer), You will see the options. Choose "Last Known Good Configuration" and enter. It will probably will resolve the issue. If issue persist please post for further assistance.
Good Luck
Feb 03, 2008 | Compaq Presario M2000 Notebook
Problem: Cannot Load Windows/Windows Setup Does Not Detect Hardrive
My Hp Compaq tc4400 Does not load Windows and when i try to install a new one and error Message apears saying that it cannot detect any hardrive, but when i press F9 for boot selection Notebook Hardrive is dected and availble, i tried removing the hardrive and re-insert it also it dint work could somebody help plssss
Feb 01, 2008 | Compaq tc4400 Tablet PC (RL875AW#ABA)
Harddrive is most likely bad get another and install windiws... if you found the right place they could "ghost" your information onto the new one!
Compaq Armada M700 Notebook Logo
181 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
