Question about Guardian Rv Generator 4800 Watt, Gasoline, Primepact 50G
Guardian gen. won't start, I have to spray starter fluid everytime i want to start it up,help
3 Suggested Answers
SOURCE: guardian primepact 50g rv gen starts for 2 sec then shuts down
This story ends with bad gas and silicone in the gen tank
Posted on Apr 15, 2009
mamicheddy
  • 79 Answers
SOURCE: guardian rv generator
Your control board is faulty. Try to power up the ingnition coil as well as your fuel pump. If this does not get the engine running then you have major engine problems.
Posted on May 19, 2009
17 hp briggs stratton ohc
Clean or change air filter. Clean, gap or change spark plug. Empty gas tank add fresh gas with Stabil. When spark plug is removed pull rope several times to blow out cylinder. Spray starter fluid in spark plug hole before replacing spark plug. Clean outside of carb so choke works freely. Spray starter fluid into carb breather hole with air filter removed and try to start. if running replace air filter and cover. If no start disassemble carb and clean. If no start replace carb.
Jun 19, 2013 | Garden
Cub Cadet has gas, has spark, has air -still won't start/run
Are you pulling the plug to check for wetness after cranking it a few times, WITHOUT using the starting fluid? Also, I would recommend using carb cleaner in place of the starting fluid. Starting fluid runs the engine VERY hot for a brief time and can possibly damage rings, valves, and aluminum parts.
Jun 09, 2013 | Garden
Saw won't start without starting fluid.
Sounds like you have a compression problem. Starting fluid will fire at a much lower compression than a gas/oil mix so that's why it will start with it. When the motor is running you get a little more compression because the piston is coming up so fast. You should check the condition of your cylinder wall and piston & ring. If they are damaged at all you loose compression which directly affects starting and running power.
Mar 28, 2012 | McCulloch Garden
My 96 crown vic police interceptor, cranks won't start without spraying starter fluid.. the car won't start without spraying starter fluid into air intake hose to carb...
starting fluid is a thing of the past. dont use it. this car doesnt have a carb, its a throttle body/ electronic fuel injection system. you most likely have a fuel pump or fuel pressure regulator issue. test the fuel pressure, should be anywheres from 35-50 psi
Oct 11, 2011 | 1996 Ford Crown Victoria
1990 Taurus sta wgn 3.8. Sprayed starter fluid in EFI port, car started and ran for 5 sec, won't start again
Your limited information suggests that you're not getting fuel pressure to your system. Your use of the starter fluid suggests that you have been having starting problems. Can you describe what problems led you to this action? Based on what you've described, I would suggest checking your fuel pump, appropriate fuse(s), wiring connections, fuel lines and so on to make sure you are getting fuel under pressure in your system.
Aug 12, 2011 | 1990 Ford Taurus
1992 gmc Jimmy won't start without spraying
check the fuel filter first , then the fuel pump
Jul 15, 2011 | 1992 GMC Jimmy
Car has gas but won't start. Sprayed starter
the most likely reason is a failed fuel pump, plugged fuel filter or defective fuel regulator-you need to have the fuel line pressure tested-you can get the use (free) of a guage set from most commercial auto parts stores.
Jul 02, 2011 | 2000 Oldsmobile Alero
Guardian Rv Generator 4800 Watt, Gasoline, Primepact 50G Logo
Top Guardian Electrical Supplies Experts
 Kenneth
Kenneth
Roland W VanLue
Roland W VanLue
Are you a Guardian Electrical Supply Expert? Answer questions, earn points and help others
