Question about Garmin Rino 530 GPS Receiver
Tryin to take gps antenna off
Got unit wet company no longer repairs this unit i have back cover off need to know how to get antennas disconnected?
5 Suggested Answers
SOURCE: garmin astro 220 gps dogtracker
garmin, it seems to me that your techs should be able to correct this problem by mounting the antenna in such a way as to place it in a fixed position where it could not be turned internally and cause damage to the unit with a force as small as hand tightening.
Posted on Jun 08, 2008
reef runner
  • 7 Answers
SOURCE: My Garmin GPSMAP 76S will no longer accquire any satellites
I had the same problem? GPSmap76S was hung up trying to AutoLocate. It just couldn’t find itself, and it just stopped working all of a sudden one day, while I was traveling. I spoke with Garmin about the problem, and they advised me of an ongoing problem with WAAS. I was told that I should "Disable" WAAS, because the signal from the WAAS satellites had been changed by the government, and Garmin had not yet put out a software update to address the problem, on the 76 units, anyway. Also said that an update "should" come out, in the future, however, no commitment or promise on that. Evidently, once your unit hits one of the WAAS signals, it scrambles up the receiver in the GPS, because mine sure went crazy. The support guy also said, that if this did not correct the problem, I might also want to try a "Master Reset". So here’s what happened.
I disabled WAAS, but this did not correct the problem. The unit was still lost out there somewhere, trying to AutoLocate, so I ended up doing the “Master Reset”. Please read up on this procedure before trying it, and understand that you “will loose” any settings that you might have made to the GPS, along with all waypoints, routes, tracks, etc., however, my maps actually remained in tact? This procedure will actually set the unit back, just as it was when it originally came from the factory. Once completed, you will then have to allow the unit to initialize it's self again, just as you did when the unit was new. If you have forgotten about doing that, it simply means that you need to set the unit outdoors and leave it “on” for a while (15 – 20 minutes), until it actually AutoLocates it’s self, or locks in on your current position. Once this is done, re-do your setting preferences, back to the way you had them before the Master Reset. At the very least, you’ll have to re-set it to the correct time zone, and tell it about daylight savings time. Note: It’s a very good idea to go thru first, and jot down your page settings and main menu settings, before doing this procedure, or the screens may not look familiar to you, once the unit resets. You think you’ll remember them all, but you won’t. But whatever, once you have done the “Reset” and “Initialization”, you must now hook the GPS up to the computer and reload your waypoints, routes, etc, back to the GPS. You did have them saved on your computer, didn’t you? Hope so… If so, you should now be good to go…………….
My unit now works like a champ, good as new, just not as accurate, due to WAAS being turned off. I still don't know if the WAAS issue, was part of the problem or not, but I do know that the Master Reset got the unit back to working immediately, allowing it to locate itself almost instantly. What a relief…………..it’s a little work, but it takes much less time than it took you to read this post…………..
Hey, when all else fails, call Garmin 1-800-800-1020. They are good guys and willing to help, in fact, I would advise you to call them before you do anything, so you can describe to them, exactly what your unit is doing. I am only relating my situation and what happened to me. Your situation may be different……. .
Posted on Dec 13, 2008
SOURCE: When GPS is turned on unit locks up
I had losts of lock ups when flipping on the GPS - almost ready to get rid of the Garmin IQUE 3600 since it hasn't worked well for over a year. Sometimes it works a short time with the GPS; other times it was instant lock up when searching for satellites.
I took many steps to isolate the issue, and then added complexity to the equation: update to r6 (no change), hard reset, no user data on IQ3600 during testing, use only internal drive, only use basemap lite on internal drive, only use 1 local city on internal drive, load other maps on external card. Each time I went outside and flipped on the GPS to see if that was affecting the lock up.
Then I played with the GPS settings. The factor that seems to solve the issue: TURN OFF WAAS - it is intended to improve accuracy to 9 ft but it seems to have a bug.
Garmin
Ique 3600
Palm OS Release 5.2.1r6
GPS lock up crash bug
Posted on Feb 03, 2009
  • 4090 Answers
SOURCE: The gps looses satellite reception. Repositioning
DIY is risky in this situation, besides there is 3 months warranty by Garmin on their interventions I would suggest you get it done by the professionals
Posted on Jul 22, 2009
I have a SGX and have lost the antenna cover. Can I find a replacement?
Stay AWAY from the SGX. The quality control is really poor. I know of three other users having the same problem, the antenna cover falls off and the unit does not get satelite reception. It becomes a piece of junk. Once that unit got replaced, in less than 5 months, the rubber covering the knob that allows you to select items had a tear and now the unit is no longer waterproof. This is not covered under warranty and they want you to pay $89.95 for a replacement. I am done with SkyCaddie. I have just purchased the new Garmin G6, awesome device, no annual fees, long battery life and touch screen enabled.
Look at the following link to get other user experiences.
Amazon com Customer Reviews SkyCaddie SGX Golf GPS
Feb 09, 2015 | SkyGolf SkyCaddie SGX GPS Receiver
Satellites no longer acquireable
both the problems could be there mostly the chip corrupted.
Aug 29, 2008 | Garmin Nuvi 660 GPS Receiver
GPS will not work on my clarion NX500. After a cold night, the GPS thinks I am not moving, the satellite reception says it is stuck at 2 bars. The GPS diagnostic screen says it is tracking 0 satellites,...
I got the same problem, Clarion Canada says it is the antenna but I am removing the radio and bringing it to them to check out. Will report back when they let me know.
Jan 29, 2011 | Clarion NX500 Car Video Player
My Garmin Quest has stopped working. It is trying to acquire satellites and also 'drawing' appears on the screen. I have re-booted the unit and it still does not work. Any ideas?
If the screen is otherwise "normal" and it is just not able to acquire satellites, I am guessing you have a problem with the antenna. One way to determine that is if you got an external "patch" antenna, plugged it in and it started working as it should, that is definitely an antenna issue. I have run into several of the "flip up" antennas recently that have exhibited this problem. What happens is, the connector from the antenna breaks loose from the solder joint inside the antenna. If you have a small soldering iron, you can CAREFULLY pry the antenna case apart to access the connector and it is a simple matter to solder it back in place. You will need a very small screwdriver to pry the two outer sections of the antenna case apart. Wedge the screwdriver blade in between the two sections of the antenna covering. Pry the larger part (the part that would face the sky with the antenna at 90 degrees), and with CARE you can get it apart. The small gold connector solders to some circuit traces on the antenna board. To get the antenna off the GPS, place the GPS face down with the hinge part of the antenna away from you. With a small jewelers screwdriver, remove the right two screws on the back of the GPS on the right end. There is a small plastic retaining piece that holds the antenna in place. CAREFULLY lift it up and off the GPS. Be VERY CAREFUL at this point because there is a small spring loaded plastic piece that fits against the retainer piece you just removed. It is very easy to lose the spring and plastic piece if you are not careful. Gently pull the antenna to your right, away from the GPS. The antenna should pop out. If the connector has completely disconnected from the antenna circuit board, you may need some small pliers to get it off the GPS side of the antenna connection. Once you have the antenna removed, separate the antenna case as I described and resolder the connector back on the board.
Oct 16, 2010 | Garmin Quest GPS Receiver
My garmin 680 gps will not acquire a satellite
This is a problem I see very often and it is due to the flip antenna. Garmin is no longer using this style of antenna because moving parts equal less reliable. Anyhow, I have remedied the problem by plugging in an external antenna in the side of the flip antenna. Sometimes this works.
If that does not help it is time to get the unit fixed or replaced. To find the closest repair depot to you please contact Garmin 1-800-800-1020
Cheers
Jesse GPS
Jul 13, 2010 | Garmin Nuvi 680 GPS Receiver
My Nuvi 660 can not locate the satelites, please advise. Thanks.
There is a common problem in the antenna circuit that will cause the antenna to fail. To confirm this take a very small section of wire and carefully insert it into the center conductor of the external antenna jack, which is located on the side of the flip up antenna. By doing so you are essentially using the wire as an external antenna and the unit should get satellite lock. Do not continue to use the wire as antenna however. Garmin will charge a flat rate of $110 to repair it or you can send it to a reputable post warranty repair company like www.sharcnet-usa.com
Hope this helps you, safe travels.
Feb 25, 2010 | Garmin Nuvi 660 GPS Receiver
No satellite reception on garmin nuvi 350, garmin offer to repair i believe it may be the antenna as i did all the reboots do think if repaired the problem will persist
There is a possiblility that the antenna is defective. Sometimes a factory reboot helps or re-burn of the firmware. One way to confirm an antenna problem is to go into the tools menu and select "about". If the screen says "GPS S/W = 0.0 (should be a real number like 2.9 or 3.0) then this indicates that your antenna is not communicating with the main board.
- Jim
Sep 22, 2008 | Garmin GPS
Nuvi 350 cannot locate satellites
I own & operate the electronics repair company, Westek Electronics in Nashville, TN. We repair & refurbish GPS units among other things. We have repaired many nuvi 350/360 units with this issue.
This issue is typically due to a hardware malfunction and cannot be remedied by software upgrades, resetting, etc.
Do this test:
  1. Strip a ¼” of a wire twist-tie end (the kind found on bread wrappers) bare exposing the fine wire core.
  2. Power up your nuvi 350/360 and confirm that you are not receiving any signal.
  3. While still powered on, insert the bare-wire end of the twist-tie into the center female external antenna jack located on the side of the antenna. If done correctly the external antenna jack will firmly hold the twist-tie in place. You cannot damage the unit by doing this.
  4. If you now have satellite reception then proceed to step 5. If you still do not have any reception then I have no further advice other than to try all of the update/reset procedures. If all else fails return to Garmin for repair.
  5. Once you have established that you have signal using the twist-tie, remove the twist-tie and confirm signal loss.
Your choices to remedy this issue is as follows:
  1. Purchase & use an external antenna.
  2. Return the GPS to Garmin for repair ($175 if its out-of-warranty). Or,
  3. Send your Garmin Nuvi 350/360 to us for repair. We charge $55 (return shipping included) to repair this malfunction. We can also accommodate this repair transaction via eBay in order to provide you with additional reassurance (an addition $5 is added to cover eBay fees, etc. when using this option). Our eBay ID is westek_electronics, feel free to review our feedback ratings. Our repairs are covered by a 30-day warranty. If for some reason we are unable to successfully complete the repair we will return the unit to you and charge only $10 for return shipping. To initiate your repair contact us at westek12@hotmail.com.
Hope this helps.
Jul 13, 2008 | Garmin Nuvi 350 Car GPS Receiver
Internal GPS antenna won't turn off
I have the same problem after unit dropped on tile floor! Everything works well except gps turns on when I power up regardless of antenna position. Tried various resets -no fix.
Jan 19, 2008 | Garmin iQue 3600 GPS Receiver
Antenna socket
call tech support 1-800-800-1020
Oct 28, 2007 | Garmin StreetPilot 2620 GPS Receiver
Garmin Rino 530 GPS Receiver Logo
42 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
