Question about Dell Computers & Internet
Dell Optiplex Mother Board 0XG312-70821 dimensions
SOURCE: Dimension 8200 will not turn on
Elleth,
It's very possible that your power supply has gone bad. A friend of mine brought me a Dimension 8200 to look at a few months ago that was acting exactly like yours. At first glance, I assumed that the power supply was ok because the LED on the motherboard was lit up. I decided to check the power supply with a tester and found out that the only live lead was the +5 VSB (5 volt stand by) which explains the LED being on. I replaced the factory 250 watt power supply with a 350 watt and it happily booted up. Keep in mind though that you may need to make a slight modification in order to use a non-Dell power supply. I had to make the opening in the back of the case slightly larger so I could plug the power cord into the power supply.
Good luck,
Mark
Posted on Jan 23, 2008
  • 38 Answers
SOURCE: Dell Dimension 8300 wouldn't start
Sounds like a power supply. You are getting the standby voltage and not the switched. plug all your wires in except the big 20 or 24 pin motherboard connector, take a small wire and short the green (PSU_ON) to black (ground) wires. This will simulate the computers "ON" signal. The fans should all spin up and your plugged in accessories should work, which means bad motherboard, if not bad power supply.
Posted on Mar 24, 2009
alexgalapin
  • 148 Answers
SOURCE: Won't boot
1. STEP: Ensure Correct Power Button Is Used and Is Not Sticking or Broken. If the power button remains depressed during the power-on attempt, the computer immediately powers off, mimicking a "no power" symptom. Ensure the button is not being held down too long or binding against the bezel or chassis. If necessary, remove the front cover to press the button directly.
2. or else...STEP: Check the Power Button LED on the Front of the Computer (on Blinking yellow)
Initial state of LED at power up.
Indicates system has power, but the POWER_GOOD signal is not yet active.
If the hard drive LED is off, it is probable that the power supply needs to be replaced.
If the hard drive LED is on, it is probable that an onboard regulator or VRM has failed. Look at the diagnostic LEDs for further information. or lese..
3. STEP: Restart the Computer Using the Power Button.Press and hold the power button down until the computer powers off. This should not require more than 10 - 15 seconds.Press the power button to turn on the computer.
4. STEP: Verify the Power Supply Voltage Selector Is Correct for the Region. Verify the setting for the power supply:
*Unplug the power cable from the back of the system. *Press and hold the power button for at least 5 seconds to discharge remaining power.*Inspect the voltage selector setting on the back of the machine (Figure 1). Ensure that the voltage select is set in the correct position for the region the in which the system is operating: For Europe and Asia, the voltage setting should be 230V.In North America, Mexico, parts of Central and South America, and parts of the Caribbean, the voltage setting should be 115V.*Plug the power cord back into the back of the system.*Turn on the power.
STEP: Try a Different Known-Good Wall Outlet.
STEP: Remove All External Devices. Turn the system off.
Unplug everything from the front and back of the system except for the power cord or AC adapter, including: keyboard mouse monitor speakers printers scanners USB devices handheld PDAs external Zip or CD-R drives joysticks/game pads, etc
Attempt to turn the system on.
Blinking Amber/yellow: Initial state of LED at power up.
Posted on May 02, 2009
rjblittle
  • 54 Answers
SOURCE: dell dimension 2350 shuts off after a few minutes
You could try opening the pc and blowing out the dust.
Posted on May 09, 2009
  • 3940 Answers
SOURCE: Enquiries on maximum supported hard disk capacity and memory
Dell Optiplex 760 Vista
Max CPU Intel Q9550
Max RAM 8GB RAM
Largest HDD Shipped 1TB (Will likely Support 2TB)
Optiplex GX260
Max Intel Northwood 2.53 GHz - 533
Max RAM 2GB
Largest HDD Shipped was 200GB (Will likely support 500GB)
Dell Dimension XPS D300
Max CPU 333 Pentium II
Max RAM 384MB
Largest HDD Shipped 16GB (Will likely Support up to 80GB)
Dell Dimension XPS M
Max CPU 166S
Max RAM 64 MB
Largest HDD Shipped 4.3 GB (Max HDD likely 20GB)
Posted on Feb 09, 2010
Can i change out the motherboard on my dell dimension 4600 and use the one from my optiplex gx 520 in place of it.
No you can't. The Optiplex system board is a BTX type, and the Dimension uses an ATX style. The BTX board was supposed to be the new standard, with the layout changed to improve cooling air flow. Unfortunately, the I/O connectors (keyboard, etc.) aren't in the same place as on ATX boards, and you can't just drop the BTX board into the same case. (This is one of the reasons the new design didn't catch on. Seems people didn't like the idea of shelling out for a new case as well as the board.)
May 28, 2011 | Dell Optiplex GX520 (XG309) Motherboard
I have dell desktop PC BMQVSOJ and model MTC2 ,made on ,july29, 2003. i need to buy new motherborad, how?
If you need to buy mother board then go to computer shop nearer to your home or in city and my request to purchase dell's optiplex mother boards.
Mar 19, 2011 | Dell Dimension 2400 PC Desktop
Went from a Dell Dimension 8250 to a Dell Optiplex GX280
Check for updated drivers and install if available. If that does not resolve the issue completely remove the card and any software and drivers and do a clean install with the new drivers
Apr 25, 2009 | Creative Labs Creative Sound Blaster...
Bought refurbished dell optiplex 260 w/o operating system
The problem might be with the video card of the system as it might have gone bad. & as far as my knowledge about DELL Optiplex series is concerned they come with a integrated video card. So the problem might be with the mother board...
Jan 13, 2009 | Dell OptiPlex GX620 PC Desktop
Picked up a DELL OptiPlex GX1 ? ID the Mother Board
go to Dell.com and select suport an download.
enter the model number and the serial number or service tag (rear of the machine).
you should be able to get the original configuration of the machine. Provided that nothing has changed since it left the factory.
Dec 01, 2008 | Dell Computers & Internet
DELL motherboard drivers
if you want a driver for yourdell mother board you can download call the dell support centre they ll send you or else you can download through http://supportapj.dell.com/support/downloads/this is the dells site they ll ask about the model and service tags......
Mar 12, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600C will not power up
Sounds like the power supply is faulting. If not it is your mother board that has failed.
Mar 06, 2008 | Dell Dimension™ 4600C PC Desktop
Computers & Internet Logo
18 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
