Question about Stanley Bostitch N80s Nailer -rebuild Parts O`ring & Seal Kit
Can I use paper collated nails in my Stanley N80s b-1? The nails meet all other required specs.
    President:
  • Stanley Master
  • 1,388 Answers
Paper collated will work. Maze nails part # PCP28325131 works on many 28 degree guns including yours. Only advantage that I can see with using welded is that the nails will take more abuse on the job site including getting wet. Paper collated can brake apart easily but dont worry too much about the difference. I would buy the least expensive or available but I like the idea of using made in USA of maze nails (not available on all areas of US). Good luck
Posted on Nov 10, 2012
5 Suggested Answers
  • 3 Answers
SOURCE: N80S won't completely sink #12 nail
it sounds like its not oiled enough possible bent piston due to jamming.
Posted on Feb 20, 2009
  • 3 Answers
SOURCE: Stanley bostitch coil nailer gun
check the safty shaft and see if something could be under trigger safty causeing it to fire.
  • 84 Answers
SOURCE: have a stanley bostitch framing nailer. Nails
Normally, yes- depends on how old the nailer is. But first, let's ask: are you getting at least 90 psi of pressure to the rig?
If so, you may adjust the nailer with an allen wrench, or with a thumbwheel, both of which are located near the firing mechanism.
IMPORTANT: before you mess with it, be sure no pressure is left in the unit, otherwise you may be on here asking how to extract a framing nail from your skull while your hand is attached!
Posted on Nov 25, 2009
  • 1584 Answers
SOURCE: stanley coil roofing nailer not sinking 3 1/4
That model may not be designed for that length nail. Check with your local supplier.
Posted on Mar 10, 2010
Can My FC 350 A used 28 degree nails
The manual for your gun specifies 34-degree nails from 2 to 3 1/2 inches long. 28-degree, wire collated nails are a Stanley-Bostitch thing and they only work in their nail guns, they will not work in your nail gun. You need 34-degree, paper-tape collated nails. I know Senco framing nails will work in your gun and I think Duo-fast makes 34-drgree nails but check that before buying them.
Mar 03, 2013 | Porter Cable Factory-Reconditioned...
Senco fram pro 602 nail gun firers but no nail just a hole from firing pin
First, check that you are using the proper nails. The FP602 needs Full Round Head nails with plastic collation. If you are using Clipped Head nails with the paper tape collation the angle of the nails not let the driver catch the next nail and drive it into your work.
If you have the correct nails, check the magazine to make sure the nails are feeding all the way up to the driver. If there is anything blocking the way or if the spring on the feeder isn't taught enough to pull the clip all the way up the driver won't be able to catch the next nail and drive it in.
May 05, 2012 | Senco Tools & Hardware - Others
Bought hitachi nr90ad nail gun and it isn't firing right..what exact size nails should i get ( as in 35,33,or 30 degree nails)
Use 34 degree, paper collated, clipped head nails. They were always the most common strip nails years ago as Senco, Paslode, and a number of other nailers used them.
Jul 25, 2011 | Hitachi NR90AD 3 - 1/2'' Clipped Head...
2 nails shoot at the same time
It could be just from using poorly clipped or collated nails. I have noticed that with some cheaper nails, the clipped heads are not all lined up properly. If a nail has rotated slightly during the collation proccess, the unclipped portion of the nail head protrudes over the previous nail in the clip. This causes the heads of two nails to be struck at once. Another problem I've encountered is collation wire that doesn't shear off with each nail. An ever lengthening strand of wire protrudes into the nail chamber and eventually the driver snags this wire as it drives a nail. This jerks the clip forward forcefully forcing more than one nail into the chamber or causing the next nails in line to rotate slightly, thus exposing the unclipped portion of the nail heads to the driver.
Mar 13, 2010 | Tools & Hardware - Others
What is the angle of the nail we use with this nailer
if thats a hitachi nr90ad, then you should be using 30 degree paper taped clipped headed nails,, never use plastic or wire collated nails in that gun,, some boxes might say 30 up to 34 degree and thats fine, also in a lot of areas clipped headed nails are no longer code, so they made the nails full headed, the head is just off set,,
Dec 04, 2009 | Hitachi NR90AD 3 - 1/2'' Clipped Head...
Nail compatibility with Milwaukee framing nailer
any full round head with a 22 degree angle and plastic collated nail between 2 to 3 1/2 inch should work, they don't list any other specific brand but these are the requirements for the tool.
Oct 23, 2009 | Milwaukee Tool Air Tools & Compressors
For the Dewalt d51844 can you use PAPER or plastic collated nails
Yes you can generally interchange the two (paper vs plastic collated) as long as the nails meet the specifications (and collated angle) specified by your nail gun.
Please rate this solution on FixYa!
Thanks.
Apr 01, 2009 | Dewalt D51844 Framing Nailer
Feb 19, 2009 | Stanley Bostitch N80s Nailer -rebuild...
Stanley Bostitch N80s Nailer -rebuild Parts O`ring & Seal Kit Logo
73 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
