Its says on sights that windows xp does not recongise sada harddrives
Its says on sights that windows xp does not recongise sada hardrives,so before i begin to attempt to change the harddrive does anyone know a step by step guide for "dummies" that i could use so it recognises xp?Thankyou : )
  • 2,878 Answers
You just need an updated XP SP3 installation disc. No special instructions are then required. This was referring to a new OS install, with new SATA drives. Right?
Or, make sure you are updated and add a second drive as normal.
Posted on Nov 09, 2012
Hardrive removal
Simple as pie... you will see the harddrive mounted horizontally in a small shelf after you tae the cover off. You have to unscrew the philips screws that hold it in the shelf and unplug the connectors. make sure you label the wires so you know which ones came from that harddrive... they is usually room for 2 harddrives and two complete sets of connectors, don't mix them up. (One is the master and the other called a slave.) There is an adapter for the harddrive that you should always keep should you need to replace the harddrive, (comes in two pieces on either side) the new ones don't come with the adapters to fit them in the case; they are bare bones. If you don't want to go through the gymnastics of taking the other tower apart and installing the 2nd harddrive in it to read it... an internal HDD adapter can be purchased from Tiger Direct for a nominal cost. I allows you plug you internal HDD into a USB socket in any PC (desktop or laptop) and read it as you would a Flashdrive.
Jun 02, 2014 | Gateway E-4300 E4300 Matxhrn Lux Pc - XP...
Problems loading OS in Gateway desktop
Normally installing the os on a different mechine, and then putting into another pc dosent work.
If the hardrive is the oringinal drive, which came with the system, and you want to install xp on, you will have to use a dos disk with fdisk on it, delete all partitions on the drive and create a new partition, then start loading windows, it will give you the option to format the drive for nt(ntfs) file system and setup windows.
If you do that and it still gives you protecting files error, you will have to take the side panel of the computer tower, unplug from the mains and take the cmos battery out for about 30 secs, put the battery back in, plug in the mains and reboot the computer, start loading windows again
Hope this helps and post back if you need further assistance.
Feb 19, 2010 | Gateway GT5220 PC Desktop
I need to reformat a dead harddrive
Hi there !!
Method 1: Perform a clean install of Windows XP loadTOCNode(2, 'resolution'); A clean installation consists of removing all data from your hard disk by repartitioning and reformatting your hard disk and reinstalling the operating system and programs to an empty (clean) hard disk. For more information about important things to consider before you partition and format you hard disk and how to partition and format your hard disk by using the Windows XP Setup program, click the following article number to view the article in the Microsoft Knowledge Base: 313348 (http://support.microsoft.com/kb/313348/ ) How to partition and format a hard disk in Windows XP To perform a clean installation of Windows XP, follow these steps:
  1. Back up all important information before you perform a clean installation of Windows XP. Save the backup to an external location, such as a CD or external hard disk.
  2. Start your computer from the Windows XP CD. To do this, insert the Windows XP CD into your CD drive or DVD drive, and then restart your computer.
    Note To boot from your Windows XP CD, the BIOS settings on your computer must be configured to do this.
  3. When you see the "Press any key to boot from CD" message, press any key to start the computer from the Windows XP CD.
  4. At the Welcome to Setup screen, press ENTER to start Windows XP Setup.
  5. Read the Microsoft Software License Terms, and then press F8.
  6. Follow the instructions on the screen to select and format a partition where you want to install Windows XP.
  7. Follow the instructions on the screen to complete the Windows XP Setup.
If you have successfully installed Windows XP, you are finished. If these steps did not help you install Windows XP, go to the "Next Steps" section.
Here's the link that contains the screen shots as well:
http://www.buildeasypc.com/sw/windows_xp.htm
Try these steps & hopefully you will be able to format the Harddrive.
Regard's
Anurag Shukla
Sep 03, 2009 | Microsoft Windows XP Professional With...
Mecer wont load wi xp sp2 on 160gig hardrive
The BIOS is seeing the drive but your computer can only see about 120-130 GB of harddrive. If the drive has a pin option to limit it's size you may be able to limit it then install windows but if it doesn't you're back to looking for a smaller drive.
Hope this helps
Chris
Aug 17, 2009 | Computers & Internet
Windows xp will not boot
If you just installed windows then take the cd out and let the computer reboot on its own. Windows will ask you to replace the OS disk later.
So just restart the computer with nothing in the CD drive.
Also make sure in BIOS that the Hard drive is the first boot device. Don't need the CD drive as first anymore.
See if that helps.
Brian
Jul 09, 2009 | Intel Computers & Internet
AX4SPE-UN doesn't enter CMOS
Hi
It might seem like you are having a problem with your harddrive. It might have failed or maybe some cabling got loose. I would first try to check the cables connected to your harddrive and make sure they are securely connected. If this doesn't help then the hardrive might be dead, and you need to get a replacement.
Hope this helps.
Mar 13, 2009 | AOpen Computers & Internet
Toshiba A135-S4656 Hardrive Not being recongized
Check to see if the hard drive is recognized in the bios. If it is, try reloading the computer from the recovery disk supplied with the computer. This will take the computer back to the original factory state.
Mar 12, 2009 | Toshiba Satellite A135-S4527 Notebook
Installation of windows xp on vista
Reformat the hard drive first using. Take VISTA off.
Jan 10, 2009 | Microsoft Windows XP Professional With...
Install windows XP on toshiba satellite U300
Hello
The windows Xp installation doesent find your hardrive because you have a sata drive. you need to adjust the settings in the bios so the sata drive appears as a ordinary IDE drive(ide native) or something like that. search in the bios settings.
A other way is to burn a new winxp cd with the Toshiba Satellite U300, sata drivers.
download the http://www.softpedia.com/get/System/Back-Up-and-Recovery/Barts-PE-Builder.shtml
and download the toshiba harddrive drivers and creat a new cd.
but the simples way is to make the change in bios.
good luck
Aug 18, 2008 | Microsoft Windows XP Professional With...
Compaq presario 1685 is this particular system xp compatible.
Unfortunately, the Hard Drive size is only 4.3 GB, while WinXP takes 3 GB and requires at least 5 GB to run. Even if you did have an external Hard Drive, the amount of RAM is not enough to let you do anything. Stay with your current OS or get a new PC.
Feb 05, 2008 | Computers & Internet
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
