Question about IBM ThinkPad T40 2379 Notebook
Say's it's connected, but it's not
I have a ThinkPad 2379. We took it on a vacation last summer and my son changed the connective network to the hotel's wireless network (they talked him through it) I manually changed it back to 2WIRE at home and it says it's connected (star and everything) but it's not connecting to the net.
There is seven months of upgrades (AVG, Windows) that it can not install.
The signal light is green.
What do I need to do?
  • 4tmore Jan 05, 2009
    Thanks for your prompt response.
    I powered off and that did not help. This laptop has been unusable since last July so it's just been sitting in my closet. HOWEVER, I have more information.
    I ran a Repair from the wireless network icon and it gave me this message.
    "Windows could not repair the problem because the following action could not be completed.
    Clearing the ARP casche"
    I have no idea what that means but it must be significant. Is this information helpful?
    PS. Power down did not fix it. I am running Network Diagnostics for Windows XP right now.
  • 4tmore Jan 06, 2009
    Thank you for your comment. I am using XP. The Diagnostics just told me to call my IP.
  • IBM Master
  • 4,806 Answers
Hi there
Try resetting the modem by removing power for a minute and then power it on, leave it to reset for a minute and then try to connect again
post back if no luck
good luck and kind regards
Posted on Jan 05, 2009
  • Lee Hodgson
    Lee Hodgson Jan 05, 2009
    are you using XP or Vista?
Wireless thinkpad t30
Need a little more info to be helpful. Did the computer ever connect to the network? If so what was changed?
Jan 24, 2014 | IBM ThinkPad T30 2366 Notebook
Thinkpad having limited to no connectivity
More than likely your password is wrong or the Authentication Type such as WEP, WPA, WPA-2 is wrong.
For Windows XP below:
Click Start/Control Panel/Network Connections then Right Click on the Wireless Network Connection and select Properties. When the Properties window open click the Wireless Networks tab. Click on the SSID for your wireless network that you connect to and the Properties window will open. You can change the Authentication Type to match the type set in your wireless router and you can also change your password or Network Key to make sure you have it in correctly.
For Windows Vista below:
Click Start/Control Panel/Network and Sharing Center then look to the left of the open window and click Manage Wireless Networks. Find the SSID of the network that you connect to and double click it. When the window opens click the Security tab to change the Security Type (which is the Authentication), The Encryption Type and the Network Security Key (which is the password).
For Windows 7 below:
Click Start/Control Panel/Network and Internet/Network and Sharing Center then look to the left and select Manage Wireless Networks. Find the SSID of the network that you connect to and double click it. When the window opens click the Security tab to change the Security Type (which is the Authentication), The Encryption Type and the Network Security Key (which is the password).
May 11, 2012 | Lenovo ThinkPad T420 Notebook
I have an IBM T40 (2379). Sometimes it boots up, sometimes it doesn't and beeps 4 times at me, but the real problem is that the screen will come on for 3-4 seconds, and then shut off. What could be my...
Beeps usually mean there is a problem with your system hardware. 4 beeps usually mean a memory failure, but beep codes vary. Google "beep codes" to get a list of meanings. Lenovo Support has several pages for this. Try HERE
Sep 28, 2010 | IBM ThinkPad T40 2379 Notebook
Wireless network
remove the wireless profiles on the PC and see if that helps - [b]Wireless Profiles
  • http://mgmcc.forumotion.net/networking-tutorials-f17/removing-an-existing-wireless-profile-t109.htm
- Vista/windows 7
  • http://www.tp-link.com/support/showfaq.asp?id=214
- delete the wireless profiles Start control Panel classic view network and sharing center manage wireless networks
Delete the profiles you will then have to enter the wireless security key for any networks you connect to
Apr 11, 2010 | Dell Studio 17 Laptop
Cannot click ''Connect'' to join Wi-Fi network
This is because it is remembering the "Old" settings which must have been saved as default. What you should do is run the Connect to Internet again, this will reset the network settings and connect. Also make sure to go into networking and ensure the settings are right in there regarding sharing, permissions etc, etc.
Mar 04, 2010 | Computers & Internet
I am trying to connect my sons laptop to the wireless internet that I have .I have refreshed the wireless network connection and it says make sure the wireless switch on your computer is on. where is the...
What is the model of yuor laptop?
There will be wireless switch at the base of the laptop - turn it on. If still nok- - check system tray on the right hand side - you will find wireless switch utility there - enable wireless
Thanx
Sep 14, 2009 | IBM Thinkpad T40 Thinkpad T41 Thinkpad T42...
Open the computer
You stated that the power cord connection on the computer is loose, but if it operates while connected to the external power supply that would indicate to me that the connection is working. My thought at this point is either that the battery is not accepting a charge, indicating a defective battery, or that there is a problem with the motherboard that is preventing the battery from charging.
Nov 26, 2008 | IBM ThinkPad T40 2379 Notebook
Boot problem
check it on bios whether the hard drive is detecting or not, if detecting then recover OS using recovery Cd
Nov 15, 2008 | IBM ThinkPad T40 2379 Notebook
Linksys wireless-g
It has nothing to do with the brands. I do have different peripherals of different brands and they work well.
Maybe your son's laptop is more recent than yours. When you connect the wireless adapter to your laptop, does it detect the wireless network? I remember having a similar problem on vacation. At the hotel, I could'nt connect to the wireless network. The tech support told me to adjust some settings on my laptop. He said to go to the Network connexions, right-click on the wireless connection and selection Properties. Click on Configure...And select the Advanced button. Then on the list select Power on saving Mode. Other than Max power save mode.
Sep 06, 2008 | Televison & Video
? Network problem
This is generally a driver glitch. Check to see if the wireless card is receiving a signal. If not, then uninstall the wireless drivers from the device manager and reboot. Th machine will find the card and reinstall the drivers. If it does see a signal, but won't connect, then try plugging in with an ethernet cable to see if it will connect. If it doesn't connect with the cable, then uninstall the network controller drivers and reboot. If the problem persists let me know and we'll try another approach.
Jul 23, 2008 | IBM ThinkPad R40 2722 Notebook
IBM ThinkPad T40 2379 Notebook Logo
55 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
