SOURCE: Error 3-397 Xerox DC 12
Hello, I have a Xerox DC 12 and i receive the error 3-308
Someone can you help me or information about me ???
Thank you.
SOURCE: xerox 6120 printer fuser jam
Thank you for your time. I appreciate your help. Your response is consistent with my experience of removing screws and trying to access the fuser without jeopardizing/damaging any components.
This afternoon, Tech support at Xerox avoided the fuser access issue entirely by offering to replace the printer within three days under my existing warranty. I have only to remove my cartridges and place them in the new unit. This is most certainly an equitable solution and one that acknowledges the good sense of your evaluation: It was just too ambitious a task for this rookie.
SOURCE: xerox phaser 6120 laser printer paper jam fuser
You can remove the imaging unit, then
Depending on the stock being used for the job, raise or lower the left and right colored Fuser separator levers. The levers will stay in the raised or lowered position on their own.
the levers are green. The fuser itself is not easy to remove.
Do you have any warranty left on the machine? Or a depot repair agreement?
SOURCE: paper jam
I had the same problem kept getting an error something like Jam at Exit Door Open Door A. When I looked at the top of the where paper normally comes from and flipped it open I found a super crinkled piece of paper, which once removed cleared the jam.
SOURCE: Our XEROX Worcentre 4150 often jams and displays a
In the main door at the top in the middle there is a little black leaver that moves up and down if it gets stuck in the up position it thinks that there is a papper jam just check the little black lever and make sure its down
