Question about Pride Mobility Products Health & Beauty
How can I get the manual for an axs 33 mobility scooter
I need to find a manual for this scooter
4 Suggested Answers
  • 11 Answers
SOURCE: User manual for shoprider madrid mobility scooter
Go to the Shoprider website and look for the scooter. It might have a different model name than the one you own. Get the name and click on the user manuals for the model that resembles yours (PDF file) and print.
Posted on Apr 02, 2009
bunnydawg
  • 5158 Answers
SOURCE: manual for sterling elite 4 mobility scooter
i haven't been able to locate a manual online however here is the company website http://www.sterlingscooters.co.uk/index.asp email them or call them they may be able to assist you. keep in mind many companies won't offer support for products bought on ebay.
robert
Posted on Sep 08, 2009
Testimonial: "thanks for the answer so quick il phone them tomorrow"
  • 19 Answers
SOURCE: info neede for mobility scooter
http://www.scootamart.com/mobility/mobility-scooters/heavy-duty-8mph-mobility-scooters/sterling-elite-xs-4-mobility-scooter.html
Posted on Oct 02, 2009
Testimonial: "I had given up hope after mailing several company's asking for the number for the scooter, which was met with no answer, then this morning I cam to mai"
Keys I needs keys for my AXS SCOOTER 33
Go to the main dealer and buy some.
May 18, 2017 | Health & Beauty
What type of batteries does this model take?.jb.
you need 12v 33ah sealed deep cycle battery most likely it may need two batteries any thing above 33 amp hours would also be ok. A higher Ah the longer the batteries last. This information on the type of battery is from the user manual.
http://www.hardwarexpress.co.uk/rascal-388-mobility-scooter-battery-1949-p.asp
Any battery type store should be able to supply this to you .
Feb 10, 2015 | Electric Mobility Rascal Scooter...
The battery is not charging
Unfortunatly, your batteries need to be replaced. The batteries contain a gel that needs to have current run through it on a regular basis (at least 8 hours once a week) or it will solidify. If you attach the charger, what will most likely happen is the green light will either stay green or go to green after a very short time. The charger will indicate the batteries are full, but instead of being full of pwer, they are full of crud. Your warranty will most likely not cover replacment as this is due to customer neglect, but your insurance may still cover the replacement if you can wait for the process to go through. Otherwise, you will need to replace the batteries on your own, MOST LIKELY type U1, 24v 33 amp, confirm that with your owner's manual or by calling the manufacturer. Good luck!
Oct 27, 2010 | Pride New Mobility Victory XL 4 Wheel...
Missing manual Do you know where I can get a manual for Freerider Kensington mobility scooter thanks Dianne
I need a manual and wiring diagram for a electric mobility mobility electric power scooter wheelchair model chauffeur 230
Jul 01, 2010 | Electric Mobility Mobility Electric Power...
Scooter will not move forward or revese,it makes a split second contact then stops
When mine does this it means she is not fully in gear. Try manually moving it back and forth a few inches and see if it clicks in.(Like moving the seat back in the car and it doesn't quite click in.) If it doesn't work take it fully back out of gear and try again.
You could also try checking the key is in straight, and that all the cords are plugged in tight. You may need a hand with this, as you need to lift the chair off, (Straight up) and then the cover of the back section, removing the locking pins as you go. My loocking pins tend to get very stiff and I cant pull them out myself due to arthritis:)
If all else fails, check the troubleshooting page (33) of the manual, available in pdf at
http://www.rentascooter.com/downloads/_manuals/pridemobility/Pride%20Victory%20Owner's%20Manual.pdf
Hope this helps.
May 05, 2010 | Golden Technologies Companion II Travel...
AXS Mobility scooter loses battery power quickly.
hi , two problems can cause this,
1. batteries are weak, is the charger ok ? just because it 's green does not mean the charger is ok, can you validate the charge, try some other batteries ?,
2. Brake be activated or on at all times,
The best way to prove this is to remove the brake mech from the side of the motor completey now try the scooter, if the problem goes away then check the resistance of the brake, is it open or shorted ?
If you feel the brake, batteries and charger are working ok then the controller must be activating the brake and this is the fault but please double check the voltage on the brake leads.
Regards
GeWiz.
Jan 11, 2010 | Pride Mobility Products Go-Go Elite...
Need manual for celebrity x mobilty scooter
Go to cheapest-scooters.co.uk Then click on photo of celebrity x sport mobility scooter.Then scroll down page and click link to download owners manual. Hope this was helpful?
Sep 24, 2009 | Pride Mobility Products Celebrity X - 3...
Wont move beeps several times battery dial shows full
Check the "neutral" lever just above the right rear wheel. It is probably not engaged. If the Go-Go rolls freely, that is the simple fix. If that isn't it, look at your manual on page 33 for the beep codes to tell you what's wrong. If you don't have the manual, here is a link to the free download site...
http://www.pridemobility.com/pdf/Owners_Manuals/US_Scooter/US_Elite_Traveller_om.pdf
Sep 02, 2009 | Pride Go Go Elite 4 Wheel Traveller...
Health & Beauty Logo
115 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
