Canon Photo copier IR2020 error says change paper size
SOURCE: settings for printing a borderless 8x10 on a canon i9900
Downloaded following program for Vista and was able to print borderless pictures on Canoni9900
Easy-PhotoPrint EX Ver.2.0.3 (Windows Vista/Vista64/XP/2000)
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=232&modelid=9870#DownloadDetailAct
Posted on May 25, 2009
  • 92 Answers
SOURCE: canon ir 2016 digital copier
you can have 1 of 2 problems.
the cassete paper are in A4 position ,or you can trie to clean the registry roller.
Posted on Nov 02, 2009
SOURCE: Canon iR1600 incorrect paper size problem
change te paper size reader on the front saite on copier ( or cleaning the contacts on the same reader )
Posted on Nov 27, 2010
SOURCE: system error 007 in Canon
Replace the fiximg heater unit
Posted on Jan 19, 2011
  • 165 Answers
SOURCE: paper jam/open left / drawer cover canon ir2020
check the route sheet to the oven tray.
check all sensors on the route, as I remember are three in number.
check to be all clean and properly positioned
http://uploading.com/files/48b21612/...52CiR2016.pdf/
from this link you can download the service manual.
Posted on Mar 09, 2011
How can i reset a system error E007
Good answer here:
http://www.mytechtime.com/2011/10/canon-error-e001e002-e003-e007.html
<quote>
How to reset E000, E001, E003 and E007
Canon IR2016, IR2020
Enter the service mode by pressing "additional function" key, "2" and "8" keys in that order. SSSW will display. Press "OK" key.
Change Bit switch 1, bit 0 (might display as the first one on the left using number keys) status, (change 1 to 0 or 0 to 1).
Press "OK" than Press "Stop" or "Additional Function key" to end service mode or restart the machine.
</quote>
Jan 20, 2015 | Canon IR2020 Copier
Tip
Incorrect paper size while copy in progress for Canon iR2016 series.
Regarding pick-up error "change paper size"or "incorrect paper size" while copy/print:
These may do the trick:
Point of problem:
Paper Pick-Up Assembly
Problem:
Prevention of incorrect Paper Size Error or Pickup Assmbly Delay Jam (0104) upon Cassette Pick-up
Behaviour of copier:
When making a pick-up setting as from the Cassette and starting Copy, "incorrect paper size" error or pick-up delay
jam (0104) may occur.
Possible reason:
When considerable amount of Paper Lint is attached onto the Vertical Path Roller , the feeding power is
undermined and the paper feeding is delayed, resulting in "incorrect paper size" error or "pickup assembly delay"
jam.
Servicing work:
When the foregoing symptom occurs, be sure to replace the 27T/50T Gear [old type] with the 33T/50T Gear [new
type] and the 29T Gear with the new type simultaneously.
Affected machines are:
iR2016J 120V KQW00838 and later iR2020 230V KRS02060 and later
iR2016J EUR 230V KQX19105 and later iR2020i 120V SRB03779 and later
iR2016J 230V KQY08575 and later iR2020i EUR 230V SRC03634 and later
iR2016 EUR 230V KRB61503 and later iR2020i 230V SRE00245 and later
iR2016J EUR 230V TXK10815 and later iR2016i 120V SRH01205 and later
iR2016 120V KRE05112 and later iR2016i EUR 230V SRJ04494 and later
iR2016 230V KRJ07227 and later iR2016i 230V SRL00298 and later
iR2020J 230V KRM01592 and later
iR2020 EUR 230V KRP16433 and later
iR2020 120V KRR07615 and later
on Apr 12, 2011 | Office Equipment & Supplies
Want to change language of photo copier machine canon ir2020
Eneter in the user mode or in menu mode and select language.
Feb 05, 2013 | Canon Office Equipment & Supplies
Photo copier error saying "load
the copier has adjusting nods on the trys.adjust these to the size of paper you have loaded.that is A4,A3 and so on .
May 14, 2011 | Canon imageRUNNER 4570 Copier
I bought canon printer MF4150 from Singapore. The problem is when i print or photo copy A4 or legal size after 1 printer it errors and said load proper size @ MP tray
The printer may have a setup for a region which will change the paper size. Also the paper tray may need to have the paper size adjusted on it physically. Save the paper size in the preferences to A4.
Nov 17, 2009 | Canon imageCLASS MF4150 All-In-One Laser...
Error E02530 on Canon W8400 PG
Hello
when i load a material in printer, it shows me this error E0200B (size undetected) i loaded another photo papers and photo rolls but it steel show me the same error.
what should i do to solve this problem ?
thank you
Oct 27, 2008 | Canon imagePROGRAF W8400 InkJet Printer
Canon Error Eoo7
This error code indicates to the copier that the upper fixing film on the fuser assy is not rotating. Paper wrapped around the fixing film or the film itself is damaged may cause this. Unless you are very mechanically inclined , it will take the removal of the fixing assy and possibly the replacing of the fixing film assy. A tech would need to be called in to correct the problem. The fixing film is a replaceable item. Good luck.
Sep 26, 2007 | Canon imageRUNNER 8500 Copier
k24674
