Question about Ovens
Noisy vibrating oven fan on brand new appliance (Baumatic BCD901SS)
The rear access panel, when pressure is applied by hand, stops the vibration and noise, but it immediatly returns when pressure is released. It stops when the oven fan is turned off !!
4 Suggested Answers
SOURCE: JTP15 GE Oven - vibration noise
We have a double ge wall oven. The vent fans had become really loud. I checked the price for new fans...$275 each! Plus service of $200. If your oven is not too old, go to GE service purchase a 1 year service contract for $93.00. Wait one one month till it takes effect. Call them and request service and the entire replacement is free.
Posted on Mar 04, 2009
SOURCE: Some panel in my Neff electric oven is making a loud vibration noise on fan mode. The vibration noise stops if the top part of the front surround (with door open) is pushed in. There is no vibration o
Update: after using the oven with the grill instead of the fan, the problem sorted itself. With the heating and cooling, obviously some panel had not settled correctly and was causing the vibration. It hasn't happened again so far.
Posted on Jun 05, 2009
  • 523 Answers
SOURCE: Electric oven makes an awful vibrating noise when hot
yes it can,i have used double sided sticky tape tp put between the blower houseing and top
Posted on May 27, 2010
De dietrich range cooker very noisy when oven on?
Have you checked the exhaust fans within the oven? These can make a lot of noise if something has come lose. They should be located at the top of your oven or on the back. I would check that.
Good luck
Dec 05, 2013 | De Dietrich Ovens
Why is the fan so noisy?
If the fan is noisy, then it is probably due to worn bearings, or possibly worn or loose fan blade/s
In my experience it it is usually due to worn bearings.
The only guaranteed cur is to replace the fan motor.
Dec 02, 2010 | Baumatic B187 Stainless Steel Electric...
My Candy TC21 oven makes a vibrating noise when on, why is that?
There are only 2 moving parts in your oven when it is running - the fan and the fan motor. If a bearing is worn or the fan blade is damaged, this can cause vibration. However, the actual noise could be could be coming from some other part of the oven which is insecurely fixed, e.g a panel, internal shelf, the oven/grill element - pretty much anything!
Basically, the fan/motor causes the vibration and a loose part causes the noise.
Hope this helps.
Regards,
BElectric
Nov 14, 2010 | Ovens
Baumatic oven not heating up. Grill and fan fine.
if it is the b180, the answer (having just fixed this) is really simple.
The coily bit is the oven element - it will have gone. A new one from eBay cost me about 6 quid.
[WHEN IT ARRIVES !]
Turn the power off.
Inside the oven use a philips screwdriver to remove the 4 screws (KEEP THEM !)
You will see a coily thing and a fan.
You unscrew 3 more screws (2 on the left and 1 on the right).
(KEEP THESE TOO!)
now ... bit tricky, have the new one inside the oven and take each wire off one at a time and put it on the new element.
Screw it back on but DONT put the last panel back in.
Turn the oven on maximum for about 2 minutes and see it glow red.
Turn the oven off. Make a cup of tea and have a couple of biscuits while admiring how good you are and waiting for the element to cool down!!!
Put the final panel back in place. Whole thing (including a cup of tea) takes about half an hour.
Jan 27, 2010 | Baumatic B180 Electric Single Oven
Delonghi ESM465ST Oven Noisy Fan
If it is a fan assisted oven, then you are likely to have 2 fans, an external cooling fan, and a fan inside the oven for ciculating the hot air.
So to answer your query, yes it is a noisy fan you are going to have to establish which fan.
It could be a worn bearing, or the fan blade has come loose.
If it is a worn bearing, thge only cure is a new fan.
Hope this helps with your problem.
Dec 02, 2009 | DeLonghi Ovens
Some panel in my Neff electric oven is making a loud vibration noise on fan mode. The vibration noise stops if the top part of the front surround (with door open) is pushed in. There is no vibration on...
May 19, 2009 | Neff Ovens
Baumatic fan assisted oven not heating up
The oven element has failed, you need to fit a new element.
It is a straight forward repair to do.
Remove inner rear panel of oven, you will see the round element at rear.
Unfasten element, detach wires, and fit new element.
Refit rear panel, and test.
Plz rate my solution.
Thanks.
Jan 24, 2009 | Baumatic B180 Electric Single Oven
Jan 14, 2009 | GE JTP15 Electric Single Oven
Oven fan zannusi zbf360x
Remove rear panel in back of oven, there you will see the fan,remove fan blade,usually left hand thread, and remove screws that hold fan, if they are not accessable from inside the oven then you will have to remove oven from housing, and remove rear outer panel to access fan screws and connections.
Remove fan and replace in reverse order.,don't forget the nut that holds the fan is a left hand thread.
Plz rate this solution.
Thanks.
Dec 14, 2008 | Zanussi ZBF360X Electric Single Oven
Noisy Oven when heating up & fan spinning
Neth, Im not familiar with this oven but I thing someone is handing you a line. I've been doing this for 30 years now and never saw a oven cavity arch when heating. The fact is that there is something wrong with the fan motor or fan blades itself. Call this cat back and have them honor your warranty...Catriver..post back.
Sep 12, 2006 | Baumatic B180 Electric Single Oven
Ovens Logo
42 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
