I have a hotpoint washer/dryer and half way into a cycle water starts to pump out the draw, what is doing this?
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 09, 2012
  • 183 Answers
SOURCE: WD640 Aquarious supersilent washer/dryer leaking from powder draw
during the rinse the machine uses a higher level of water, therefore check the door seal for holes,if the water is leaking from the soap drawer in the spin then this suggests that you may have a blockage in the outlet hose or in the sump filter, to check the filter remove the sump hose, the filter is hidden in the hose. Regards Engineer
Posted on Jul 29, 2007
sidthedog
  • 4 Answers
SOURCE: Hotpoint Aquarius wd440 washer/dryer wont pump out water HELP!
hold the start button for 5 seconds this should clear previous program. then select drain on your dial. press start as normal and machine will drain. if this does not work the only other remedy is with help, making sure the end of the drain hose is higher than drum at all times take machine outside, lean it back at 45 degrees agaist a wall with a towel or similar covering lid to stop scratching . working from underneath loosen the large jubillee clip that connects the drum to pump drain hose to the drum. As the drum is overfull there is no recepticle large enough to fit under so just let water just flow away. Dry every thing off. make sure you don't loose ping pong ball in filter and make sure filter is clear. refitting is reverse of removal
Posted on Apr 20, 2008
hards327
  • 30 Answers
SOURCE: Washer WD420 leaking from dispenser draw
hi firstly turn down your cold water pressure as this somtimes gives the impression that the water is coming from the drum,then check that the rinse hold button is not activated if so press in the button then the timer should continue on its own,hope this helps if so please rate thank you.
Posted on Aug 19, 2008
SOURCE: my aeg washer dryer comes up with e20 flashing
I had the same problem (E20) for a long time and tried everything in the manual before I called AEG to have someone stop by and fix it.
He took the whole top off as well as the back and pulled out all this fuzz that was stopped somewhere. He said it normally comes from using too much detergant and also from not letting the machine run empty every now and then....but it doesn't say to do this in the manual. And anyway, I can't imagine that using too much wash powder made 1/2 kg of fluff.
I still have a guarantee on the machine, but they say that because it is my fault that I got E20 I have to pay for the repairment myself.
I actually think that they build the machine purposly in this way to keep up the money flow. I have an attorney on the case now.
Posted on Jan 14, 2009
  • 142 Answers
Try unplugging the unit and plug it back in. This may reset the controls.
Posted on Jun 02, 2009
By hotpoint ultima ctd80 tumble dryer has error code f11. What does this mean?
F11 - No pump connection. the pump that pumps the water up to the draw has gone wrong. hope this helps.
Sep 26, 2010 | Hotpoint Ultima WF860 Front Load Washer
Whirlpool wshser-dryer: water won't drain, cycles won't start
You need to give more info in order for a diagnosis. Is this a compact stack unit or an all -in -one unit or an interconnected washer/dryer pair ? Is it front load or top load washer ? What do you mean by "dry cycle"? Is that dryer cycle or is it washer cycle without water ?
Usually when water cannot be drained it is a bad coupling connector on the motor drive, or a bad or clogged pump (small socks have been known to get sucked in an lodged in the pumps); in either case you need a good mechanic or a service person to handle the repair because it requires opening up the shell of the unit and getting to the motor/pump assembly.As always, disconnect the power cord before diving into the unit. Good Luck, Macgivor.
Sep 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
WD640 aquarius super silent won't spin or drain
hi there......most likley cause is a blocked or defective drain pump....if the water cannot get out of your machine due to the faults above it wont rinse drain or spin
regards Sir Galahad
Aug 16, 2009 | Hotpoint Aquarius WD640 Front Load...
Jun 02, 2009 | Hotpoint Aquarius WD640 Front Load...
Water coming out of the draw during cycle
water comes out of draw when the water is emptying and on a spin. have tried it on the drain button to see if it did the same and there seems to be no problem on this function, only seems to be a problem when spinning, not sure if something is blocked.
Feb 15, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
My washing machine does not drain out water
Hi I had the same proble with a Hotpoint. I found the pipe that comes out of the bottom of the drum had got clogged with coins etc some of these and other junk had reached the small pump that drew the water out, the same pipe leads to the pump. It was easy to take off and open and I found the rubber impeller blades had been damaged and was not drawing all the water out. These I got from ebay for 3 pounds and fitted myself. Really hope this helps
Jan 08, 2007 | Hotpoint Aquarius WD63 Front Load...
Problem with our washer/dryer
sump/filter is blocked instead of flushing on dry cycle is filling as not pumping well. ring hotpoint to reorder pts cheaper then anyone
Jan 06, 2007 | Hotpoint Aquarius WD63 Front Load...
Find the pipe that comes out of the bottom of the drum, this may contain coin, muck, etc. Clean. This pipe leads to the small pump that draws the water out. If your clean of the pipe does not work the machine.......there could be a fault with your pump..........which you can/cannot clean.
Dec 29, 2006 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
11 people viewed this question
Top Washing Machines Experts
