Question about Panasonic Panafax UF-885 Plain Paper Laser Fax
Machine will not reset after toner replacement
Hello, I have a Panafax UF 885 fax machine. I have replaced the toner cartridge recently and the machine will not recognize it and reset itself. I have tried echanging the toner thinking it was defective. Unplugging did not work. My IT people have tried scrolling through all the menues to reset with no results. The message on the screen is "info code 45" which, when I looked it up in the manual says.."needs toner". Meanwhile faxes are comming in and my memeory is just about maxed out. I really hope you folks can help me! Thank you for your time. Jill Lowther Webasto Roof Systems 248-997-5135
  • 31 Answers
Info code 45 really means Toner cartridge is not installed.Info code 41 is out of toner & code 43 is toner getting low. There are three connection points inside of the fax machine that tell the machine that a cartridge is installed. Open the cartridge door & remove the cartridge. Verify that the metal tabs on the right hand side above the drive gear stick out far enough to make contact with the cartridge. There should also be two wires that are located on the left hand side that also make contact with the cartridge. Try putting your used/empty cartridge in & see if your info code changes to a 41 or 43.If not, you may have a broken connection. I have found that some compatible cartridges for the panafaxes are missing metal tabs that make contact with the connectors. Compare a cartridge that worked to the one that doesn't to see if it's missing metal tabs. This is not an issue if you are using OEM. Good luck! I can be reached by email if you have any questions. bspier@carlsonsupplies.com
Posted on May 23, 2007
Info Code 060 on our Panafax UF 885
Code 060 means that the toner door is open. Check the switches.
You might have to tape the door closed on the rear side or call a technician to replace the door.
Nov 25, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Panafax UF-885 flashing UF-885 (AU) message
yes there is a batt on the board it will need to replaced i have seen this many times
Nov 18, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Machine totally unresponsive just blinks model with letters AU after it" for model UF 885
Remove the toner cart
Pull up on the operation panel to open
unplug the machine
hold down the pointed switch near the **** glass while plugging the machine back in.
wait for the beep
close feeder
scroll down to SHIPMENT SET
press SET
press 2
press SET
wait for the machine to initialize
Jun 15, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Panafax uf-885 will not print
You will need a flashlight!
Open the toner door, remove the toner cart.
Look in the cavity towards the bottom left side
You should see 2 spring loaded loops sticking up.
One or both of them is probably bent down and not making contact with the silver tabs on the bottom of the toner cartridge.
Also, remove and discard the plastic drum cover that swings back and forth.....it's only for shipping, it causes many jams.
Try to bend the loop back up with your finger.
Repost if you can't get in bent straight up and I will help you further.
Jun 11, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
What does the code mean? How do I fix it?
051 means the printer motor is abnormal. I would try replacing the toner cart then switch off/on in the first instance.
Apr 14, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Fax machine error code 021
If a new toner cartridge doesn't take care of it, replace the fuser.
Apr 07, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Panafax UF-885 - Error Code 055
Error 055 is a laser error. the laser is not spinning at the proper speed and may need replacement. There is another solution, where some ferrite cores are added around three cables to reduce electronic interference. Best call a local technician for further diagnosis.
Mar 25, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
UF-885 Panafax
Unplug the power cord in the rear of the machine
Open the document feeder by pulling it straight up
hold down the pointed switch by the scanner glass while plugging the machine back in until you hear a beep
close the document feeder
press SET or START
press 2
wait for the machine to reboot.
Dec 30, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
Panasonic copier/fax UF 885
It sounds like you are stuck in the boot-up mode.
Try this:
Open the toner door and remove the cartridge
Turn the machine off
Open the document feeder by pulling straight up
While turning the machine back on, hold down the pointed switch actuator closest to the small glass
Close the document feeder..display should read "RAM INITIALIZE"
Scroll down to "SHIPMENT SET"
Press "SET"
Press "2" for "NO"
Wait for the machine to reboot (could take 5 mins)
Some times a bad toner cartridge will cause this.
If this does not work, you have a bad Main PC Board. Uneconomical to repair.
Sep 19, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
Panfax uf 885
If it happens on all printouts, and not just from one sender, then replace the toner cartridge. That will clear up most image related issues.
Jan 18, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
Panasonic Panafax UF-885 Plain Paper Laser Fax Logo
506 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
