Question about HP Pavilion DV6500Z Notebook
The sound just plain quit. The it came back one time and then it quit again. I installed a Serif tool bar and the the sound went out shortly after that. I tried to completely uninstall the Serif bar and couldn't. I installed something for online classes - sorry, can't remember the name - it was thru the school's website - and the sound came back for one day, then it was gone again. My OS is Windows 7 Premium. All help is appreciated! Thanks, Kristy
  • HP Master
  • 27,725 Answers
Click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to update drivers
click start right click on computer select properties then device manager scroll to sound and video if you right click on sound and video then on high definition audio device select update driver software
click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers
right click on the speaker icon in the bottom taskbar you will see an array of options select
playback devices make sure it has a green tick and the correct speakers are selected
be updated if you computer came with a motherboard disk the drivers could be on it although
once speakers are connected widows 7 should automatically update the drivers
click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker
you might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down
list in the advanced tab select dvd quality or another then apply
hope this helps
Posted on Nov 08, 2012
thehumble1
  • 137 Answers
SOURCE: sound is not working on my hp laptop
did you RESTORE the OS or did you reformat and REINSTALL the OS? if you did a complete reformat and reinstall either 1) the software has changed Firmware settings and messed up the hardware or 2) The Reinstalling process has installed similarly unfunctional drivers or 3) there is an unrelated problem that is the real cause of the issue.
I'd try getting ahold of a whole set of drivers and trying each one. You might also want to look into BIOS updates for the HP, they might have fixed the issue already.
Posted on Apr 29, 2008
  • 17 Answers
SOURCE: Touchpad scroller stopped working on my Acer Aspire 4920
Go to control panel and look for touchpad icon. You can change the settings in here. If there is no touchpad icon try the mouse icon as sometimes there is a touchpad settings tab in there. Hope this helps.
Posted on Dec 02, 2008
  • 86 Answers
SOURCE: task-bar & start-menu disappeared
Just do as I say - it will be ok and sort itself out - the screen will not go blank and the drivers are still installed in Windows and will just be reinstalled, thus associating themselves with the card again. No internet connection is needed and the drivers will be reinstalled automatically without the need for user input.
To gain access to that which is 'off screen' push the mouse against the edge of the screen and it should move the display into view
Posted on Dec 12, 2008
  • 629 Answers
SOURCE: HP Pavilion dv6810us does not start...
since the system got dropped off, different components would have been affected. From the information that you have provided, the LCD and motherboard appears to be two of the affected components. Since it is difficult to determine all the components that may have been affected by the accident, I would suggest contacting HP for support and ask if there is a repair center where you can take your computer for thorough testing. If you have an HP diagnostics utility, connect an external monitor to your computer and run the diagnostics. Note any error codes of beep codes which can help isolate the situation.
Posted on Mar 14, 2009
I had the same problem; my laptop's speakers suddenly stopped working but I could still use the headphones and sound was fine.
I played around a while and searched the net; and I got them to work:
Open Control Panel- Sound, Speech, Audio Devices-------->
1) Audio Tab
2) Under 'Sound Playback' hit Advanced
3) At the bottom where it has Speaker Setup change it to "Laptop Stereo Speakers" (mine was initially on "Desktop Stereo Speakers" for some odd reason)
Problem solved, Thank God (Alhamdulilah)!
Hope it works out for you :)
Posted on Apr 10, 2009
I purchased the item listed below as a download in October last year. It never seems to work properly. I have reinstalled it many times but I get a box up saying I need to reinstall. I constantly lose...
Sounds like you need the latest patch which fixes a number of known issues..
Read about it here. http://forums.serif.com/showthread.php?t=66785
Download the patch here http://www.serif.com/downloads.asp
Scroll down about half way to Digital Scrapbook and click download button on the right.
Save it to your desktop then doubleclick it to install when downloaded.
Hopefully this will fix most or all of your problems with this SW
Mar 21, 2011 | Serif Digital Scrapbook Artist 2
Quite awhile ago, one side of the unit went dead. Uesterday, after hearing a couple clicks, the unit will beep a few short beeps, then after a little bit, there will be a few short beeps again. I press the...
sounds like it is failing. When was the last time you tested its capacity? Test it to see how long the battery works. If it doesnt then get a new one or send it back where you got it.
Mar 09, 2010 | CyberPower 525SL (CPS525SL) UPS System
Sometimes driving down the road the aircondioner quits and the cruise control quits at the same time and then they just start working again
sounds like there is a short in your wiring some where take it to you local dealership or shop and see if it is faulty wiring or inspect your car and see any bar or loose wires
Nov 04, 2009 | Heating & Cooling
Installed new fuel pump, new electronic lift pump, 2 new fuel filters, new glow plugs, and a few new fuel lines. Truck starts and runs ok till it warms up then when putting it in a pull like going up steep...
The next step is fuel flow measurement. your description sounds like fuel starvation...this test focuses on volume over time.
Probably, you would have good flow, that would taper off and no longer be enough, after a short time...
Sep 18, 2009 | Ford F-350 Cars & Trucks
Hitachi DS18DL drill quits under load
sounds like your battery is either shorted out or out of charge
Jun 22, 2009 | Hitachi 18V Lithium Ion Cordless...
My 36' RCA TV JUST QUIT WORKING. TURNED ON POWER
A shorted horizontal output transistor or shorted flyback. If the flyback is shorted replace also its HOT.
Apr 05, 2009 | RCA F36650 36" TV
Te.co.ukFile opening error
Did you try uninstalling and re-installing the drivers. Uninstall everything including the canoscan tool bar, Arcsoft photo studio and Omnipage. And re-install.
Hope that helps,
Sai.
Jan 13, 2009 | Epson Perfection 1240U Flatbed Scanner
Sharp LC-26D6U sound issues
Capacitor is what I found out.. (Supposedly althoug Ive not verified).. If you can send here I'd love to see the unit...
(Theres a reason)....
Ken
Dec 27, 2007 | Sharp LC-26D6U 26 in. LCD Television
HP Pavilion DV6500Z Notebook Logo
29 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
