Take top off - Audio Players & Recorders
    Master:
  • 689 Answers
Take the screws out that holds the cover on,
Posted on Nov 09, 2012
07 corvette top will retract but deck lid makes no effort to close, then top will not go back up. Need to release pressure in block lift top up about 1/4 of way then top will go back up
Manually Moving the Folding Top from the Down Position
Important: Allow the system a minimum of four minutes to bleed down pressure after the last cycle.
Manually release the folding top cover latch using the emergency release cable.
Raise the folding top stowage cover.
Manually raise the folding top, holding the 5 bow up.
Manually lower and latch the folding top stowage cover.
Manually unfold the top and latch per normal procedure.
Manually Moving the Folding Top from the Up Position
Manually release header latch per normal operation.
Manually lift front of roof off of the header and raise the #5 bow at the same time.
Manually release the Folding Top Cover latch using the emergency release cable.
Fold the roof down into the well.
Manually close and latch the folding top stowage cover.
Power Folding Top System Components
The power folding top system consists of the following components:
• Folding top control (FTC) module
• Body control module (BCM)
• Folding top control switch
• Serial data communication
• Folding top cover latch actuator
• Folding top cover pull down actuator
• Folding top pump motor with valve manifold
• Position switches and limit switches:
- Pin receiver switch
- Luggage barrier switch
- Folding top cover open switch
- Top open switch
- Top closed switch
- 5 bow raised switch
- 5 bow lowered switch
• Tonneau release relay
• TONNEAU PULL DOWN ACTUATOR Fuse 20 A
• TONNEAU RELEASE Fuse 10 A
• BATT 2 Fuse 40 A
• REAR FOG/ALDL TOP SW Fuse 10 A
• Folding top mechanical components:
- Folding top
- Folding top cover
- Folding top valve 1
- Folding top valve 2
- Folding top valve 3
- Hydraulic lines and cylinders
Folding Top Cover Latch Actuator
The power folding top system includes a folding top cover that is powered open and close by a hydraulic system that is controlled by the FTC module. A power unlatch motor is used to unlatch the folding top cover before the folding top control (FTC) module powers the top cover open. The folding top cover unlatching is requested by the FTC module via class 2 message, but is executed by the body control module (BCM). When requested, the BCM applies battery voltage through the folding top cover release relay control circuit to the tonneau release relay. The relay is energized and battery voltage is applied through the folding top cover release control circuit to the latch actuator. The actuator is energized and the latch releases the folding top cover.
The electronics on this are very complex ,
System Operation
Before any movement of the power folding top is allowed, the folding top control (FTC) module must be aware of the following conditions:
• Unlatch the header. The FTC module reads the pin receiver switch is Inactive.
• The windows must be normalized. Refer to Power Window Reinitialization.
• The ignition must be placed in Accessory or RUN.
• The transmission must be placed in PARK, or with manual transmission, the park brake must be applied.
• Trunk status must not be ajar.
• The luggage barrier must be in place.
• The pump motor temperature must be within the operating range.
After the last cycle of power folding top operation, allow the hydraulic system a minimum of 4 minutes to bleed down before attempting manual operation of the top.
Your best bet take and have it checked for DTC'S - diagnostic trouble codes .
DTC B3666 Rear Tonneau Position Error
DTC B3667 Tonneau Release Circuit
DTC B1011
DTC B1291
DTC B1420
DTC B3602
DTC B3666
DTC B3667
DTC B3670
DTC B3971
Jan 23, 2017 | 2007 Chevrolet Corvette Convertible
Tip
Top Shot Elite Set Up and Usage Guide by Activision Follow this link to the...
<b><u>Top Shot Elite Set Up and Usage Guide by Activision</u></b><br /> Follow this link to the Guide on <a href="http://www.facebook.com/ActivisionHunts?sk=app_2373072738#!/topic.php?uid=133041143393695&topic=331">Facebook.com/ActivisionHunts</a><br /> Also see the following <b>Expert Videos</b> to have the best gameplay experience with your <b>Top Shot Elite</b>:<br /> <a href="http://www.facebook.com/ActivisionHunts?sk=app_2373072738#!/video/video.php?v=10150089463307966">Top Shot Elite How To Video 1 - Introduction</a><br /> <a href="http://www.facebook.com/ActivisionHunts?sk=app_2373072738#!/video/video.php?v=10150089459077966">Top Shot Elite How To Video 2 - Syncing</a><br /> <a href="http://www.facebook.com/ActivisionHunts?sk=app_2373072738#!/video/video.php?v=10150089455422966">Top Shot Elite How To Video 3 - Calibration</a><br /> <a href="http://www.facebook.com/ActivisionHunts?sk=app_2373072738#!/video/video.php?v=10150089452377966">Top Shot Elite How To Video 4 - Dead Zones</a><br /> <a href="http://www.facebook.com/ActivisionHunts?sk=app_2373072738#!/video/video.php?v=10150089448732966">Top Shot Elite How To Video 5 - Red Lens</a><br /> <a href="http://www.facebook.com/ActivisionHunts?sk=app_2373072738#!/video/video.php?v=10150089445917966">Top Shot Elite How To Video 6 - Troubleshooting</a>
on Feb 17, 2011 | Video Game Consoles & Games
How to run diagnostic
Maytag Bravos MTW6600T Top Load Washer Run ... - Fixya
www.fixya.com > ... > Maytag Bravos MTW6600T Top Load Washer
Maytag Bravos MTW6600T Top Load Washer, run diagnostic test cycle related issues. Get free help, solutions & advice from top Maytag experts.
Maytag Bravos MTW6600T Top Load Washer, run diagnostic test ccu related issues. Get free help, solutions & advice from top Maytag experts.
Maytag Bravos MTW6600T Top Load Washer Diagnostic ...
Dec 02, 2015 | Maytag Bravos MTW6600T Top Load Washer
Top worked fine yesterday but today tried to let down only clicked
It is a hydraulic pump that applies pressure to the 2 hydraulic pistons to raise & lower the top. So, check for something obstructing movement first.
The convertible top:
  • is motor-driven.
  • requires parking brake engaged to complete circuit for operation.
  • is equipped with a back window glass (42006) . The back window glass is permanently attached to the folding top back window curtain (52500) and cannot be opened.
VISUAL INSPECTION CHART Mechanical Electrical
  • Damaged fluid reservoir.
  • Damaged folding top hydraulic cylinders .
  • Damaged folding top motor upper and lower hose .
  • Damaged convertible top regulator.
  • Parking brake not engaged.
  • Open power distribution box circuit breaker CONV TOP (30A), fuse junction panel Fuse 1 (15A).
  • Circuitry open/shorted.
  • Damaged convertible top switch.
  • Damaged raise/lower relay .
  • Damaged folding top hydraulic lift motor and plate kit .
  • Convertible Top Does Not Raise/Lower
  • Open circuit breaker or fuse.
  • Damaged folding top switch.
Jun 29, 2011 | 1998 Ford Mustang
Need to reset the soft top on a maserati spyder
Manual roof procedure
The procedure in the manual is just for closing the top.
A) Turn key to OFF for several seconds to bleed off hyd pressure.
B) Turn key to MAR (full electrical, but before start)
C) Remove cap on bulkhead behind the right-hand seat and use flat head screw driver to unfasten the hyd unit valve in order to relieve the oil pressure in the circuit.
D) Remove the cap on the bulkhead behind the left-hand seat and using screwdriver or allen wrench press until the top covering (panel behind roll bars that covers the convertible top well) until the panel's locks are released - you may have to tap the wrench to release the locks.
E) Lift the top covering manually and keep it open while extracting the top from its well.
F) Remove top from well until the front part is near the windshield frame.
G) Lift the rear part of top (rear window) upwards and lower the top covering until the hooks are resting on their respective locks.
H) While still keeping rear part of convertible top lifted upward press Button 1 to attach the top covering locks.
Button 1 is the forward one
Button 2 is the rear one.
I) Make sure locks are fastened. if not - try pushbutton 1 again. If necessary repeat D and H
J) Rest rear part of convertible top on top of covering.
K) At front of convertible top, open (deploy) the top's hooks by using allen wrench to turn the pin mechanism. (located in center of front headliner)
L) Press top unto windshield frame and use wrench to lock the hooks.
M) Press the rear of convertible top, so hooks on rear top insert into respective slots and press Button 2 to secure.
N) Keep Button 2 pressed until hooks properly fasten.
If the top is still tightly latched at the front, you can just start at step "G":
While holding the back of the top in the air, and the "top cover" resting down on its "hooks", press button 1 until it seats well.
Then lower the back of the top down to mate its "hooks" and press it down while holding button 2 until the top seats well.
Sep 10, 2009 | 2002 Maserati Spyder
Have 2 lap tops,1 desk top. Desk top and 1 lap
For the 2nd laptop, first upgrade the LAN card driver, then reinstall the driver if the problem is not resolved with the driver upgrade.
Hope this helps.
Aug 29, 2009 | D-Link 802.11g Wireless Router WBR-1310...
I would like a diagram of the parts to the fabric softner holder to reinstall back into washer
two clips hold the top on they are located in the gap between the top and the front. insert a knife in between the top and front on each side while maintaining a little upward pressure on the top. the top will lift up from the front. The top will hinge on two clips in the back of the top. Once you pivot up the top you will be accessing you lid closed switch which is located in the top of the machine good luck.
Aug 06, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Letting the top down
I had the same problem for four years until I purchased a CD from Ebay titled "BMW E30 Convertible". I discovered, that I was opening the top up incorrectly. The top works fine. Unlatch the top from the windshield frame, then lift up the back half of the top, unlatch the top lid, rise it up and lower the top into the compartment, close and latch the soft top lid. Hopes this helps.
Jan 29, 2009 | 1987 BMW 3 Series
 Grubhead
Grubhead
