Question about LG WM-2277HW Front Load Washer
Hi. I have an LG WD - 8050 FH Front Load washing machine. The motor works however when you try to spin, the motor spins but the wheel doesn't. I took the belt off and found by turning the wheel, the tub turns one way but not the other (spin direction). Basically it turns anti-clockwise but jams on clockwise. Any ideas would be muchly appreciated?
    Top Expert:
  • LG Master
  • 9,472 Answers
Is the tub wobbly at all when you spin it?
Posted on Nov 09, 2012
SOURCE: LG WD 8050 intellowasher Front loader
My machine is spinning OK, but it has a terrible smell of rubber? oil? burning?
Last month I rang LG who said I should have been using Scalex (first I heard) to descale the build up, and they sent me a sample.
Well, it helped for a couple of washes, and I bought some more and used it at least 10 times now, but the smell is worse than ever - can't even wear the clothes. So it is time to ring them again.
Posted on Nov 07, 2007
  • 4 Answers
SOURCE: LG front load washing machine will not spin
I am having the same problem with my washer. Go to this web site below it has a free troubleshooting guide. I narrowed my washer machine down to two parts. Stator assy or Main PWB assy.
http://136.166.4.200/contents/Laundry/WM2042/WM2042xx_Service_Manual.pdf
Posted on Oct 13, 2008
  • 130 Answers
SOURCE: noisey during spin
yes you are right noise during spin cycle is due to faulty bearing. If the tub seal lets go water will weep into the tub bearing. This will rust the basket shaft and normally wreck the tub bearing. Once the bearings starts to get worn enough it usually gets very noisy. The tub bearing is pressed onto the outer back half of the tub shell assembly. Normally need to replace the inner basket/shaft assembly  and the outer shell with the tub bearing.
Sometimes the inner basket support will crack, this can give an clicking or banging noise as well.
Pictures of this job...
A sure indication was the brown junk/gookus leaking out if the rear bearing area and the belt has spewed it around in the drum that the rear bearing and seal was bad...
Picture1 - Picture2
The whole outer shell and basket come out to do this repair....what bad bearing and rusted shaft looked like...
Picture1 - Picture2 - Picture3
I had to remove the back panel. Undo the pump hose & water level hose, remove the 2 shocks, remove the motor, undo the front boot from the outer panel and remove the 2 springs to lift the whole assembly out from the back to work on it.
Picture1 ( boot pushed inside ) Help page1 - Help page2
It leaks Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only If the washer leaks only during the fill cycle, check these:
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time If the washer leaks all the time, check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Posted on May 07, 2009
MNTECH
  • 1543 Answers
SOURCE: LG front load washer WM2277HW. ''LE'' Error code
First try unplugging the machine for a few minutes and then retry a cycle. If you still get the LE error:
The Hall sensor (part number 6501KW2001A) has failed. The hall sensor is rather easy to replace, and is covered by a seven year part warranty (in the US). Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble. Usually takes under a half hour. On a difficulty scale of 1 - 10, it might rate a 4. This should be a Fix-Ya for your machine, and at basically no cost!
In the US, find a service provider using your zip code at http://us.lgservice.com/index_b2c.jsp or call LG at 800-243-0000
Posted on Jul 03, 2009
  • 22 Answers
SOURCE: Error Message and Tub not spinning
Depending on how many clothes are in the washer you may a unbalance error
Posted on Jul 31, 2009
Washer wont spin
see this possibles cause:
It doesn't pump or spin
frozen pump pulley+drive pump belt broken replace
It pumps, but doesn't spin
lid switch open, or defective +motor coupler broken+belt broken+clutch worn+motor defective.+transmission not shifting properly+basket worn
It spins only with the lid closed
safety the machine will run with the lid door closed.
God bless you
Jun 28, 2012 | LG WM1814CW Front Load Washer
My washing doesn't spin, It doesn't pump or spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 12, 2011 | Washing Machines
GE frontload washer doesn't spin
heatman101
Aug 12, 2011 | GE WSXH208A Front Load Washer
I have an LG WM2277HS which will aggitate, but will not spin & rinse.
make sure the door safety switch is working correctly ,, if it doesn't show as locked, the machine won't spin
Jul 15, 2011 | LG WM-2277HW Front Load Washer
The door is jammed on my LG Intellowasher WD-1023C-Washing Machine - Front loader. It has finished it's wash cycle, but the door won't open
Slide a paint scraper or similar between the machine and the latch side and push it quite hard and it should open. Mine does and I found the fix on this site!
Jul 13, 2011 | LG WD-1041WFH Front Load Washer
On spin cycle drum going round but not spinning so clothes stay wet
Hi, if it doesn't spin, check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Jun 20, 2011 | AEG Lavamat 74640 Front Load Washer
All the water does not spin out of the clothes & at times it doesn't even seem like it is spinning
heatman101
Jun 07, 2011 | Whirlpool LSR6334LQ Top Load Washer
Water not draining from the machine...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 19, 2010 | LG WD-1041WFH Front Load Washer
My LG front loading washing machine gets halfway through its cycle then sits there humming. I have checked the pump it's not blocked or jammed. I can drain the machine & run a spin cycle all correctly...
Seems to me the board may have an issue at the thyristor or relay. Unfortunately, with LG,the board is covered with appoxy so as not repairable. The motor is usually very durable and very seldom go faulty. When selecting the spin cycle, a second triac activates that part to spin the motor. (again ,suspect the board.)
Aug 15, 2010 | LG WD-16115FD Front Load Washer
Lg washing machine error message
Possible that water solenoid valve died. Unplug the unit to clear error code, and try to fill using only hot water. Try the same procesude using only cold water.
May 02, 2009 | LG Washing Machines
LG WM-2277HW Front Load Washer Logo
61 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
