Question about Avaya S3400 Mss-h Modular Messaging Storage Server 2ghz 3x 73gb Scsi Dvd-rw Raid
How do I locate a secondary extension in modular messaging
Trying to add an extension to modular messaging I get an error saying this extension is in use as a secondary extension but I can not find it.
Error message display (adding toner), but the catridge is full with toner.
cartage dispenser wheel might have broken,try with different cartage .
Feb 17, 2014 | Toshiba e-Studio 232 Black and White...
Tip
How can I run two Skype accounts on the same computer?
To use more than one Skype account on the same computer at the same time you need to start a new instance of Skype.
1.
From the Windows taskbar, click Start > Run (or press the Windows and R keys on your keyboard at the same time)
2.
In the Run window, enter the following command (include the quotes) and press OK:
"C:\Program Files\Skype\Phone\Skype.exe" /secondary
If you get an error message, copy and paste the exact command from this page and try again.
Be aware that if you have changed the installation path for Skype then you will need to enter the correct path for the Skype.exe file.
If this solution fails, you can try another option:
1.Find the Skype executable file (Skype.exe) in: C:\Program Files\Skype\Phone\
2.Right click on it and select Send to > Desktop (create shortcut)
3.Locate the shortcut on the desktop, then right-click on it and select Properties
4.In the Target field, add: /secondary. The Target field should now be "C:\Program Files\Skype\Phone\Skype.exe" /secondary
5.Click OK. You can now start a new instance of Skype every time you double-click the new shortcut.
on Nov 19, 2013 | SKYPE Computers & Internet
Google chrome keeps going snap why?
"Aw, Snap!" IssueYou may see the "Aw, Snap!" message if a webpage crashes unexpectedly.
SolutionsIf a webpage crashes unexpectedly, you can simply reload the page. If you're seeing the "Aw, Snap!" message for every page you visit, try the solutions below:
Some anti-virus or firewall applications, such as Symantec Endpoint Protection, can prevent Google Chrome from working properly. Test whether such applications on your computer are causing the error by turning them off temporarily. Then try opening Google Chrome again. If you are able to open the browser, you'll need to create an exception in your anti-virus or firewall settings for Google Chrome. Once you've done so, you can then re-enable the applications.
Conflicting applications that users have reported include the following:
  • Spyware Doctor
  • Comodo firewall
  • McAfee Enterprise
  • McAfee Virus Scan
Try disabling your extensions one by one to see if a particular extension is causing the problem.
  1. Click the wrench icon chrome_toolsmenu.gif on the browser toolbar.
  2. Select Tools.
  3. Select Extensions.
  4. On the Extensions page, click Disable for the extension you'd like to temporarily remove.
Go back to your list of extensions at any time to re-enable disabled extensions. You may need to refresh the page in order to use extensions you've re-enabled.
If the browser continues to display the "Aw, Snap!" message, your user profile may be corrupted.
To create a new user profile, follow these steps:
  1. Exit Chrome.
  2. Find the "Default" folder. It's usually located in the following locations:
    Windows
    • Windows XP: %USERPROFILE%\Local Settings\Application Data\Google\Chrome\User Data\
    • Windows Vista and Windows 7: %LOCALAPPDATA%\Google\Chrome\User Data\
    Mac OS X: ~/Library/Application Support/Google/Chrome/Default
    Linux: ~/.config/google-chrome/Default
  3. Rename the folder as "Backup default."
  4. Restart Chrome.
it is taken from support site..
Regards
Aug 18, 2011 | Computers & Internet
At Receptionist phone- shows a solid green light on rights side of a specific extension- at that extention it is a green flashing light, but no message- looking to see how we get rid of the green light at...
On the attendant phone:
1. Press the Message key on the Attendant Add-On Console.
2. Press the DSS key on the Attendant Add-On Console that is associated with the station where Message Waiting is to be canceled.
May 12, 2011 | NEC DTH-8D-1 Corded Phone
I'm unable to rename any file in win XP,a message appears "If you change a file name extension,the file may become unusable" Plz help
Go to control panel then go to folder option then click on view tab. On the list you'll find a option named "Hide extensions for known file type". Enable this option and click OK. Now you can rename your files easily.
Mar 13, 2011 | Microsoft Windows XP Professional
I keep getting erros when im trying to redeem my 3 month card what do i do?
You receive this error when a secondary account in a Gold Family Pack subscription tries to add a credit card or buy Microsoft Points. Secondary accounts cannot add credit cards to or make purchases with cards over Xbox LIVE. The primary account can add a credit card and transfer points to the secondary account. For more information, read Questions about billing and Microsoft Points for the Xbox LIVE Gold Family Pack.
Dec 29, 2010 | Microsoft Xbox 360 Console
How many phones can we use at a time in our office? We have 3 currently and six jacks. Can we add more phones?
I'm guessing yes, but it depends on what system it's plugged into. In the U.S. Panasonic sytems come in 308, 616 and 824 models in the TA series, but only 4x4 default in the TAW-848.
These would be the systems most common for the 7731 phone.
So, when you locate the cabinet, if it's a TA-624/824, then you'll see a board with 11 modular jacks, 3 for lines and 8 for extensions. In the 848, it will be 4 lines and 4 extensions if it has not been expanded. If it's an old KXT30810/61610, you'll see the extra jacks on the sytem.
Carl
Sep 21, 2010 | Panasonic KX-T7731 Corded Phone
Getting error message saying the installer could not locate a suitable folder to install into
Most of such type of problems occurs with respect to availability of secondary memory space in order to install
Dec 16, 2009 | Citrix GoToMeeting
I get error message for woks 6. It says fatal error ocurred
What you need to do is open start, control panel, add/remove programs and select microsoft office.
Click on repair, it will go through an extensive check and repair clip art if it is corrupted.
Jan 12, 2009 | Microsoft Windows XP Home Edition
I need solution
Ok, this is a misworded error message on dells end. this laptop does not have a modular bay instead it has a locked in disc drive. Based on what i have seen on other dell laptops i would have to say the cd drive is going bad. To test this try removing the cd drive. Power the laptop on and push the eject button then power the laptop off. Flip the laptop overand there will be a screw to hold the drive in, this screw will be close to the center and will be the only screw in a square hole, remove this screw. Now if you followed my directions, you should have the drive out. Pull the tray out as far as it will go then grab the two sides closest to the laptop and gently pull it out. If you are having problems you can stick a flat screw driver in the square hole and push the piece of metel to the side to remove.
Now power the laptop on it may say something about there not being a cd drive(optical drive) if it does not say: "the device in the system modular bay cannot be identified" then you need to replace to CD drive.
Dec 04, 2008 | Dell Inspiron 2200 Notebook
Avaya S3400 Mss-h Modular Messaging Storage Server 2ghz 3x 73gb Scsi Dvd-rw Raid Logo
219 people viewed this question
Top Avaya Computers & Internet Experts
Michael Vincent Cruz
RSole
Are you an Avaya Computer and Internet Expert? Answer questions, earn points and help others
