Im about to install a avital 4103 on a 03 exterra and noticed the avital only has 1 starter wire output. what do i do with the second starter wire in the exterra? any help or input would be great .... thanks
  • Anonymous Mar 17, 2014
    cant find push button on avital 4103
  • 34 Answers
The one you need to use is the wire that shows a 12volt power in cranking posision
Posted on Jan 09, 2009
Avital 4113 remote starter shuts off after a few seconds
check and scan vehicle if you have a pending code remote starts wont work correctly or wont start at all or need to check and test unit for possible fault or wire problem
Dec 15, 2016 | Avital Vehicle Parts & Accessories
2000 dodge durango remote starter
Go here to find wiring diagram for your truck - then you'll know where these wires are
Jul 29, 2014 | 4103LX Remote Start System with Two...
Cant get the starter off of my 2004 nissan exterra and the bolts are out how is it stuck to the engine
starter gear is probably stuck in flywheel. 1. disconnect battery 2. use correct size socket w/ratchet and turn the crankshaft on front of motor. the bolt is inside crankshaft pulley.
Dec 25, 2013 | 2004 Nissan XTerra
Avital 473L TX will start and keep the starter engaged
Sounds like the ignition or accessory output from the remote starter is connected to the starter wire. Has it always done this?
Mar 06, 2013 | Avital Vehicle Parts & Accessories
Alarm keeps turning on when I turn on my car starter
Okay, the Avital 4111 is a one button remote starter. So, it has no way of locking your car doors except if wired to lock after start or, after shut down. In the 2010 CRV, the unit should have been wired to disarm the alarm before start(brown wire in kick panel) and to unlock doors when running (grey wire in kick panel in same harness as disarm) with the press and release of the remote starter remote. If the unit is not working in cold weather it may be due to the installer using a valet key instead of a bypass and/or the unit may be programmed for virtual tachometer or voltage instead of having a true tachometer wire connected.
Jan 25, 2013 | Avital Vehicle Parts & Accessories
I have a Avital model 4100 remote car starter. My question is I have 2 wires that i cant figure out where to or what to hook them up to. The wires are on a 9 pin connection. They are the H1/4 White/Blue...
I'm not familiar with this particular model, but do you have the wiring/installation diagram for this system? If so, does the manual specify if these are trigger wires or if they are output/source wires?
They could be trigger wires to allow a secondary system to activate the remote start and they provide options for either a negative trigger or a positive trigger. They could also be outputs that will provide a negative signal/pulse or a positive signal/pulse to activate other features when a remote start is successful (such as to activate a relay to power the heated seats).
Dec 16, 2017 | 831002/4100 4100 REMOTE START SYSTEM WITH...
We had the Avital 4003 keyless engine starter remote installed on our 4Runner in July when we purchased it. We shipped the car overseas and now that it has arrived the renmote will only start the radio...
You mean the igniton powers up but it does not start, correct? Sounds like the remote starter is not sending power to the starter. Did it ever work? It's possible that one of the 30amp fuses (one that supplies power to the starter output of the remote starter) is blown. If there is 12 volts present, check for voltage at the starter wire (purple) from the remote starter. If it has voltage,make sure it's connected. Also make sure that the harnesses of the remote starter are completely plugged into the module.
Sep 26, 2010 | 4003L Avital 4003 Remote Start Module...
546 people viewed this question
Top Avital Vehicle Parts & Accessories Experts
D. E. Hev
Billy Mac
Are you an Avital Vehicle Part and Accessory Expert? Answer questions, earn points and help others
