Question about Dishwashers
Looking at how to pull out the filter on my dishwasher
  • Kelly Sullivan Nov 08, 2012
    What model are we talking about here?
    Problem Solver:
  • 13 Answers
You need to remove the spray tube also in order to remove the filter. Some dishwashers have a clip or screw right under the tube that secures it to the lower pump assembly. Hope that helps Good luck
Posted on Nov 08, 2012
  • 3 Answers
I would go to manufacturers web site and see if the manual is there. It should give detailed instructions for how to remove filter for cleaning.
Particles left on glasses
Steps:
1)Empty the dishwasher.Remove all dishes including pots,pans and silverware.
2)Pull the bottom rack out as far as possible.The filters are under the basket on the Maytag dishwashers.It may be convenient to lift the rack out.Typically,if you lift,the wheels leave the track.
3)Remove the Coarse" filter.This filter is a small,round knob in the middle of the Fine filter.A round knob is around the Coarse filter.Hold on to the handle and lift straight up.
4)Knock the contents of the Coarse filter into the garbage can.Run the faucet to remove smaller particles.Wipe the dishwasher filter with the sink sponge.Push back into the filter holder when complete.
5)Take out the Fine filter.Turn the round knob that is around the Coarse filter counter-clockwise.Once the knob is loose pull up.The Fine filter will come out of the dishwasher.
6)Rinse the Fine filter with the hot water faucet.Scrub with the sink sponge to remove any stuck-on fragments.Replace the filter into the dishwasher.Push down and turn the knob clockwise to tighten.
Jul 31, 2010 | Maytag 24 in. MDBF550 Built-in Dishwasher
Dishes have a soap residue left on them after washing
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Jan 12, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Normal cycle leave dishes half clean. Heavy cycle
in the bottom of the machine, under the bottom rack, is a screen looking piece. twist or just pull up, should be able to clean that then replace.
Aug 08, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
GE Profile Max Dishwasher
I,m not familiar with this make or model but all spray arms should be removable bottom normally pulls off top quarter turn and pull and the back water feeding tube can also be removed usually by clips.rinse through thoroughly and hook out food stuffs with needle from the eyelets.the cause is general build up but mainly pips seeds rice etc.solution is to rinse plates before going in machine also checking filter is firmly in place before wash cycle.remove and check filters regulary. hope this helps
May 18, 2009 | GE 24 in. Profile PDW9200J Built-in...
Dishwasher comes on, fills with water, water heats, no movement of the arms so no water spraying out, then the water drains, it goes through the dry cycle and no clean dishes.
What is the manufacturer and model number of your dishwasher?
Depending on the model and design, the sprayer motor/pump has probably failed and the drain motor/pump is still working.
Recommend you pull the sprayer arm and filter. Look for debris that could be jamming the pump - watch out for broken glass when looking.
Make sure the impeller can spin and is not damaged.
If that does not fix the problem, replace the wash motor / pump or replace the entire dishwasher with an Energy Star qualified name brand model.
Good Luck!
Apr 01, 2009 | Maytag 24 in. MDB5600A Jetclean II...
No idea how to put filters in Dishlex Global 450
G'day Megan.
I just pulled my dishlex apart (AGAIN ) and I'm sure that there is some sort of --- hang on while I go check this out!!!!! --- Wait --- Yep, if you look at the part itself and read around the ring it says "PUSH THIS CUP FIRMLY DOWN TO SECURE FILTER", Errr. Yeh - very informative
The part you are talking about goes into the bottom filter LAST with the pipe thingy sticking up in the air like a tower.
If you still can't figure it out, let me know and I'll photograph the assembly and re-post.
Grumpy Plumber
Jan 16, 2009 | Dishwashers
Lg dishwashers
The LG dishwashers have a perminant mesh filter just below the bottom spray arm.
The filter can be removed by removing the spray arm by pulling straight up, then removing 10 phillips screws. Whenever you remove the filter, inspect for debris beneath the filter (including hard to see broken glass.)
Jan 03, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Bosch dishwasher model shv4800/shi6800/shu6800
you should have two filters. one you can unscrew .its a smaller round looking filter right under the bottom spray arm .once removed you just pull up on the flat filter that lying on top of the sump area
Dec 22, 2008 | Bosch 23 in. SHU303 Built-in Dishwasher
Dishwasher making loud humming noise
The most common cause of the hum/grinding sound, and often poor cleaning - is a blocked filter or debris stuck below that filter.
Pretty easy fix: Get a phillips screwdriver near by. Pull out the lower rack (the upper rack can come out if you pull the little gray thingeys on the front of the upper rails.)
Remove the lower spray arm -- just pull it straight up. Remove nine silver screws from the sump area that holds the filter down. Pull the filter up and out. Rinse the filter as best you can.
While the filter removed, with a flash light inspect all over the sump area - looking for stuff that should not be there and clean it out. Watch out for broken glass!
Replace the filter, screws and the spray arm. Fire it up and check your results!
Good Luck!
Oct 20, 2008 | LG 24 in. LDS 5811ST Stainless Steel...
Dishwashers Logo
125 people viewed this question
Top Dishwashers Experts
