Question about Cuisinart Four-slice Stainless Steel Toaster RBT-385PC 4 Slice Metal Toaster
Rbt 385pc toaster does not stay down
Does not stay down
3 Suggested Answers
SOURCE: toaster arms will not stay down
Arms stay down by the mean of an electromagnet, controlled by a chip. If the wall outlet is functional, you should be able to turn on light by pressing the "defrost" or "bagel" button while the arm is held down. No light? the toaster is good for garbage!!
Posted on Jul 10, 2009
SOURCE: problem with the CUISINART RBT-450BKPC costco toaster
We had exact the same problem. Our problem was within the circuit board controlling the release relay, on the left side. 3 parts was dead:
1) rectifier diode 200V 1amp
2) Electrolytic capacitor 220uF 25V
3 Zener diode 12V 1W
These components supplies 12VDC to the rest of the circuits from the mains, 127 VAC.
Posted on Jul 06, 2010
When you press the lever to push the bread down in the toaster, it will not stay down
How to Fix a Broken Toaster - For Dummies
www.dummies.com/how-to/content/how-to-fix-a-broken-toaster.html
Toasters are uncomplicated appliances with heating elements, a thermostat, switches, and plugs and cords. ... If you get a shock when you touch the toaster, it's not grounded. ... What to do when your toast won't stay down ... Take off the carriagelever and front cover and look for a knob, screw, or nut located near the toast ...
How I fixed my toaster - YouTube
? 6:15
https://www.youtube.com/watch?v=QKiJkpuHy-Q
Feb 5, 2010 - Uploaded by paisteboy
Hey I know its been like 5 years since you posted this but how didyou get off the black knobs? I have a similar ... Thanks much - I shall try this on my mother-in-law's Oster toaster! ... But now that side won't stay down, so what to do? .... About · Press · Copyright · Creators · Advertise · Developers · +YouTube.
Jan 16, 2016 | KitchenAid Kitchen Aid KMT222OB - 2-Slice...
Bread stuck in the bottom of a cusinart rbt 380c toaster
unplug the toaster and either let the bread dry out to the point it will crumble and be released, or use thin tongs/knife/needle-nose pliers to carefully remove the bread.
Dec 31, 2012 | Kitchen Appliances - Others
Toaster latch does not stay down on Cusinart CPT-120 compact two slice toaster
for Cuisinart cpt160: If the latch will not stay down it is because the electromagnet at the base of the toaster, which is supposed to activate when you push the handle down, is burnt out. I pulled my toaster apart and did a test of that mechanism and found that the solenoid was fried (open circuit). There are no replacement parts.
Jan 09, 2011 | Cuisinart CPT-160 Metal Classic 2-Slice...
Problem with the CUISINART RBT-450BKPC costco toaster
Apr 25, 2010 | Cuisinart CPT-180 Metal Classic 4-Slice...
The toaster arms will not stay down on either side , have power to the toaster and can see the elements light when arm is held down but won't stay down.
First, turn it to the darkest setting. It may be set too light to stay down. Also, try cleaning it out. Take it outside and turn it upside down and shake it. Also, open the crumb door on the bottom. Hope this helps. Good Luck.
Feb 10, 2010 | Cuisinart CPT-180 Metal Classic 4-Slice...
Toaster does not stay held down to toast wct 708
there is a "contact switch" that when there is power in the system, it stays down. If hte contact switch is bad, it releases and will not stay down. COntact switch needs to be replaced, unfortuantely I have the same problem and can't seem to get the part.
Jun 12, 2009 | Waring WCT708 4-Slice Toaster
Toaster arms will not stay down
Mar 15, 2009 | Cuisinart CPT-180 Metal Classic 4-Slice...
Bread won't toast
We ran into the same problem today with our toaster. There was never a problem before I cleaned it--not only by sliding out the crumb drawer, but by turning it upside down to dislodge every last crumb. After that, It would not stay down when pushed down.
My husband took the cover off and found that a magnet is what keeps the lever down when the toaster's on, and allows it to go back up when the toasting is done. It's an electro magnet that works only when the toaster is on. It seems that when I turned the unit upside down and rightside up again, crumbs landed on the magnet's contact plates (which are about 1/4" x 1/2") and would not allow the magnet to engage. Because the magnet wouldn't engage, the lever would not stay down, and the toaster shut off. Brush off the magnets, replace the cover and toast away!
Dec 27, 2007 | Kitchen Appliances - Others
Toaster lever wont stay down
Open the toaster up and look inside by the levers, there should be a little piece that will keep the lever down, if this is missing, then you may need to replace the toaster, if not, then the little piece may be stuck, you can use the following to try and loosen it up,
1. WD-40
Oct 11, 2007 | Waring WCT708 4-Slice Toaster
Toaster broken???
these toaster has to be pluged in so that the lift lever could stay down.
Feb 23, 2007 | Kenmore KTES4 4-Slice Toaster
Cuisinart Four-slice Stainless Steel Toaster RBT-385PC 4 Slice Metal Toaster Logo
29 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dale Anderson
Dale Anderson
Level 1 Expert
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
