Question about Frigidaire ATF6000ES Front Load Washer
Frididaire front load washer won't lock
I washed a load of clothes this morning washer worked fine. Went to wash another load and the door will not lock to start the wash cycle. Can I fix this myself or do I need to call appliance guy?
  • 1 more comment
  • kellington_4 Jan 21, 2009
    Jan 21, 09
    I have the same problem... my door won't latch, therefore won't start the cycle.
  • ayana0199 Feb 15, 2009
    I am having the same problem with this frigidaire front load washer. Does anyone have a link to pics that show exactly how to fix the problem? Thanks!
  • jetfixr May 11, 2010
    See if the plastic latch on the door is intact? There is also a microswitch that the door latch contacts to allow the washer to work. You can buy the plastic door latch for about $10 bucks and replace it with 2 screws. The microswitch is more involved. Start with the plastic door latch. Give it a good visual inspection and see if a piece appears broken off.
    You may need help on the switch.
    If you need parts there are some good ones online that show parts breakdown illustrations and you should have it in a couple of days. You can also get a part number online and call a local appliance parts place. Its a pretty common part.
    Good luck.
I find that I need to be extra gentle or it won't lock.  Try that.
Posted on Jan 06, 2009
Why won't my door lock?
If the door lock will not engage, then the door lock will need to be replaced. Here is the lock to order.
Nov 18, 2012 | Frigidaire ATF6000ES Front Load Washer
Washes clothes but won't spin it dry
Hi
First make sure that nothing is blocking the drain pump assembly located inside the bottom of the unit, after this test the door lock-switch assembly. If the door lock-switch is also fine then the control board should be replaced. Hope this helps...please post back for further assistance.
Daniel
Sep 15, 2011 | Frigidaire ATF6000ES Front Load Washer
How to operate the washing machines front load washer brandt bf850
  • Open the front door and load the clothing into the washing machine. Check the owner's manual for the maximum load size. Overloading the washing machine may interfere with its ability to spin the clothes and rinse them clean.
  • Fill the detergent receptacle on the front of the washing machine, making sure not to fill it past the indicated line. Always use a liquid detergent that is designed for front-loading washing machines.
  • Add bleach or fabric softener, if needed. Most front-loading washing machines have a section for fabric softener inside the detergent receptacle. Check the instructions on the bleach to find out when it should be added to the washing machine.
  • Close the front door of the washing machine and make sure it locks into place. The machine usually will not turn on unless the door is securely locked.
  • Check the owner's manual to find out how to select the different options and wash cycles. As a general rule, use warm or cold water for most types of colored clothing. Hot water should only be used when washing white cotton items.
  • Start the front-loading washing machine and let it run through the entire wash, rinse and spin cycles before opening the door to unload the clothing.
  • Please rate this solution. Regards.
    Nov 04, 2010 | Brandt WFH1176 Front Load Washer
    I have a kenmore front load washer model 41744052500 the other day i did a load of wash and when i went to the drain cycle it worked fine but whenit went to spin it went right a couple of times then left...
    tub was out of balance remove some of the heavier clothing and re spin! and in the future donlt try to run so much through it that are heavier items when they are wet
    Jan 12, 2010 | Kenmore Energy Star 44092 Front Load...
    Hotpoint WMA33 washer - door won't open
    Problem seems to have corrected itself! I tried another slow spin cycle, waited a reasonable interval for the Door Locked light to go off, then when it didn't I switched the power to the machine off. I tried squeezing the door catch a few times and pressing the door downwards, then left it. Some time later when I went into the kitchen the door was open. I washed a small load this morning and the machine worked normally. Fingers crossed, it's ok now.
    Oct 07, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
    I have a frididaire front load washer, and lately I have been seeing hole like spots on my white or light clothes what is the problem
    Check door boot at tub. sometimes is ripped. also check your dryer...at the drum to front panel....felt could be worn and will cause clothes to catch.
    Jun 10, 2009 | Frigidaire GLTF1670A Front Load Washer
    Frigidaire front load washing machine, the screen display DO
    This is Joyce
    If you are trying to fix this yourself you can go online and download a doc of your washer from frididaire.com put in model and then it willl give you doc you can download and fix yourself or you can call techn. if you need help finding one in your area I will be glad to help.
    thanks
    Joyce
    Dec 22, 2008 | Frigidaire GLTF1670A Front Load Washer
    Door locked
    sounds like your interlock has failed you can buy from any appliance spares outlet or online regards jason
    Jun 08, 2008 | Indesit W 123 Front Load Washer
    GE Front Loader Washer - Not washing
    It sound like a lid switch issue. If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. Look that the switch is not broken or loose. If all is fine, you should replace the switch. Good luck!
    Aug 27, 2007 | GE WBVH6240F Front Load Washer
    Frigidaire ATF6000ES Front Load Washer Logo
    112 people viewed this question
    Top Frigidaire Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
