D5VL on 42PF7220/A37 Chassis BP2.3 AA
Yesterday when my42PF7220/A37 would not turn on. Well actually it will - when powered upfrom by plugging in at the socket, the green led illuminates, there are2 clicks and then a 3rd click and the green led goes out and flashesred 7 times.
Taking off the back there is a small board and key - It has a green led which flashes 13times after the red led starts flashing.
13flashes means a "D5VL". I suspect this means low voltage on a 5Vcircuit. Any clues as to where to look next?
3 Suggested Answers
SOURCE: Panasonic TH-50PE700U red light flashing 6 times
Replaced the sc board and tv works fine again.
Posted on Jan 22, 2009
SOURCE: Philips 42PF7220A/37 42'' TV (LED flashes red 7 times)
Five buck solution; If you have any tek skills at all and are feeling adventurous; UNPLUG THE POWER, remove the back panel; You will be faced with the mainboard. In the lower right quadrant you will see two small capacitors, like tiny yellowish coke cans. If these are bulging, there lies your problem. These must be replaced. If you have no soldering skills, take only the mainboard to a fixit shop and have them solder in the two capacitors easily found on line. No guarantee's but worth a try
Posted on Dec 14, 2009
On my syncmasterp2270 I plug in that white power cord thing into the hard drive and it still won't turn on. I saw it up and running in the shop yesterday so I know I'm defs doin something wrong?
You have to plug in two cords. One you plug into the power outlet/power bar and the other you plug into your computer.
You might also have to actually press the power button on the monitor to get it to turn on. Some power on right away when you plug them in, others do not!
Jan 21, 2014 | Samsung SyncMaster P2270 22 inch Monitor
Philips 42pf7320 10 has flashing led 13 times error code d5vl
your set is a 42pf7320/??. very inportant in you case. The chassis is a LC4.9E AA. error 13 relates to IC 7D03 (HDMI panel link receiver).
Jan 07, 2014 | Philips 42 in. Plasma TV
How many volts is the power adapter
The speakers use a 10 Watt power supply
Sep 06, 2011 | Sony SRS-A37 Computer Speakers
C640 stopped powering up
If it will not power on from battery or AC adapter, Either the power switch is bad - OR the motherboard is shot - OR the LCD is not working. I would suggest taking it to a local PC shop and having it diagnosed, usually this costs about $30 I work for TechSupportPros of Spokane, WA and charge $30 to diagnose computers.
Feb 05, 2010 | Dell Latitude C640 Notebook
I can't get it to turn on. I put a new AA battery in but it still won't turn on. Do I need special batteries? Or which button is the power button?
  • The HTsi & HTsi Plus cameras do not take AA batteries. They take two CR2 batteries. One AA battery will only be 1.5 volts. The CR2 batteries are 3 volts each, providing 6 volts to the camera(when you have 2 installed). So if you insert a AA battery, there is not a high enough voltage to allow the camera to operate, which is why it doesn't do anything in your case. The AA battery will not damage the electronics of the camera, but it may physically damage the "battery compartment door" if you have to force it closed.
  • There is a slide-type button on the back that is labeled "Lock . . On".
    The "On" mode is just that, it turns the camera on. The "Lock" mode is actually the "Off" mode.
Sep 06, 2009 | Minolta Maxxum HTsi Plus 35mm SLR Camera
No power to the chassis
Could have a broken earth strap
Aug 25, 2009 | 1987 GMC R3500
Protron PLTV-3250 doesn't turn on
May be the power fuse.
Older CRT sets had an external chassis-mount fuse holder at the rear.
Nowadays, many sets have the fuse on a power / control board inside.
If fuse is blown, renew with an identically-rated match.
This protects the TV.
Oct 06, 2017 | Televison & Video
New washing machine servis M6725,dispenser drawer will not open.only got it yesterday
i have just used my servis washing machine 1300 aa and just went to put a new load in and there is no power to the machine at all i have checked the fuse and the plug wiring what else can i dp please advise???????
Jul 29, 2008 | Washing Machines
Phillips 37FD9944/01S Plasma TV - Power Supply
dont waiste your money problem main or logic board or if shure power supply go radio shack and get one with specifications match voltage,ampers,and polarity
Mar 30, 2008 | Philips 60PP9352 60" Rear Projection...
Televison & Video Logo
90 people viewed this question
Top Televison & Video Experts
