HP229h. How to change position from vertical zu horizontal?
2 Suggested Answers
shaggyrat
  • 1224 Answers
SOURCE: vertical positioning setting is frozen
lets see what i can do
sometimes under the screen edge either side or bottom they have the menu buttons these have become hard to find but there on your screen on one of the buttons the select should be de gaus (spell check) this sends a powerful power signal to monitor to reset its self some times its scary to watch but when it does that it should release the buttons parameters back to working state then use the buttons to set your parameters
the other thing is there is something stuck or broke in the button which was pushed a little harder then most
if this is the case
and you dont want to mess with monitor then take to computer tech. they will tear down and replace button backing sometimes the button backing points break off or disalign do to tomuch preasure on the button
i hope this helped you
Posted on May 26, 2008
Memory seats adjust on there own as well as mirrors
BCM has nothing to do with this function , MMM - memory mirror module !
Memory Mirror System Operation
The MMM is capable of storing mirror position for 2 different drivers. Mirror position is determined by both horizontal and vertical position sensors in each of the power mirrors. The MMM supplies a reference voltage and a low reference to these sensors and determines mirror position through the horizontal and vertical position signal circuits.
The MMM receives power through the battery supply voltage circuit and the MIR/LOCK fuse and a constant ground source. Any time that battery voltage is disconnected and then connected from the MMM, the MMM will enter the mirror relearn mode. The mirror relearn mode can also be commanded using a scan tool. Refer to Memory Mirror Module Learn for further information.The memory switch receives power through the battery supply voltage circuit and the MIR/LOCK fuse. The MMM upon receipt of a memory switch signal input, a class 2 message from the SIC or a class 2 message from the PCM indicating that the transmission is in park, will then supply battery voltage and ground to the appropriate power mirror motors through the mirror motor control circuits to move the mirrors to the predetermined positions.
DTC B1586, B1596, B1616, or B1626
The mirror horizontal and vertical position sensors are potentiometers. The Memory Mirror Module (MMM) provides these sensors with a 5 volt reference circuit and a low reference circuit. The MMM monitors the horizontal and vertical position sensor signal circuits which change values based on mirror position. These voltage values are used to determine mirror position and can be set into memory. When the MMM receives a memory recall request, the MMM will control the power mirror to the memory position based on the horizontal and vertical position sensor signal values.
Install a scan tool.
Turn ON the ignition, with the engine OFF.
With the scan tool, observe the mirror horizontal and vertical position parameters in the Memory Mirror Module (MMM) data list.
Operate both the left and right mirrors through the full range of movements.
Does the scan tool indicate that the left and right mirror horizontal and vertical position parameters are within the specified range?
Memory Seat System Components
The memory seat system consists of the following components:
• Power seat switch assembly
• Memory recall switch assembly
• Horizontal adjuster motor
• Front vertical adjuster motor
• Rear vertical adjuster motor
• Recline adjuster motor
• Memory seat module
• Memory mirror module
• SEAT 25A circuit breaker
• MIR/LOCK 3A fuse
Your best bet , take it to a qualified repair shop !
May 23, 2017 | 2002 Cadillac Escalade
Tip
SERVICE MODE AND ADJUSTMENTS
Accessing Self Diagnostic Menu
1. While LCD TV set is on standby mode, press the following
sequence on the Remote Commander key. (RM-GD020)
For more check the following link. Use the search tab on the top right corner on the page to find your product.
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
on Feb 18, 2015 | Sony Kdl-32cx520 32" Full Hd Multi-system...
I have a thin line in my tv and i dont know what ic no.to replace?
The fault is a failure of the deflection circuit and since you have not specified whether it is a vertical or an horizontal line the section failed will be related to the position of the line.
If horzontal the vertical IC or the section related is faulty and if Vertical the horizontal section., Now this can be the deflection IC, teh deflection coils or even discrete components like capacitors or resisitors in this section which will require a signal trace with a voltage test before the absence of the sync pulses are confirmed and the section identified.
I request not to change the IC unless it is proved but you can solder the vertical IC or the section concerned -- if there is dry soldering.
Aug 25, 2011 | Toshiba 32A50 32" TV
My wires are labeled A1,A2 ,A3 and A4 .how do they connect to the terminal block
hi..there is color coding on the wires..BLACK WIRE is the live wire(wire #1) which should be connected on top of the terminal supply of your oven (if vertically positioned) and sometimes to the leftmost right(horizontally positioned),then the RED WIRE to the bottom (vertically positioned),or rightmost part (horizontally positioned) and the WHITE WIRE is at the center(both horizontally/vertically positioned0 and the GREEN wire must be connected to the grounding of the unit just below/beside the terminal supply of your oven..hope this helps..
Apr 16, 2011 | Bakers Pride P-44S Oven
My Dymo LabelWriter 400 is printing vertically. How do I change it to print horizontally? Thanks
Hi Kaylene, i`ve experience that before.. Just set the print set-up/ preview into horizontal.. The dialog box of print preview will show you the position of your text before printing Dymo Label! goodluck!!
Feb 07, 2011 | Dymo LabelWriter 400 Turbo Thermal Printer
Need a wiring schematic for a Bakers Pride p44 double pizza oven.
Apr 15, 2010 | Bakers Pride P-44S Oven
Monitor has all in a horizontal position,want vertical
do you mean the task bars? if so click on them and drag them back down to the bottom of the screen
Sep 03, 2008 | Logitech 967437-0403 Keyboard
One green vertical line in HDTV Vizio 42
Try changing the H/V position in the TV Set Up menu. You can adjust the horizontal and vertical position of the screen and move it enough that the green line disappears from the screen.
May 18, 2008 | Televison & Video
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
