Question about Sharp AR-5316 Advanced Digital Imager Copier
Sharp ar-5520 toner caution red light is on and i can't print
  • 257 Answers
SOURCE: Get F2-40 error on sharp ar-5520 Im a newbie in
How are you , this problem occurs when there is very low toner concentration on the unit or low developer.
solution
  1. Replace a toner cartridge and make sure it is smoothly running as some come with hardened toner or
  2. Replace a new developer which is Sharp Ar 205 dv Check that the toner motor is rotating well
This error is self resetting so no need of simulation code. Bye.
Posted on Oct 23, 2010
  • 148 Answers
SOURCE: F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
Posted on May 26, 2008
  • 3 Answers
SOURCE: a new sharp ar 5316e photocopy machine photocopy blank
change the main charger because based on my experienced it has an arching problem
Posted on May 23, 2009
SOURCE: I have a Sharp AR-507. Error F2-00. How to fix?
It could also be the sponge roller in the toner hopper. The old ones started to deteriorate after a while so sharp modified them.
Posted on Jun 17, 2009
SOURCE: SHARP AR 5012 developer reset
i have a sharp sf 1025 , and i want to reset developer conter? can u help me pls
Posted on Jul 17, 2010
SHARP AR-5520 RED TRIANGLE LIGHT BLINKING HOW TO SLOVE THIS PROBLEM?
If the triangle of dots points upward it needs toner, if the triangle points down the machines waste toner needs to be emptied out.
Apr 27, 2017 | Sharp Office Equipment & Supplies
I have a problem with sharp AR 6020 photocopier machine that is displaying triangle and minus symbols how can i solve it
The Triangle may be the toner low light. On the older models it would look like a Triangle of stacked up cannon balls. I am not specifically familiar with your exact model.
Feb 19, 2017 | Sharp Office Equipment & Supplies
CH blinking in sharp photo copyier model AR 5520
check if the toner is insert or check the doors for the machine both the front and side door door
Nov 05, 2016 | Sharp AR-5520N
SHARP AR 5520 keep displaying TONER INDICATOR ALARM MESSAGE whenever I switch on the copier. And even if there is toner, the message keep displaying. So what is the problem?
Dear
The ink cart. is dual component one is drum unit and other is toner unit. You may go to system information there consumable information which indicate the status of the both and according to that replace the chip of the respective cart.
Thanks.
Jan 12, 2015 | Sharp Office Equipment & Supplies
Hello! How do i network my sharp AR 5520
Interface Std/Opt USB 2,0 Any print server with a usb connection will work. Do a Google search.
Mar 12, 2014 | Xerox Computers & Internet
Sharp ar 5520
Check programme setup. before printing you should have a setup window to alter the shading same place where you enter number of copies required
Oct 31, 2013 | Office Equipment & Supplies
My machine model is SHARP AR 5520,the problem is that the machine is returning all the toner into the waste bin,all the toner will be sent into waste within an hour or two.this happened when i refilled the...
hello,
problem is your toner cartridge. inside of the toner cartridge have a toner roller it's didn't circling.or you are using duplicate toner powder.it's doesn't match with sharp ar 5520 developer. or your developer was expired.
first use original toner and try to make copies .i think your problem is solved.
Feb 05, 2011 | Sharp AR-5316 Advanced Digital Imager...
solution
Oct 21, 2010 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
128 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
