Question about Exercise & Fitness
Sport craft TX 4.9 treadmill shutting off at error 3
4 Suggested Answers
  • 15 Answers
SOURCE: TX 4.9 sportcraft treadmill
Info from PDF files located on Sportcrafts website under manuals.
E3 – No speed sensor reading. Unit shuts down. This is the most difficult repair diagnose. The speed
sensor is connected to the frame of the treadmill near the drive pulley on the front roller. There is a
small magnet on the side of the pulley wheel. The sensor tip must be no more than 5mm from the
magnet. If for any reason the distance is greater than 5mm the treadmill will shutdown
Adjust or replace speed sensor.
Treadmill: Speed Sensor Replacement
1. Make sure your treadmill is unplugged before you begin.
2. Remove the motor cover located in the front of your treadmill, it is held on by a few screws.
3. Locate your speed sensor; it is the small T shaped part with a red and black wire coming from it.
4. Remove the 2 screws in the speed sensor and remove the old sensor.
5. Place the adjustment holder on the frame with the open holes facing the pulley wheel, the prongs facing
up and way from the pulley wheel. Insert the screws but don’t tighten fully.
6. Now place the speed sensor over the prongs with the square part facing the pulley wheel and the red and
black wire to the far right.
7. Plug the treadmill back in and slide the speed sensor until it is 5mm from the magnet inside the pulley
wheel, you may have to do this several times until you can position it so it no longer shuts down. Use 2
nickels to figure out the spacing. The width of 2 nickels is 5mm.
8. Once you find the correct position tighten the screws all the way; being careful not to touch any of the other electronics
9. Place the motor cover back on and enjoy your machine.
Posted on Oct 17, 2009
SOURCE: Sportcraft TX 2.5 treadmill - error code 3 - stops
Sorry I dont have the solution but I have the same problem.
Read somewhere that Sportcraft control boards had
a design flaw.
Posted on Dec 20, 2009
SOURCE: Sport Craft Treadmill model TX2.5xt, showing
You need to put the RED SAFETY KEY on the Yellow spot on the control panel to turn it on. EO will disappear once you put it on.
Paul
Posted on Apr 11, 2010
We picked a TX 440 from a friend and the error button shuts it off
If you wish to get some details About treadmill repair; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Sep 11, 2016 | Sportcraft Tx 455 Sportscraft Treadmill...
This leaver won't budge I've tried everything can't get it to unfold treadmill sports craft tx 390
Have you tried pushing forward on the platform while using the lever? They can get in a bind and stick
Jul 01, 2016 | Exercise & Fitness
My tx335 treadmill will run for about 7 sec. then stops running. It shows up on the monitor the number 3 when it shuts off. What could be wrong with it and how can I fix it??
That is the speed sensor interrupt. Sport craft is hard to get parts for. You can take the cover off and see if you can repair it though
Jun 25, 2014 | Exercise & Fitness
The treadmill shuts off after a minute, producing an Error message.
see the video proceed according and lube the rollers bearing front+back too.
God bless you
Nov 03, 2013 | Sportcraft Tx 455 Sportscraft Treadmill...
SPORT TRac treadmill shuts off after a few seconds
1) LUBE THE DECK BELT, this produce enough friction for shutdown the machine.
2) LUBE the rollers bearing very well.
3) Test the input voltage motor, if there are VOLTAGE, the motor need repair.
4) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
See the block diagram. God bless you
May 27, 2012 | Sportcraft Exercise & Fitness
Sport trac treadmill shuts off after a few seconds
1) LUBE the deck belt, this produce enough friction, by lack of LUBE
2) Lube the roller bearing, very well
3) Test the input voltage motor, if there are the motor need repair.
May 27, 2012 | Sportcraft Tx5.0 Tx 5.0 Rc Treadmill Motor...
My Sportcraft TX-400 Treadmill shuts off after 7 seconds
Dear sIR:
This by lack of LUBE, in your schedule maintenance DECK BELT. maybe the belt is worn.
2) Lube the roller bearing.
3) Align the belt see the diagrams
4) Test the input voltage motor, if there are voltage motor, the motor need repair.
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
Now you can RUN the software calibration for diagnose, troubleshooting. See my personal TIPS for HELPs too.
sincerely. God bless you
May 06, 2012 | Sportcraft TX 400 Walking Belt
Treadmill giving me error P1U
Got it. See last page of manual found here: http://webpages.charter.net/chestnuts/Trimline%20Owner%27s%20Manual-1600-2600-3600-4600.pdf
i.e. stuck in calibration mode.
1. Press & Hold PROGRAM INTERVAL, SPEED DOWN and POWER
2. Release SPEED DOWN only (must hear a beep or repeat 1 &2)
3. Release the other two
4. Press PROGRAM INTERVAL (treadmill will move up or down)
5. Press PROGRAM INTERVAL (treadmill will move up or down)
Calibration is complete. Enjoy your exercise!
Eric
Ottawa, ON
Aug 29, 2011 | Sport & Outdoor - Others
Kettler Treadmill TX 3 gives error 91 supplier told it was the Power supply print. We changed it including the motor and the problem was solved for a couple of weeks. Now it is back again? Please...
Problem with Trendmil TX-3 err-91 problem is solved ... speed sensor (photo transistro in photo cell is damaged).The palsis in colector is 5V Amplitud .
Apr 05, 2011 | Kettler TX3 Folding Treadmill
Exercise & Fitness Logo
56 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
