Question about Scotsman Cooled Modular Contour Cuber Air Condensed 975lbs
CME500 ICEMACHINE MAKES ON BOTTOM PART OF CUBER ONLY
I HAVE A COMMERCIAL ICE MACHINE CME500, IT MAKES ICE ON THE BOTTOM PART OF THE TRAY ONLY AND KEEPS BUILDING UP AND THE TIMER DOES NOT ADVANCE TO HARVEST CYCLE. MANUALLY WHEN YOU ADVANCE THE TIMER IT HARVESTS AND THEN AGAIN IT GETS STAYS IN SAME POSITION
  • kingsinn Jan 08, 2009
    The actul problem was with the themal expansion valve
  • 163 Answers
Hi!!!Relax you just answer your question.If you went and advance the timer and it work but was stuck in the same position well its your bad timer.change timer and you will be fine..Good luck
Posted on Jan 05, 2009
Scotsman icemachine constantly freezing up no matter how small you put the setting?
Max harvest cycle just keeps it in a harvest longer. if you set the freeze setting to its lowest point and ice is still to thick then replace the freeze stat.
Feb 22, 2015 | Scotsman Ice Machine, Cuber, 1930 lb....
Ice t3 error
check water supply line for blockage. check lever is operating correctly. empty tray and see if it makes ice.
Dec 10, 2013 | Electrolux EI23BC56IS (226 cu ft) Bottom...
I have a MV450 icemachine that work for up to 4 days without any problem .Then it cuts out the hi pressure indicator light up .i have checked the gas charge and cleaned the condensor
The magnetic switch just lets the machine know it finished a harvest and start ice production all over again. high pressure could be a dirty coil, fan motor stops working, a possible refrigerant restriction, or the room that the machine is in is getting to hot but this would cause the production of ice to take longer. it should be making ice every 15 to 18 mints in a 74 deg room.
Oct 05, 2013 | Scotsman Cooled Modular Contour Cuber Air...
My ice machine model f-450 mah makes ice but once it's full the water keeps running and runs out of the machine how do I fix this?
Make sure the plug in the water tray is secure and not allowing water to drip out. Check to make sure the float turns off the flow water once up to level.
Mar 01, 2011 | Hoshizaki Freezer Commercial Ice Machines...
Scotsman icemachine cm506 stuck in harvest hot gas won't close any ideas?
check for power to valve coil. If it remains it's a control problem. If no power and still in harvest, valve is stuck. Unit usually does not exceed a 6 to 8 minute harvest.
Aug 17, 2010 | Scotsman Cooled Modular Contour Cuber...
We have an older manitowoc icemachine model ey 040a that we can't get make ice. It has a new compressor and the water semms to be fine too
The EY0404A was manufactured in the mid to late 80's and and uses R-502 Refrigerant. Best bet would be to upgrade to a new energy efficient unit using an environmentally friendly refrigerant. The average life of that EY0404A was about six years. Hoshizaki makes the best.
Jun 04, 2009 | Hoshizaki Commercial Freezer KM-500MAH
How far can the condensor be located away from ice machine
Their web site has all your answers. Their tech support line is worth the wait. 1-800-233-1940.
I usually don't exceed 25 feet. If it is a straight up install, that is, the remote is on a roof, you may have to install traps to ensure proper oil return to the compressor, Otherwise, it will lockup on ya.
Jan 16, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Not dropping ice
the water pome geting to hot and not raning
Jul 02, 2008 | Hoshizaki KM-630M Crescent Cuber Ice Maker
Scotsman Cooled Modular Contour Cuber Air Condensed 975lbs Logo
139 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Tim Whalen
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
