Question about Minolta EP4000/5000 CS/PRO Copier
Code c0555 code is coming after the machine open
  • Minolta Master
  • 6,696 Answers
No such code on a Ep5000. please come back with a new code
Posted on Feb 08, 2015
What does f26 mean for siemens washing machine
F26 come up This error code indicates that the door needs to be opened and closed.The F26 code may appear the first time you try to use the washer. Open and ...
Jan 03, 2016 | Siemens Washing Machines
The door is opening even when the machine is on.Error code 50 comes on display
It ispossible that the error comes because the door was opened during the cycle. Remove power for sometime to reset . Now check the door lock and safety on feature while the cycle starts. If there is fault in this link the program will show an error.
Check the lock : http://www.espares.co.uk/advice/washing-machines/a/7/1207/how-to-replace-a-washing-machine-tumble-dryer.html
Jun 28, 2012 | Washing Machines
Error code F26
The F26 code may appear the first time you try to use the washer. Open and close the door to clear the display.
The F26 code may also appear if the washer has run three cycles without the door being opened. Open and close the door to clear the display.
If opening and closing the door does not remove the error display, press Pause/Cancel twice
Oct 22, 2011 | Whirlpool WFW9200S Front Load Washer
Got a bizhub c550 and error code c-0206 came up and it just wont reboot or do anything. Help
This code means that your paper tray 3 is not lifting the paper properly. Usually this is because the paper is not loaded properly. Open then close the front door to reset the code then immediately open tray 3. Check to insure that the paper is loaded properly. I would remove all the paper and then re-load. Leave tray 3 open long enough to verify that the machine will warm up and make copies. Then close tray 3 and see if the code comes back. If not then you are good to go. If it comes back then there is a tray lift problem with tray 3 and it will need service. Open tray 3 and reset the machine again. You can leave tray 3 slightly open to at least be able to use the machine until it gets repaired.
Good Luck and Thank You for using Fixya.
Sep 09, 2010 | Office Equipment & Supplies
Get alarm code ld
CI code comes on just seconds after I start the machine. The machine itself is leveled on all sides.
Dec 26, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
C-0991 error on screen
First problem is for some reason your KMC 3130 crosses over to a Konica Minolta CF3102 and there is no C-0991 code listed for those machines. However, that C-0991 code is a common paper tray lift failure code on Konica MInolta machines.
So I would recommend opening and checking all of your paper trays to make sure nothing is binding them and that the paper is loaded properly.
Then open and close the large front door to reset the code.
If the code comes back then open all of your paper trays and LEAVE them open. Next open and close the front door to reset the code. The copier should now come to "ready to copy"
Then close each paper tray 1 at a time waiting 30 seconds between each tray closing. Once the code pops back up after closing a particular tray then you will know for sure which tray is causing the problem.
You can use the copier by leaving this tray open if need be.
Good Luck.
Nov 24, 2009 | Kyocera Mita KYOCERA/MITA - KM-C3130...
DE code on WM0642HW TROMM washing machine We've been getting this error code on our washing machine for some time. The code is coming up quite frequently now. It stops the cycle so the load is not...
HI, this is a Door Open Error.
Possible Causes are..-
* Door not all the way closed
* Loose electrical connections at door switch and pwb assembly(Control Board)
* Door switch assembly is out of order(Miss aligned)
* Gasket on door may be creased in
Most common issue here will be a defective door lock switch. check all causes before replacing the switch.
Jul 11, 2009 | LG Washing Machines
Machine code
It must be a thread on your computer think hardly haven't you downloaded a hack program or some game with unsuspected error. this can solve all the problem
Oct 25, 2008 | Yahoo Mail
Epic 9600 model door will not open machine will not engage code comes on screen dl f
hi there,
this code means you have a door latch error. this is why the door does not open or does not work. the machine automatically shuts down when this error happens to prevent the machine from running endlessly. call a technician to replace the door lock.
thanks
Oct 02, 2008 | Maytag Washing Machines
37 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
